My unit stopped heating - Heating & Cooling
  • 81 Answers
Probably your reversing vavle in the outdoor unit. does it still cool well?
Posted on Nov 09, 2010
Is the heat pump cooling itself down? It is a combination heat pump/air conditioner wall unit.
If a unit is in heating mode the outdoor unit is in cooling mode (outside always does opposite of indoor) after a while if there is a build up of ice on outdoor coil unit stops and puts hot gas through outdoor coil to clear it. The indoor fan stops to avoid and heat loss in area served buy unit once this has been done and indoor unit coil is hot again fan will start. This is the correct operation of the unit to save against bust could and reduced efficiency
Dec 31, 2015 | Heating & Cooling
LG model TS-K2430hl .Outside fan stops after a few min.
Should like your unit is working fine unless this is constantly happening. If this is a constant thing then condenser coil if dirty,check thermostat setting
Dec 16, 2017 | LG Heating & Cooling
Heat and air unit heat stopped working
1-Check Thermostate for setting may wrong or Th. faulty.
2-Fuse near to heating element blown, Change it.
Nov 12, 2013 | LG Electronics 23,500 BTU 230v Window Air...
How do I fix heat on unit Frigidare Model LRA12HZT2?
There are no heating strips within this unit. This unit has a heater part 5304476390 that you would need to replaced upon a diagnosis.
Dec 24, 2012 | Frigidaire FAH106N1 Wall/Window Air...
Mitsubishi MSZ GA80VA stopped cooling after being regassed.
The "service person" could have used leak detector the first time to make leakage obvious.
Feb 20, 2018 | Heating & Cooling
When the air con is on heating it works fine for about 5-10 minutes and then the compressor stops and then the outdoor fan stops and then the indoor unit stops heating.
This could be any number of problems depending on whether this unit is a heat Pump or not. It sounds like it is a heat pump, if so it should have a defrost board or Control of some type. They also usually have a defrost or ice sensor on the outdoor Refrigerant coil. When ice or heavy frost is detected it puts the unit into defrost. This Could be why your unit is cycling off, the sensor could be bad or the board could be Bad. Also be sure your air filters are clean and the indoor and outdoor refrigerant Coils are clean. This may require you to remove the unit and hose it out.
Aug 09, 2011 | LG Art Cool LA121CNP wall/window Air...
The turn table stopped turning and the unit stopped heating.
the turn table stopped and the unit stopped heating.What should I do?
May 30, 2011 | Goldstar MV-1501 Microwave Oven
The dryer unit I have has stopped producing heat
could be either the ignitor or a bad coil on the gas valve or a bad gas valve to start with..
Jul 21, 2010 | Kenmore Dryers
Amana Cooling Condensing Unit fan stops spinning after 15 mins
Capacitor, dirty condencer coil causing the motor amps to run too high. But most likely worn bearing on blade side of motor causing it to pull to one side causing it to over heat and shut down. Sleve bearings should have no side play.
Jun 28, 2009 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
13 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
