Question about AutoCommand Remote Car Starter Add-On
98 chevy truck Z71- When using the remote starter every thing works good except the engine light comes on with transmission codes stored in memory. The transmission then has a shifting problem until codes are cleared. This remote starter was installed about five years ago and never figured out what to do to repair problem. Hopefully someone can help. Thanks, James
  • 139 Answers
The remote start system has been improperly installed. This is a common occurrence for the vehicle that you have. To correct the problem, you need to make sure that the vehicle's primary ignition (pink), ignition #2 (orange) and ignition #3 (white) wires are connected to separate ignition sources from the remote starter. This may require the addition of relays depending on the number of high current ignition outputs available from the remote start module.
If you have the model #25622 remote start installed than you need 2 extra relays. The relay terminals need to be wired as follows:
30 = to vehicle extra ignition wire
87 = to 12V constant source (fused at 20A)
87a = no connection
86 = to r/s module thick green wire
85 = to chassis ground
Both relays need to be wired the same way.
Posted on Nov 09, 2010
Remote starter comes only briefly and shuts off
Factory Remote Starter Quits After 5 Seconds - Diesel Place ...
www.dieselplace.com/.../340832-factory-remote-starter-quits-after-5-sec...
Nov 23, 2009 - 11 posts - ‎8 authors
On my 2007.5 Duramax, the factory remote has been working fine ... I tried this morning again with the remote starter while sitting in the truck and same thing, turned off ....2008 Silverado 2500 HD CCLB Duramax 6 Spd Allison 4X4 Z71 ... shut off engine", basically its doing it foryou as your not in the truck to ... check engine light on wont shift
Oct 28, 2011
remote start
Oct 14, 2008
More results from www.dieselplace.com
Factory Remote Start Problem - 1999-2006 & 2007-2013 Chevrolet ...
www.gm-trucks.com/forums/topic/114985-factory-remote-start-problem/
Jun 12, 2010 - 10 posts - ‎8 authors
Factory Remote Start Problem - posted in 1999-2006 & 2007-2013 ... Sounds like you may have an intermittant code coming in and the dealer should be able to pull it out.2008 Sierra SLT ECSB Z71, Corsa Touring, and GMPP CAI .... the remote start button again the truck WILL shut off and the only way to ... Burning smell, white smoke - 2014 / 2015 / 2016 ...
Jan 11, 2014
2008 Silverado Electrical Issue
Aug 19, 2012
Making Factory Remote Start Run Longer
Dec 21, 2010
2000 Sierra, Starts Then Dies - Code 1631
Dec 4, 2008
More results from www.gm-trucks.com
Jan 05, 2016 | 2008 Chevrolet Silverado 2500HD
How can i find out what's wrong with the transmission in my 99' Chevy Silverado Z71?
Have you checked the fluid level? Plus the color of the fluid. It could just need a transmission fluid & filter change.
Nov 28, 2013 | 1999 Chevrolet Silverado 1500
1993 Chevy 4x4 Z71 has lost 2nd gear
The following are the general instructions on the start of diagnosing any electronically controlled engine or transmission problem.
The engine and the automatic transmission (transmission control is only for automatics, engine is still computer controlled no matter the transmission type) in this vehicle are computer controlled and in most cases when a fault occurs a fault code is stored in the memory of the computer control module. There are exception to this, such as the Mass Airflow Meter and fuel pressure problems. What must be done is to have all the basic testing done such as a scan of the system for fault codes as well as a check with a live data scanner tool for engine functions that are not within range of normal, a trained technician is required to know what is correct and what isn't, then based on careful diagnostics done from a factory repair manual the correct part is replaced or the wiring repaired or the computer replaced (known as the PCM), which is very rarely the problem. Other basic checks must be done as well such as mechanical problems with the engine as well as engine state of tune and mileage on the engine. The transmission can have mechanical issues as well such as no gear engagement at all or a failed pump or other pressure related problems. Also engine mechanical problems ca cause many drive-ability related problem such as rough idle and other symptoms
Oct 16, 2012 | 1993 GMC Sierra
I have a 99 Chevy silverado 1500 z71....I just installed a 4l60e transmission and now the speedomotor is pegged out and not working...I think thats what is stopping the transmission from shifting correctly
Oct 10, 2012 | Cars & Trucks
How can i fix my auto start on 07 escallade
when there is any stored check engine light codes the remote starter is disabled fix the codes and the starter will work again most large auto parts stores will scan it for free in hopes to sell the parts needed to repair it
Aug 28, 2012 | 2007 Cadillac Escalade Ext
98 chevy 5.7 z71 misses when 1st cranked
Hello
The engine and transmission in this cars drive train are fully electronically controlled by a computer called the PCM (Power Train Control Module). Whenever a problem like this occurs the computer stores a record of the problem (there are of course some exceptions to this, like the fuel pump for instance) in the form of a fault code in its memory, to read these fault codes you must have the systems memory scanned with a special tool. Once the fault code(s) are read you then must perform the appropriate diagnostic testing to find and resolve the problem(s) DO NOT REPLACE ANY PARTS UNTIL THE DIAGNOSIS & TESTING IS COMPLETED.
Jul 09, 2012 | 1998 Chevrolet K1500
I changed the fuel filter on my 98 chevy z71 and the service engine soon light stays on. How do i get the lihgt off?
Take it to advanced auto they will hook up their obd2 reader print you outt the code and shut the light off
Jan 29, 2011 | 1998 Chevrolet C1500
My remote start is not working and the service engine light is on in my 09 chevy impala. what could the problem be?
The Factory remote start is disabled any time the check engine light is on. You'll need to find out what is causing the check engine light to come on by using a scan tool/code reader to read the codes stored in the computers memory.
You can buy a basic code reader for about $50 and do this yourself. You could buy a nice scan tool for $3,500 to $10,000 and again do this yourself.
You can also call your local auto parts store. Sometimes they will read codes for free. Please do not buy what every they think is the problem.
The last thing you can do is head into your local shop or dealer if under warranty and have them do the diagnostic test to see what the codes are and why they are being triggered. There is usually a set fee for this.
Some common things that come to mind that would cause a check engine light are, Low coolant temperature, loose/missing gas cap, Catalytic converter inefficiency, and maybe an O2 sensor code.
Good luck and let us know what codes you find.
Dec 16, 2010 | 2009 Chevrolet Impala
2001 Chevy Impala won't start
If the battery has gone dead, it could cause the security system to go into full lock-up mode. If it has locked up the accessories will work after the battery is charged back up , but the power to the starter will be cut off and it wont turn over. You need to do the 30 minute learn procedure. A GM dealer will print it out for you and you can do it yourself. It's very simple if you follow the procedure exact. hope this helps and good luck.
Feb 21, 2009 | 2001 Chevrolet Impala
2000 chevy impala will not start with remote start
There are several things that can cause this.
A common cause for this is that the check engine light is, or has been been on. When the check engine light comes on, a trouble code is stored in the computer. Most trouble codes will cause the remote start to become inoperative. Repair of the check engine light code is needed first. A scan of the system will show any stored codes.
Another cause is a faulty hood ajay switch.
Tech JK
Jul 23, 2008 | 2002 Chevrolet Impala
AutoCommand Remote Car Starter Add-On Logo
200 people viewed this question
Top Design Tech Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Design Tech Vehicle Part and Accessory Expert? Answer questions, earn points and help others
