Question about Samsung LN26C450 26 in. TV
LN26A450C1DXZA Samsung 26" Flat
  • 1779 Answers
SOURCE: HDMI outlet seems to be bad/ no picture
Main Bd part# BN94-00629F and sells for $201.00 that includes a 50.00 dud. Encompassparts.com
Posted on May 10, 2009
SOURCE: Samsung LCD TV doesn't power on, just blinks 5 times
After about 5 years the Samsung LCD televisions backlight fails which prevents the TV from coming on and the powerlight just flickers the backlight can be changed but it is often alot easier and cheaper to buy a new Television
Posted on Sep 23, 2009
  • 4 Answers
SOURCE: Samsung LN26A450 LN26A450C1DXZA won't turn on
I had the same problem with my Samsung LN26A450 LCD TV. I found the following YouTube video http://www.youtube.com/watch?v=Mm51C_RDIZE titled "Samsung TV Repair - Part 1 of 2) (also watch Part 2 of 2) which shows how to easily fix the problem. The problem is bad capacitors on the power supply board. My TV had seven (7) bad capacitors - all 7 had dark stains on the ends from leaking electrolytic fluid and one (10V 2200MFD) was blown with bulging ends. I ordered 7 new high-temp (105 degrees C) aluminum radial capacitors from DigiKey.com matching the Temperature, Capacitances and Voltage Ratings for each damaged capacitor that I removed. I followed the instructions in the video except I used desoldering braid ($3.99 at RadioShack) to remove the solder attaching the bad capacitor leads to the power supply board. Once you wick up the old solder from all sides of each lead wire using the desoldering braid, the bad capacitors are easily removed. Total cost of repair including soldering equipment was less than $50. Thanks to “The Professor” for posting the video and saving me $400.
Posted on Oct 30, 2009
SOURCE: Bottom half of the screen is black on Samsung HP-R5072 50 in. HDTV Plasma Television
I have a solution. My Samsung plasma had the same problem with the bottom half of the screen being black. Follow these directions and it will not cost you a dime, just some time. I took the back panel of the tv. I found the lower buffer board on the left hand side. I disconnect all the ribbon cables. Use an air cleaner to spray out any dust on the ribbon connection and the board. I connect the ribbons back to the board. My plasma is now as good as new. If you have issue with the top portion, do the same with the upper buffer board. I was going to buy a new tv but I'm glad I gave this a shot first. It's been almost a month and it's still working fine. Hope this helps and hope it saves you some money.
Posted on Nov 14, 2009
  • 21 Answers
SOURCE: Samsung 32" can not turn on
It could be a faulty power supply (capacitors). To all who are having power supply issues: Samsung is now acknowledging a problem with faulty capacitors. I called 1 800 726-7864 and they said they would repair certain out-of-warranty TVs if the problem is related to the capacitors. I just called and they are sending a service rep out to diagnose the problem
Posted on Feb 22, 2010
I have a 65 inch Samsung TV approximately 2 1/2 years old . Recently developed a 10 inch Parker sheeted lying horizontally across the bottom of the screen. Is this repairable? What's wrong with it?
every tv is repairable , it is just a matter of money
take it to a tv repair shop get a proper diagnosis and a quote then decide to repair or replace it
the problem that most people have is that they try diy repairs first and generally end up with a unit that is still faulty and has cost more in parts than what a new unit would have cost
Jul 10, 2016 | Samsung Televison & Video
Tip
SERVICE MODE AND ERROR CODES CHECK
Viewing the Self Check Diagnostic List
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
3. To exit Self Check display, turn the power off. Press [Menu] Exit.
Clearing the Self Check Diagnostic List
1. In Service Mode, press the Channel 8 Channel 0 .
RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
White Balance adjustment
1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
3. Set the Picture Mode to "VIVID" in the user menu.
4. Select the Component In input.
5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
Green", "Black Level Offset Blue" to average values .
"Cool " White Balance Adjustment
1. Select "COOL" from Color Tone in Service Alignments Menu.
2. Input 70IRE full white pattern signal into Component In.
3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
4. Input 25IRE full white pattern signal into Component In.
5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
6. Repeat steps 2 to 5 to achieve desired White Balance.
FOR MORE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE THE DROP DOWN MENU
on Jun 30, 2015 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
Why did the audio go out on samsung ln26a450c1dxza
Probably because of a power supply failure
Feb 24, 2013 | Samsung LN26A450C LCD TV
I have a Sanyo DP26649 TV and the front screen a a scratch on it and I was wondering if the front screen can be replaced. If so where can I purchase one. Thanks
Generally no, the vast majority of TV repair shops will inform you that the panel on your LCD TV is not worth repairing.
With the low cost of 26 inch TVs right now, they're now seen as a throw-away commodity. When they break, the best bet is to get a new TV. It works out to be cheaper in the long run. We've come to a point where TVs are disposable.
At the electronics store I work at, an entry level 26 inch TV sells for approximately $250. To repair a panel on this TV would cost approximately $150 to $200.
Mar 10, 2011 | Sanyo DP26649 26 in. TV
Samsung 50'' Plasma TV won't turn on anymore
If your tv is within the one year warranty period then call 1-800-Samsung for warranty repair. Look at your tv purchase receipt for the Purchase Date. You have one year from the date of purchase to get warranty repair.
Jul 08, 2009 | Televison & Video
Where can I get a power cord for niko 26 inch?
95% of all LCD's use the standard PC or Monitor cord. Best Buy ect...
Feb 06, 2009 | Niko OTP-2613W 26 in. LCD Television
Shadows on screen
Try moving a medium powered magnet (not one for picking up heavy objects and not a refrigerator holding one) over the distorted area. If that doesn't work, try a more powerful one. This worked for my Toshiba LCD. Good luck!
Jan 04, 2009 | Sylvania 6626LCT 26 in. LCD Television
Protron PLTV-26 Television
Here is the number to Spectroniq, which is the manufactor of Protron, you should be able to purchase one from them directly.
1-877-778-8876
Aug 18, 2008 | Protron PLTV-26 26 in. HD-Ready LCD...
26 inch Samsung LCD TV
I would take advantage of the warranty before it runs out.  These things can be expensive to fix out of warranty.
Oct 19, 2007 | Televison & Video
Samsung LN26C450 26 in. TV Logo
158 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
