Question about SEH TECHNOLOGY InterCon IC105-FASTPOCKET-TX (0889418030225) Print Server
I have ic105 with used mutoh falcon jr printer. Is this compatible with Vista
How to reset drivers on mutoh sc 550
Have you checked it is not programmed in the metrics scale (cm) instead of the imperial (inch) scale.
Maintenance manual is available at this site
http://83.145.206.11/profiles/Ohjekirjat/Mutoh/SC/Mutoh%20SC%20manual.pdf
Check the Power on instructions on page 31 of user manual.
http://83.145.206.11/profiles/Ohjekirjat/Mutoh/SC/Sc_manuaali.pdf
Sep 16, 2014 | Office Equipment & Supplies
I am trying to install falcon 4.0 on my computer. I can get through the install and everything is fine, but when I open the program a window pops up saying that I have to use a file on the disk. I browse...
What is the operating system you are using. If it is windows vista or 7 you will need to right click on the set-up and select trouble-shoot compatibility. set it to windows XP compatibility.
Mar 02, 2011 | Infogrames Falcon 4.0 for Windows
WINDOWS 7 COMPATIBLE?
Yes, just use Windows 7 Update function to install proper drivers automatically. The drivers provided by Brother on CD do not work, though.
Feb 06, 2010 | Brother MFC 420CN All-In-One InkJet...
Epson Stylus Pro 9600 vs Agfa Sherpa44
The Agfa Sherpa is not manufactured by Epson. Both Epson and Agfa buy and retag their printers from Mutoh.
I do not know if the 44 is the same as Epson 7600 or 9600, but it should fit the same cartridges.
If the printer does not accept the cartridges, that means that there is something different in the software stored in the Epson cartridge chip.
In this case you will be only able to use only Agfa or Mutoh Falcon cartridges.
Oct 27, 2008 | Epson Stylus Pro 9600 InkJet Printer
Cannot install printer in windows vista.
Is your printer Vista compatible?
Did you have been installed in correct way your printer?
If this it is a driver issue, try to find the right drivers for your printer (must be compatible with Vista)
Go to the website of your printer manufacturer >> www.yourprinterbrand.com >> then go to Support >> Software and drivers
And download the driver there
If your printer is not Vista compatible at this point:
1) is better to get a new printer compatible with Vista
or
2) Downgrade your OS to one compatible with your printer.
Let me know how your issue it is going....
This will fix your problem.
Don't forget to rate my help! :-)
Thank you for using FIXYA!
Pablo
Oct 16, 2008 | HP PhotoSmart C4180 All-in-One Color...
Driver
Taka9}I{e xyema, rge 6JI9gb gocmamb eToT e6y4uu' gpau'Bep!? cykuHax
Sep 09, 2008 | Office Equipment & Supplies
SEH TECHNOLOGY InterCon  IC105-FASTPOCKET-TX (0889418030225) Print Server Logo
70 people viewed this question
Top SEH TECHNOLOGY Computers & Internet Experts
David Payne
David Payne
Are you a SEH TECHNOLOGY Computer and Internet Expert? Answer questions, earn points and help others
