Thanks for your advice! I sorted it out today thanks to you :)
    Genius:
  • 1,027 Answers
Glad you were able to fix it.
Posted on Jun 17, 2008
Help SLV-900 has a screen that randomly flickers and wont play
Advice given has helped me to sort out this problem thanks
Mar 07, 2010 | Sony SLV-D100 DVD Player/VCR
Tip
Great advice. I was able to replace my dog ears today with your help. Mine was a...
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
  1. Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
  2. If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
  3. Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
  4. Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
  5. Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
  6. With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
  7. With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
  8. Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
  9. Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
  10. Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary. If you get confused and require further assistance, please refer to my profile at http://www.fixya.com/users/jsrock516 and use the “Ask Me” feature. For excellent diagrams to assist in reassembly you can also refer to the searspartsdirect.com website. Just type in your COMPLETE washer model number and look under the Agitator Parts heading. I hope this information is found to be helpful.
on Aug 12, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
JVC AV-56WP74 Colors quit working or went out of balance.
Guns or CRT are probably ok. Your TV needs a convergence IC STK392-120 replacement. Lamp are used on LCD and DLP rear projection TV's. Color wheel are for DLP's. :)
Dec 26, 2009 | JVC Televison & Video
TACHOMETER WIRE?
You can use the blue wire from the distributor plug. Conatct i fyou need more help thanks for using FIX YA
Jun 17, 2009 | 1997 Honda Accord
All buttons suddenlly stopped work correctly.
must be check if it exposed to any sort of liquid and if not remove the memory card and try to do software
May 11, 2009 | Nokia 6500 Slide Cellular Phone
HELLO PRINTING FADES RIGHT HAND SIDE OF DOC ANY ADVICE ,THANKS IN
Hello I have sorted the growling sound out with a shot of WD40 lube ,but have not sorted out wht the cyan does not print clearly any advice would be helpfull
Nov 14, 2008 | Epson AcuLaser C900 Printer
Camcorder hitachi dz-mv100e
Yes you can still post there im you still have problem.... there's a lot of experts here to help you.. just do what have you done ealier when you post your concern.......
Jul 02, 2008 | Cameras
Got a marantz 2220B Stereo Receiver. Everything works but getting some unwanted static after the unit has been on for an hour or so. Any ideas? THanks
Hi mdpagan
There are lots of mechanical switch contacts to these old girls. Go about wriggling and tweaking with all the controls and switches on the amp. You may find one of these to be the source of static. These sorts of problems can be sorted out with a squirt of CRC2-26 into the switch or control that is noisy. If it is not this, it may have a leaky capacitor or noisy transistor. the mains switch can produce strange static also when they get a little tired.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, then before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Jun 11, 2008 | Marantz Audio Players & Recorders
Thanks! just one last question..
It could be that the software somehow recovered itself. I am glad to hear that it works now.
Apr 29, 2008 | Sony Ericsson K750i Cellular Phone
Laptop / AC Adapter Problem
It maybe the problem of your laptop ac adapter,find a new universal laptop ac adapter to have a try.
Sep 14, 2005 | Fujitsu Siemens Loox 710 Pocket PC
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
