Question about Husqvarna Chain Saw Maintenance Kit 357xp 359
357xp 359 After 15 to 30 min. of cutting engine gets extremly hot and cuts off. Checked spark plug,air filter, and made sure all cooling system components are cleaned. I was told it may be the ignition coil,if so where is it located? I appreciate any info.
  • 7,733 Answers
The ignition coil is attached to the spark plug cable.Also check the spark plug number for the chain model.As the chain get older you can put a cooler spark plug and try before change the coil.
Posted on Nov 09, 2010
Cuts out randomly, starts again ok,rides ok,done spark plug air filter,emptied tank. wot now,is there a solenoid or something?
when it cuts off I would pull spark plug wire and crank and see if it is getting fire at the time it has cut off, if its not sparking the coil is probably getting hot and cutting out. if it is getting fire I would remove the bowl of the carburetor and clean with a wire brush and carb cleaner.. I would make sure the float is moving up and down freely, lastly I would check to make sure the air vent on the fuel system is not blocked. if you continue to have problems after checking those things.. please contact me as I would like to help you get your bike running!
Sep 28, 2015 | 2004 kawasaki Super Sherpa
My twin impeller 6.5 Honda starts but cuts out after 10 mins. Then it is very hard to start and then cuts out again after 10 mins. The oil level is good and it has fresh fuel
have you checked the condition of the spark plug , these engines are pretty straight forward so has very little to go wrong , also check the air intake for any sort of blockage and check if there is a fuel filter , is there a manual choke ? if so this may need attention , hope this helps ( i'm presuming it's petrol and not diesel)
Feb 23, 2015 | Honda Cars & Trucks
2000 katana runs for 5 min then cuts off I've cleaned carbs replace gas filter checked the peacock filter idk lost on y it keeps stalling out
I had a similar with my Suzuki....turned out to be the coil, it would get hot and the spark would fade and eventually the engine would die and wouldnt restart till it cooled off...Good luck with it!!
Apr 09, 2014 | 2000 Suzuki GSX 600 F (Katana)
We have a Subaru Legacy GT, Twin Turbo 93, the car cut out and will not start, no fault codes, replaced spark plugs, fuel filter, checked the fuel pump, replaced air flow meter, engine temperature sensor,...
sounds like your timing may be off, or have a crank shaft postion sensor failing, when it cuts are you losing spark completely? do you have a fuel pressue gauge? whats the pressure? also you could try running it with the map sensor unplugged and see if the condition improves
Jul 31, 2011 | 1993 Subaru Legacy
I have a 18" Craftsman gas chain saw. It will not keep running, after two or three cuts it just stops and cannot be started again until it sits for 15 to 20 minutes. I have cleaned the air filter and...
Try removing the fuel cap for a moment, then try restart. If ok, check the fuel vent for plugging. Check the fuel filter for plugging. Inspect the fuel lines for decay or other damage. Check for spark when it stops--it may be the ignition module failing when hot. Check for sawdust and dirt plugging the ventilation system--blow it out with compressed air. Does the engine 4-stroke at speed when not cutting, but does 2-stroke when cutting? Make sure the chain is being oiled while running. Hope this helps!
Jul 13, 2010 | Craftsman 18" Chain Saw Replacement Bar...
Motor runs for 5-10 min. then starts missing and quits.
Check your spark first,if you do not have spark your problem is the coils-if you do have spark the problem probaly lies withone of your valves getting stuck after getting hot and soonas it cools down a little it closes and then you can restart it till it gets hot again.Hope this helps
Jul 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
1990 Buick LeSabre cutting off, getting no spark, 30 mins starts
Replace crank sensor. Next time it cuts off pour or spray water on it, to cool it down and if car starts that is what it is. I did this to get my car home to fix it. Next thing I would look at is the coil module if crank sensor does not fix it.
Dec 21, 2008 | 1990 Buick LeSabre
Husqvarna Chain Saw Maintenance Kit 357xp  359 Logo
270 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
