Question about Miele 36 in. KM342 Gas Cooktop
Need replacement grates for miele km342 gas cooktop where can I buy grates and stainless steel knobs
4 Suggested Answers
SOURCE: 1 burner wont stop clicking on miele cooktop km 344
usually due to the ignition unit being faulty. being miele, the part will be pricey. another solution is to take out the ignition unit and take it into a local electrical repair outfit and see if it can be matched up with one from a different make. to check if this is the problem, interchange two electrode leads on the ignition unit and see if fault changers to another burner. you sometimes find that there is a spare ignition outlet on the ignition unit and this can be used as an alternative
Posted on May 06, 2007
SOURCE: miele gas cooktop flame shuts off after lighting.
I had similar problem.Solved by Miele tech by placing rice grain sized wad of paper towel inside knob so it sits slightly higher on the valve shaft.
Posted on Oct 28, 2009
Joe Onley
  • 363 Answers
SOURCE: My Miele KM342 cooktop has
Have you tried to just move the knob away from the 'Start" position. this sounds like the ignitor is still engaged. Aside from that, I'm not sure of a solution.
Posted on Aug 29, 2011
Knobs melted when simmer pot was used....where to get replacements
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommendhttp://ping.fm/zJDAM
heatman101
Sep 06, 2011 | Miele 36 in. KM342 Gas Cooktop
My Miele KM342 cooktop has one burner that keeps clicking when on, regardless if the other burners are on or not. This is annoying when cooking. Can it be fixed.
Aug 29, 2011 | Miele 36 in. KM342 Gas Cooktop
All the knobs have cracked stems. I need replacement parts.
My knobs did the same _ if you want to avoid expensive replacements (mine were going to be $125) get some small good quality zap straps and tighten 2-3 around the stem. For added strength you could add some apoxy but i found it was not necessary. Good Luck!
Aug 06, 2011 | Miele 36 in. KM342 Gas Cooktop
Hi I have a Miele KM32G that keep clicking on some burners. can you help
Hi jennifer20,
I believe those ignition switches have come in to contact with either water or moisture.
Please read my below Tip on how to fix the problem:
GAS KITCHEN APPLIANCE CLICKING SOUND...
If it does not solve your problem, I'd suggest replacing the ignition switches.
Kind Regards
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 27, 2011 | Miele 36 in. KM342 Gas Cooktop
Miele KM 342 - I have burner - will ignite when knob pushed in but once release knob flame goes out
Hi dear.According to you're explanation,there is flame failure safety device in each hob.Please check the hob,there is one ignition plug & one prob next to each other.Please clean them up with hard brush to get rid of the cleaning chemicals(Like: CIF)residue.It's a sensitive prob becareful when you do this.Please make sure it sees the flame.As long as it feels the heat it'll let hob to run.If that's not work,you may need to change it.Please do this if you know what you're doing,other wise call service department.I hope that helps.Thanks.
Aug 07, 2010 | Miele 36 in. KM342 Gas Cooktop
Electric ignitors clicking
I'm sorry that I don't have a solution for you, but my Miele gas stove does the same thing. I had a repairman come out while it was under warrantee and they fixed it, but it was only temporary. It's doing it again, but, of course, it's no longer under warantee and will be very expensive to have Miele come out again. I've found that it's the right front burner that causes the clicking, so I've just stopped using it.
Apr 18, 2010 | Miele 36 in. KM342 Gas Cooktop
Piezo igniter keeps clickingeven afte burner is lit
the ignitor on my Miele gas cooktop keeps clicking without me touching it,how do I stop it?
Mar 21, 2010 | Miele 36 in. KM342 Gas Cooktop
Gas cooktops
Go for ease of cleaning. Avoid any light colors expecially the grates. White cooktop, light grey grates, AWFUL I replaced it within 6 months. Stainless or black is fine, very easy to clean. Make sure the drip area can contain a spill . Another importent thing, If you can see it connected, turn the flame down as much as possible and see if it stays lit. Pusling and relighting is a plus some higher end units do this. It is very hard to get a true low flame on a high BTU unit. Another big plus. See if the grates are arranged so you can slide a pan over without lifting. This seems a minor point but what a luxury.
Jun 12, 2008 | WindCrest 35 in. CTG365D Stainless Steel...
Miele 36 in. KM342 Gas Cooktop Logo
85 people viewed this question
Top Miele Cooktops Experts
Dan Webster
Dan Webster
Are you a Miele Cooktop Expert? Answer questions, earn points and help others
