Question about Cameras
How is this hooked up between a VCR and DVD recorder and what are the best settings for it. My object is to copy my VCR tapes over to dvds. What cables will be needed. There is no available users manual for purchase or download.
  • Sandy Chamberlain
    Sandy Chamberlain Nov 08, 2010
    There is a misunderstanding. This is a pro unit connected between the VCR and DVD recorder. They are up to date units. (total 3 separate units)The connection problem is with the Sony MPU-F100. I guess I should have put that in the body of the letter and not rely on the title coming through.
  • Sandy Chamberlain
    Sandy Chamberlain Nov 11, 2010
    I am trying to hook up three components together. 1)VCR 2)SONY MPU-F100 Trans-coder 3)DVD recorder. In that order. There is no user manual for the trans-coder and 10,000 buttons and switches. The object of this project is to move the VCR tapes onto a DVD. I do NOT want to connect the VCR and DVD recorder to each other. If you have the users manual that would be PERFECT.
  • 10,594 Answers
You need to plug RCA video cable in AV out of VCR jacks and AV In of dvd recorder to send VCR playback audio/video signal to dvd recorder to burn dvd disc.
What are the model numbers of VCR and DVD recorders so to find out its user manuals for you.
Thanks.
Posted on Nov 15, 2010
  • Shahid Electronics
    Shahid Electronics Nov 16, 2010
    I just saw these are professional equipments so I take back my suggestion, please reject my answer.
    Thanks.
  • 4,472 Answers
First off all I would need to know the make and model of the VCR and the DVD recorder you are using. Most likely the best way to do this is to output from your VCR to the inputs on the DVD recorder and that should be about all there is to it as far as connections go.
Thank you,
Lee
Posted on Nov 08, 2010
  • 12,061 Answers
Ok, doing this is quite easy really, for the simplest way here is what you need to do.
On the REAR of VCR, you will have a Yellow OUTPUT (Video) and a Red & White OUTPUT (Audio) Now, the OUTPUT from here goes Color to Color onto the DVD recorder's INPUT, again you will have Yellow, (Video) Red & White (Audio) simply hook up color to color.
These connection cables are called RCA Male Cables. and usually come as a "Set" with Color coded leads with Male Plugs on them.
After you are connected, basically you cue up your VCR Tape and DVR, press "Play" on VCR , and then, "Record" on the DVR, and that's basically all you need to do, when you have finished, you will need to "Finalise" your DVD so it can be used on "Other" players etc.
This will all be in your user manual for/or with your DVR. If you do not have a manual, you need to go to the manufacturers website and download a copy for reference.
Posted on Nov 09, 2010
Is it possible to copy video from a vhs to a dvd?
If the DVD drive is a recorder, yes. If it is a player only, no. If the tape is copy-protected, recording to a DVD recorder is not possible. Assuming the tapes are not copy-protected, and you are using a DVD recorder with the correct format DVDs (DVD-R for example), you shouldn't have any problems transferring old VHS tapes to DVD.
Jul 05, 2011 | GoVideo DVR4000 DVD Player/VCR
The manual for my DVD-V3500 says that you can't record from DVD to the VCR. But, can you record from the VCR to a DVD?
In short, no. Not with this unit on its own. No function for recording from or copying to DVDs exists with this brand/model.
A separate DVD recorder is required. I don't know of anyone who records DVDs to tape these days.
You are correct; the manual states clearly you cannot record from the DVD deck in this machine, which is a bit unusual, considering other brands of combos such as LG, SONY and PANASONIC offered an input (which was between channels or could be selected via remote) to allow DVD to VHS recording within the one unit.
I would presume you can connect this combo to the input of a DVD recorder, play a videotape and it will work via cables. DVDs last longer than tapes anyway.
Feb 03, 2011 | Samsung DVD-V3500 DVD Player/VCR
This morning while trying to copy from vhs to dvd I kept getting an on screen message OTR Pause....record. What is OTR as the tape did not copy this is model DRC832ON
OTR is one-touch recording on most of my VCR/DVD burners where you set the length of time to record from the tv. In my manual it is the Express Record feature. Press the REC button several times to advance the record time by 30 minutes. In your case it might refer to On Timed Record.
Use the COPY button on the front of the unit when the tape you want to record is in the VCR and a blank DVD is in the DVD tray. If you have the A/B Edits set, only the A/B editted sections will copy. (Copy protected tapes and DVDs can't be copied.) (Or the timed transfer described below)
Copying DVDs to VCR tapes can be done in a timed record mode. You can either use Menu > Disc > Copy Disc then press OK or Menu > Timers > Set Transfer and press OK. Then press Info to name the timed event followed by Done and OK, if desired. Press OK to highlight Copy From/To and make sure to select the correct source and destination and press OK. Next set the day and time that you want the transfer to take place (a couple of steps, press OK between them and when done). Then adjust the quality if needed and press OK. Finally highlight Keep Timer and press OK again. Make sure the correct tape and DVD are in place for the timed event.
Depending on what you set the unit for, I'd look for signs of power failures (which mess up most timed record functions). Then I'd double-check the time you set it to transfer and the A/B edits function. (A/B edits lets you grab small clips from an Indexed tape. Either index the tape by playing it and pressing the Insert A/B edit button (on the VCR/DVD, possibly on the remote) or delete A/B edits.)
I hope this helps.
Jul 23, 2010 | RCA DRC8300N DVD Recorder/VCR
Toshiba DVR620KU error E 25 cannot put VHS onto DVDs
Probably copy protection.
You can remove it with a Grex or similar
device.
Jan 08, 2010 | Toshiba DVR620 DVD Recorder/VCR
How do I hook up my vcr to my dvd recorder so I
You will need one RCA video cable it will have a yellow, red and white plugs. On the back of your VCR locate where the color inputs are find where it says VIDEO OUT hook it up there. On the back of the DVD Recorder look for the same color input jacks NOW find where it says VIDEO IN hook it up there. You may have to turn on your TV,DVD recorder and VCR to get the right channel. your Recorder may have one or more video inputs if it does turn on all three. Use the channel on your TV you use to watch DVDs make sure you see your DVD screen. Now to record to a DVD. Change the channel on the DVD Recorder. Look for the input channels It may be Video 1 Video 2 etc... depends on the inputs you have. ( A great way to tune your DVD Recorder is to play a prerorded VCR tape. Turn the channel on your DVD Recorder unil you see the prereorded tape playing. )
Jul 21, 2009 | Toshiba Audio Players & Recorders
When I try dubbing from VCR to DVD the machine will only record about half of the VHS to the DVD. I get the following message...Recording Error - this program is not allowed to be recorded. The cause...
The DVD AGG (automatic gain control) is somehow being fooled into thinking the non-commercial tape has macrovision (copy protection). Is this a relatively inexpensive machine?
Mar 08, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
How do i hook up dvd recorder/vcr to my tv?
Hello.
If its a combined dvd/vcr unit you should be able to record on the dvd input from the vcr with a 3 split cord connected as described below..
VCR -
Video output - yellow.
Audio output - left and right - red & white.
DVD
Video input - yellow.
Audio input - left and right - red & white.
Or you might have to use a standared RF cable from the
antenna out on the video to the antenna in on the DVD.
Additional information....
Just as you can't copy commercially made video tapes to another VCR due to Macrovision anti-copy encoding, the same applies to making copies to DVD. DVD recorders cannot bypass the anti-copy signal on commercial VHS tapes or DVDs. If a DVD recorder detects the anti-copy encoding on a commercial DVD it will not start the recording and display some sort of message either on screen or on its LED front panel display that it detects the anti-copy code or that it is detecting an unusable signal.
A DVD recorder can be used to copy any homemade videos, such as camcorder videos and videos made from TV shows, and can also copy Laserdiscs, and other non-copyprotected video material. Also, remember that a DVD recorder also has a built-tuner for recording TV programming directly. The tuner can be programmed to record a series of programs on different days and times, much like a VCR. However, if you are recording a non-copy protected DVD to a DVD recorder you can record any of the video content, provided you click on the menu and start the video segments running and you have enough time space on the disc. DVD recorders function like VCRs in that they can record incoming video signals -- however, they do not automatically copy all the contents of the DVD - for instance, you cannot copy the interactive menu functions of a non-copy protected commercial DVD. A DVD recorder creates its own menu functions, it will not duplicate the function menu from a another DVD.
Hope this will help you.
/Tech5508
Feb 13, 2009 | Toshiba DVR610 DVD Recorder/VCR
I have a V3650 DVD Player, can i copy my old VCR tapes to DVDs ?
this player will not record copy garded material (this will not work! and yws the life of a VHS Tape is only about 15 years!
Dec 09, 2008 | Samsung DVD-V3650 DVD Player/VCR
Pioneer dvr 225 recorder
the dvd recorder has to be set to monitor the program your watching! you can not copy vhs tapes to dvd this way because the tapes that are prerecorded have a copy protect feature and will nut copy right!
Dec 15, 2007 | Pioneer DVR-225 DVD Recorder
HELP! I can't figure out how to Connect my Sylvania DVD/VCR Combo to my older TV
Even if you do get it connected you cannot copy from vhs to dvd as you have bought a vcr recorder with dvd player, not a dvd recorder. You can only record to the vcr tape from a dvd, in the players controls.
Feb 08, 2007 | Sylvania (SRDD495) DVD Player/VCR
Cameras Logo
62 people viewed this question
Top Cameras Experts
Steve
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
