Question about Rival 38601 Smart Pot 6-Quart
When cooking, the condensation builds up on the lip of the pot and eventually water spills out between the lid and the pot.
5 Suggested Answers
SOURCE: LId to 6 quart crock pot shattered
I have a 5-quart crockpot that cracked across the bottom. I've been using the crockpot liners, and they seem to work very well. No leaks, etc., and food seems to cook just as well as before the crockpot cracked. The liners sure do make cleaning up a lot easier, too!
Posted on Jan 04, 2008
  • 52 Answers
SOURCE: Plastic lid lets steam escape - is this normal? will it effect cooking?
This site sells replacement rival lids. They have plastic and glass ones. I would suggest you measure you old one and order a new one in glass. The added weight of the glass should cure your problems. Thanks Kevin PS if this helped you pls leave feedback. Link is below just cut and past into your browser.
http://www.marbeck.com/crock_parts_rival.html
Posted on Jan 30, 2008
clyde2j2
  • 137 Answers
SOURCE: Where can I get replacement lid for Cook's 7 qt. oval crock pot?
"Google" the following "replacement lids for slow cookers" and you will get dozens of sites.
Posted on Feb 28, 2009
clyde2j2
  • 137 Answers
SOURCE: need replacement lid for Cook's 7 qt. oval crock pot.
"Google" the following "glass covers for my slow cooker" and you will get dozens of leads.
Oval lid, what is the correct fit, should it be a tight fit, or my just sits on top, there is a small space around.
You should have a fit that has a little wiggle room, including a little space around the edge of the lid. When you cook in a slow cooker, you'll make a bit of steam, and it needs room to escape. A super tight lid would likely end up 'burping', and possibly spraying spurts of whatever your sauce is, across your kitchen. Having that small groove there also leaves you a space where a bit of steam can condense and either trickle back into the pot to keep things moist, or just sit there in the gap and not drip all over your counter. Having a little bit of give also means that if you cook and let things cool, the condensing steam won't create a partial vacuum and leave you having to plant a foot on the side of the crock pot to pull the lid off (likely with more spectacular spew-age ready for viral videos).
Cheers!
Nov 06, 2015 | Crock Pots & Slow Cookers
Should the lid be a tight fit or loose
Most crock pots are made of porous ceramic and is relatively brittle. It is glazed on all sides (except the bottom usually), to make it hold liquids without absorption. The lids, usually glass or thermoplastic, sit of top, but do not usually fit tightly as this could crack the crock. Also, it is not a pressure cooker, so you want excess steam to vent. The lid just keeps the heat inside and allows condensation to drip back into the crock, reducing the speed at which the fluids cook off, thus the term slow cooker.
Nov 06, 2015 | Hamilton Beach Crock Pots & Slow Cookers
Where can i find a manual for ultrex pressure cooker?
The company had a major recall and went out of business. No manuals appear to be available on the web.
Here are some general instructions you can use:
1 Set up your cooker. Place your Ultrex Pressure Cooker on the stove. Remove the lid and pour in no more than 2 inches of water. Depending on what you are cooking the amount of water will vary. More water will ultimately cook larger amounts of food, but you will need to refer to your specific model's instructions on this matter.
  • 2 Put in the food you wish to cook. Close and lock the lid firm to the pot. Make sure it is locked securely so none of contents boil out of the top.
  • 3 Turn on your burner to high heat for approximately ten minutes. Allow the water to boil.
  • 4 Turn the stove down to a low setting after the water is boiling in the cooker. Flip the pressure valve closed and allow your food to simmer.
  • Set the pressure valve to ten pounds. For vegetables, cook 30 to 45 minutes. For meats, cook 45 to 60 minutes.5
  • 6 Open the pressure valve and allow the pressure to discharge. Unlock and remove the lid to find your fully cooked meal.
  • Aug 25, 2014 | Ultrex Crock Pots & Slow Cookers
    How to use the slow cooker on the oval cooks essential pressure cooker
    I have a Tricity TSC09 6 litre Slow Cooker and I just love it its so handy, if your gone for even 10 hours it keeps your dinner warm after the cooking time runs out. I smashed the lid and was so gutted I tried for hours online to find a replacement lid with no luck. I went shopping and bought a very cheap 6 to 7 Quart or 6 to 6.5 litre Slow cooker / Crock pot of the same shape the removable pot and lid fit. I bought a cookworks, signature, 24 euro 6.5 litre oval dog standard slow cooker and the lid fit, now I also have a removable pot replacement as well just in case I smash that too. So happy I have my Slow cooker back again.
    Dec 05, 2013 | Deni Cooks Essentials 5qt Oval Pressure...
    Defective part
    To better address the problem with your nonstick pot... I need more information on the steps you have used to clean the pot and the extent of damage to the pot itself.
    You indicated that the damage has occured between the pot and the inner surface of the cooker base? Is this a corrosive damage or a build up of material on the inner liner of the base?
    Often times a build up of 'hard water' minerals accumulates on the inner surface due to condensation and occasional overflows from the foods being cooked. They can appear to be a type of fungus or mold.
    Jan 04, 2009 | Crock Pots & Slow Cookers
    Rival Crockpot Model 6445 Lid
    You can replace the part, contact the following sellers :
    Hamilton Beach Pot Replacement Parts
    If you cannot find the part on the website, contact them here: Contact Us
    Jul 13, 2008 | Rival 6445 6.5-Quart
    Excess condensation that causes the lid to 'float'
    I use a small bungy cord to hold the lid down securely. Hook on it on one handle wrap it around the lid knob and attach to the other handle. This is also how I transport the Crock pot.
    Good luck.
    Apr 08, 2008 | Rival 6445 6.5-Quart
    Jan 30, 2008 | Rival 3100 3.5-Quart
    Crock pot use
    You should keep the lid on as much as possible. You are correct; once you open the lid, the liquid inside can quickly lose temperature at a rate of 10-15 degrees per minute.
    Additionally, taking the top off allows steam to escape, which reduces the point of cooking in a slow cooker (cooking in a relatively closed system, with the steam condensing back to water and flowing back into the broth).
    It's not doing a whole lot to the flavor (aside from causing the stew to thicken with the loss of water), but it is definitely causing the cooking to take longer than it should.
    Nov 02, 2007 | Rival 38601 Smart Pot 6-Quart
    Rival 38601 Smart Pot 6-Quart Logo
    136 people viewed this question
    Top Rival Crock Pots & Slow Cookers Experts
    Jerry Greenberg
    Jerry Greenberg
    charles
    Irene Tulloch
    Are you a Rival Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
