Question about Dell Dimension 4550 PC Desktop
I received a dead Dell Dimension 4550 from a neighbor and when powered up, is showing green A & B and yellow C & D diagnostic lights. What is the problem?
  • lorne_kimmel Nov 08, 2010
    It won't even boot to BIOS or display the Dell splash screen.
  • Dell Master
  • 6,487 Answers
When those 4 lights are all solid green it means that computer has power up fine and just cannot load the operating system , so what you can do here is to try reloading operating system on the computer and also see if there;s any display coming on its monitor and also listed for any beep code.
This documentation from DELL will be a big help in troubleshooting this computer, click HERE.
Posted on Nov 08, 2010
  • Mark Gil
    Mark Gil Nov 08, 2010
    OK thank you for the update, this computer can have a bad motherboard already, you can do the reset of jumper settings on the motherboard to clear cmos and by the way the steps can be located on the documentation site that I provided you earlier.
SATA on dell dimension 4550 with Debian
look in the devicemanager what does it say.
update thrue the deviemanager or search the internet
May 26, 2013 | Dell Dimension 4550 PC Desktop
Dimension 3100 wont turns no power button light there is also an green light on motherboard cpu and power suplly fans working but wont bot up
Contact technical assistance.They will most likely ask you to send it back to repair.
This chart is where I got my conclusion.
Power Light
Problem Description
Suggested Resolution
Solid green
Power is on, and the computer is operating normally. On the desktop computer, a solid green light indicates a network connection.
No corrective action is required.
Blinking green
The computer is in the suspended state (Microsoft® Windows® 2000 and Windows XP).
Press the power button, move the mouse, or press a key on the keyboard to wake the computer.
Blinks green several times and then turns off
A configuration error exists.
Check the diagnostic lights to see if the specific problem is identified.
Solid yellow
The Dell Diagnostics is running a test, or a device on the system board may be faulty or incorrectly installed.
If the Dell Diagnostics is running, allow the testing to complete.
If the computer does not boot, contact Dell for technical assistance.
Blinking yellow
A power supply or system board failure has occurred.
Solid green and a beep code during POST
A problem was detected while the BIOS was executing.
See "Beep Codes" for instructions on diagnosing the beep code. Also, check the diagnostic lights to see if the specific problem is identified.
Solid green power light and no beep code and no video during POST
The monitor or the graphics card may be faulty or incorrectly installed.
Check the diagnostic lights to see if the specific problem is identified. See "Video and Monitor Problems" in your Owner's Manual.
Solid green power light and no beep code but the computer locks up during POST
An integrated system board device may be faulty.
Check the diagnostic lights to see if the specific problem is identified. If the problem is not identified, contact Dell for technical assistance.
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
Dimension 4400 Power Supply ** FREE ** (DE4400300WB) Power Supply: My Dell Dimension 4400 is dead with none of the 4 ...
It seems like it that you have a faulty power supply. Also the motherboard may be damged aswell, But most probably you can fix your PC by changing the power supply.
May 16, 2010 | Dell Dimension 4400 Power Supply ** FREE...
Dimension 4550 CN 02U819 power supply works but
many dells take proprietary power supplies. if you are using an aftermarket power supply, then you may have burned out your mobo. irregardless, your mobo may be dead, and that mey be the very problem.
Jun 08, 2009 | Dell (E210882) Motherboard
I have a Dell Dimension 4600 and it won't boot up. When I turn it on the green power light comes on and hard drive activity light flashes however no fans come on, the screen doesn't show the Dell logo or...
i would have to disagree with jerry, while that seems reasonable if the motherboard fan isn't running at all then whether or not the video card is ok is somewhat irrelevant.
I would agree somewhat though, i think the PSU might be a good thing to check to see if it is functional.
when you power it on does the CPU fan start or shudder at least ? that would be my first guess for a problem if you had been having any problems recently
Apr 17, 2009 | Dell Dimension 4600 PC Desktop
Dell dimensio 4550
you need to replace your motherboard. contact vendor
Dec 15, 2008 | Dell Dimension 4550 PC Desktop
Dell Dimension 8300 flashing amber power light and dead pc
it seems *********** board is having problem plz send it for servicing
Aug 08, 2008 | Dell Dimension 8300 PC Desktop
No power to my dell dimension 4550
It might be a couple of things bad powersupply or power button incorrect ram module or hard drive settings ,if not then lastly have a bad motherboard which we all hate. you said you have a a green light on motherboard? Did you upgrade or install any new ram ,harddrives etc check make sure they are seated properly in their sockets and free from dust check connection on the ram module make sure it shinny brass color if not you can use an eraser to clean them. If you have upgraded check make sure the ram is compatible to your machine sometimes the wrong ram install can cause no power up problem. Do you have four green lights in the back of machine? Dell new desktop has 4 green light in back of the unit . if all four light are green then system is ok but one out of the four light are orange then you have a problem. You can go onto dell web sight for your machine to check out these lights codes. I hope this help you out some.
Feb 12, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 4550 PC Desktop Logo
82 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
