Question about Dishwashers
I just had a new Frigidaire dishwasher put into our apt. The machine works fine but the water is not draining out at the end of the cycle and the dishes still feel soapy . What is the problem this is a brand new dishwasher .
  • 126 Answers
You may want to have a qualified person (plumber) check the drain hookup.
Posted on Nov 08, 2010
I have a Frigidaire dishwasher model number FGBD2431KF purchased around 2009. Water is not pumping out.
Sc. Check the drain valve, remove the pump and test it. If it is not the pump then probably a relay or switch. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Dishwasher Diagnostic Repair Not draining Frigidaire Electrolux...
Dishwasher Not Draining Dishwasher Drain Pump Replacement Part 5304463777
Frigidaire Dishwasher Not Draining
http://www.partselect.com/Repair/Dishwasher/Not-Draining
May 08, 2016 | Frigidaire Washing Machines
Frigidaire dishwasher model # fphd2491kfo has standing water in bottom after the wash cycle is complete
it could be a clogged pump its self,maybe a peice of food or a skin off some thing is hanging up at the last cycle
Apr 22, 2017 | Frigidaire Dishwashers
MY FRIGIDAIRE DISHWASHER WILL NOT DRAIN. MOTOR ONLY HUMS DURING DRAIN CYCLE. OTHER THAN DRAINING IT SEEMS TO WORK FINE. DAY IT QUITE WORKING SINK BACKED UP AND WOULD NOT DRAIN
if there is still water in the dishwasher take the drain hose off from under the sink and use a large pot or mop bucket and but the unit into a drain mode usually by cancelling the wash cycle if the unit still does not drain.Then use a wet dry shop vac and attach it to the end of the drain hose to remove the water
after the water is gone check the drain pump for any kind of obstructions you may need to replace the drain pump
Jun 06, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
I have a Frigidaire dishwasher that is not workin...
Remove the drain end. Keep it above little . Check whether the water is retained inside the washing machine. If water is retained- check your drain valve in the machine. it is parmenantly open or having improper closure.
May 21, 2010 | Frigidaire 24 in. FDB510LC Free-standing...
Dishwasher--water in bottom -end of cycle.
You may need to tip the dishwasher forward, use a towel as water will get every where otherwise. once drained put it through another cycle. this should reset the drainage level. hope this works as it has for ours, bye
Jan 12, 2008 | Frigidaire 24 in. PLD2850 Built-in...
Water not draining out after wash cycle
frigidaire dishwasher model#MDR251RER0/serial#TH84453602 not completely draining. I hear when it the drain cycle begins but does not empty completely out.
Jan 05, 2008 | Frigidaire 24 in. GLD2150RCC Built-in...
Dishasher does not drain
If it gravity drains, but the pump does not push out the water.......replace the drain pump. I just repaired an 8-year-old  Frigidaire dishwasher with this very problem, and although it sounded like the pump was operating, it was not....it was just vibrating. I replaced the drain pump and it now works perfectly. I am a service tech with 38 years experience.
Jun 21, 2007 | Frigidaire 24 in. FDB635RF Built-in...
Dishwasher won't drain all the way
After cleaning the air gap thingy my machine works fine again. This thing sits on the left lower back side of the machine (left when you are standing in front of the machine). It is a transparent plastic box with 3 hoses attached (drain hose from pump, drain hose to the outside and water). Inside the box is a black plastic float. If debris gets caught in there the float gets stuck.
Solution is to remove the part by pulling the 2 drain hoses out (there is a small black clip holding them in) and unclamp and remove the water hose. Rinse and shake the housing until the float moves freely again and reassemble.
Jul 31, 2006 | Siemens 24 in. SL84A305UC Built-in...
Dishwashers Logo
46 people viewed this question
Top Dishwashers Experts
Mike
Marvin
Marvin
