Question about Candy CPCA250K Bottom Freezer Refrigerator
The unit has stopped refrigerating and the frezzer has defrosted. Power is still getting to the unit as the fridge light still works.
Issue with Kenmore Refrigerator/Freezer
ok,1st check on fridge side toward upper back of the top and feel for air coming thru, and there is another one down possibly behind crisper .I had this same deal. Had to do total defrost,, put food in cooler,, theres two blower fans in these types of fridges,,one in the bottom back,, and one in the back of the frezzer,, I used an old hair dryer and let it blow warm to top interior of frezzer,, careful not to let any cords hang/drop in any water!!,ok once done dry out as much water as possible, turn fridge on set both controls to 4,when fridge kicks on do the feel test,, you may need to close the frezzer door, air should be felt near top inside of fridge,if so than shut fridge side and feel inside frezzer near bottom and air should be felt,, side-by-side need to circulate air from frezzer to fridge, then back to frezzer
Jan 23, 2013 | Refrigerators
Hi,i have fisher pakel E522B with frezzer on the bottom the fridge goes warm and the frezzer section is all iced up.pulled back cover of frezzer off and removed fan,tested fan across 5v ph charger fan...
HI,CHECK FOR CONTINUITY ON THE DEFROST ELEMENT AND B-METAL IF THOSE COMPONENTS PASS THE TEST MAYBE THE TIMER OR DEFROST CONTROL COULD BE BAD IN YOUR REFRIGERATOR..GOOD LUCK..
Jul 04, 2011 | Fisher and Paykel Active Smart E522B...
My KBRA20ELSS 01 Kitchenaid-mount refrigerator has stopped working. I opened the freezer tonight and the ice had all melted and the food is defrosted! I don't think the refrigerator is cooling either. ...
if both the fridge and frezzer are not working then it can only be one of two things the thermistate has blown or the motor has stopped working start by having the thermistate checked
best of luck
please remember to rank my reply
Dec 01, 2010 | KitchenAid Refrigerators
Fridge has stopped working frezzer works ok
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 01, 2010 | Refrigerators
Our frezzer is working fine but the fridge isnt
the return air ducts are frozen, not allowing cool air up to the fridge
unplug unit overnight and let defrost,you can speed up the defrost time by using a blowdryer in the freezer compartment
Jan 16, 2010 | Samsung Refrigerators
Freezer works fridge doesnt?
most likely defrost problem . most refrigerators getting their cold air from the freezer, so if your frezzer frost up, no air gets to fridge side, u have to remove the frezzer panel and inspect the evaporator coil, if frosty, u have bad defrost system, which part is bad? depends on the brand and model.
Oct 31, 2009 | Dometic RM2852 Refrigerator
FRIDGE STAYING AROUND 25 DEGREES
you have a gas leak , a refrigeration mechanic is required.
May 10, 2009 | Admiral 26 cu. ft. Side-By-Side...
DRAIN BLOCKED WITH ICE
It sounds like you need to install a drain heater. Sometimes these are available as a kit from a parts dealer, and sometimes you can just take a piece of bare solid copper or aluminium wire and put it a little ways down the drain, then wrap the other end around the defrost heater, so that when the fridge goes into self defrost, it keeps the drain warm so it does not freeze. The better way to do this repair though is to see if a drain heater is available for you model as a direct fit part. The other way is only to be used as a last resort. Good Luck!
Oct 10, 2006 | Samsung SRS20DTD Side by Side Refrigerator
Candy CPCA250K Bottom Freezer Refrigerator Logo
23 people viewed this question
Top Candy Refrigerators Experts
Charles T Nevin
Charles T Nevin
Cesar Quant
Cesar Quant
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
