Bt hub 2.0, the internet light is red, but the telephone line works, although it's very noisy/crackly. have changed the micro filters but still cannot connect to the internet.
    Scholar:
  • 97 Answers
It sounds like you have a fault on your phone line which is affecting the performance of your broadband.
As long as you haven't added any more phones to your house without a splitter, then I would go with the problem being your phone line.
You might want to give BT Broadband (assuming you have BT broadband with the BT Hub) on 0800 111 4567 they will be able to advise you further, failing that, you may need to log a call with BT about the phone line itself, which is just 151 from the line that you are having problems with. It is always best to phone from the line that you are having problems with, so they can hear that there are problems with the line.
Hope that this information helps! :)
Posted on Nov 08, 2010
Btinternet home hubsExisting home hub lights flash every time the telephone is used. Line has been checked by BT engineers and is not faulty
This could be the issue, but i suggest you ask a friend if you can borrow a modem before you go buying a new one.
Feb 10, 2013 | Computers & Internet
Telecom Issue, when a Netgear router (DG834G) linked to a small server unit, dissconnects the telephone line. The router works fine but no dial tone on the phone side of the micro filter. Any assistan
a POTs (plain old telephone) line should never be connected to a router. that adsl filter does not make a phone line share a data line.
ADSL is a type of internet service supplied over a phone line. think of it as raw (unusable) when its on the phone line. then you use your dsl filter/splitter to feed the raw internet into a special dsl modem and the other port can be used by a standard phone.
you will know a dsl modem when you see it because its uplink or internet port will only be big enough to fit a phone cord into, not an internet cord. these dsl modems then feed usable internet to your routers and all devices on your network. but, like i said before, at this point it is too late for your phone and internet to share the same wire.
OK, thats not entirely true
pin out of RJ45 internet
1=orange/white *
2=orange *
3=green/white *
4=blue
5=blue/white
6=green *
7=brown/white
8=brown
1,2,3+6 are used in a typical network
if your network is typical you can "get fancy" and use 4,5,7+8 for telephone or even put 2 data lines on the same wire (not recommended for long distances). however, this may involve cutting some wires and splicing them together or something.
Sep 14, 2012 | NetGear Computers & Internet
My att 2 wire keeps flashing red on and off for dsl and then the green wireless light goes off and internet goes down. I get a msg that the broad band cannot connect. I have checked and double checked...
Hi
This is Neo . Check the Filters in the phone line if you have installed the filter . if there is no filters before the telephone , install a filter . Whether the phone line are connected properly and check the wall point where the connection from the DSL and telephones . Check the cords and try changing the RJ11 cords . RJ cors the phone thin cords .
NOTE : FILTERS SHOULD BE INSTALLED FOR TELEPHONES BUT NOT FOR 2 WIRE .
Nov 02, 2010 | 2wire 2700HG-B Router (2700HGB)
I use AOL as my ISP, with British Telecom supplying my telephone line rental. On Friday 2nd my internet connection kept dropping out, and then eventually stopped connecting altogether. My original router...
If BT tested the phone line is OK but did AOL test the connection to the Netgear router and get the IP address of your Netgear router.
The phone connection is OK but the ADSL connection from the telephone exchange may not be working, that is why you are not getting an ADSL light.
Jul 12, 2010 | NetGear DG834 Router
How do I access the internet using a BT home hub set up for wireless operation, without having to go through BTfon
Hi Graham
This should be fairly straight forward.
Your BT Home hub should be transmitting 2 signals. One called BTfon and another called something like BTHomeHub2-PGD3.
The second is what your computer should be connecting to to access the internet. If you look at the back of your home hub you will see 4 rows of numbers/text.
One should say SSID and have have the same ending as the transmitter that your computer should be seeing. Underneath that it should say WEP code or WPA. (or something similar) What follows is the password you need to enter to access that home hub's internet transmitter. The BTfon thing is for the telephone that comes with some versions of the hub - it's not for the computer.
Jun 13, 2010 | Computers & Internet
There is a fault in-house with my BT Inspiration Telephone system
Well BT is very simple it is just a pair of wires that all connections are in parallel, so what you need to do is check between BT jacks, look for disconnection &, shorts. use Cut and test method, IE: Go to each, BT, cut off any Going away, cables, temporarily, and test that line, if Ok, then connect up the Going Away cable and test again, go to next BT and do the same until you find your fault. ALL connections are on 2 & 5 in the BT jack. With the faulty section simply replace with any lightweight 2 corr cable and terminate on 2 % 5 in the BT jack,
May 19, 2010 | Inspiration 7.6 for PC, Mac
I had problems with my BT internet connection and when BT put it right the Hub reverted to the original pass code. I put the code in my Epson SX515W but it still will not connect although the 'wireless'...
It sounds like your hub password is set with the default password If you had changed your password then try opening your hub manager and make sure that it is the same as the default one .
Mar 30, 2010 | Epson Office Equipment & Supplies
Cannot use fax,telephone line error . telephone line plug into micro-filter,RJ11 plug into line socket of printer.does not dial out
try change micro-filter or connect directly to line socket, to test. And test with any usual telefone to line socket, if all above is not working, try call to your telefone provider to report a telefone line problem.
Jan 03, 2010 | Lexmark X5470 All-In-One InkJet Printer
BROADBAND INTERNET CONNECTION PROBLEM (WIRELESS)
Every phone socket must have a working microfilter pluged as shown on the image below.
I think you need to change your microfilters as they might have blown.
microfilter2.gif&usg=afqjcnewmdhgecg08egxbhumf4zmq8g-lq
Hope this helps,
Regards,
Abdul Qayyum
Nov 05, 2007 | NetGear DG834G 54 Mbps 802.11g Wireless...
Computers & Internet Logo
181 people viewed this question
David Payne
David Payne
