Question about HP PSC 1210 All-In-One InkJet Printer
Paper size problem
I have a lb1210 laser printer. But I cannot print A4 size paper. Please solute this problem.
  • 197 Answers
That's in the application settings, under paper selection or page..depends on what you're using.
Posted on Jun 16, 2008
Special paper tray is empty error
Sounds like someone requested A4 size paper in a print job instead of the normal Letter size paper...
Try putting regular letter size paper in the bypass tray and then set it up as A4 size...the print job should then print out on that paper.
Apr 09, 2014 | Xerox WorkCentre C2424DN All-In-One Laser...
Load mp feader a4
Please determine what size you are trying to print (A4, Letter, Legal, etc.). The printer is requesting A4 sized paper in the maunal paper feeder becuase either you selected manual feed or the setting for the default try (usually tray 1) is not set to the correct paper size. In your case, make sure the green slide adjustment on tray 1 is set to A4.
Mar 22, 2014 | Lexmark T632 Laser Printer
I defined the paper size A4 but Canon gives an error and ask me to use the current size. If I push yes it prints again
go to printers and faxes right click an d select printing preferences on 4350d and select paper as A4 . Press apply & ok. Now try printing on A4
Apr 10, 2011 | Canon ImageCLASS MF4350d Laser All-in-One ...
Paper out message, wanting A4 size
Hi rmfgco2009
A4 paper is 8.3"x11.7" OR 210x297
Letter size is 8.5"x11" OR 216x279
So your paper is called LETTER size not A4
What you have to do is;
  1. On the LCD display of the printer, through the SETUP, change the paper size from A4 to LETTER. Save the settings and Exit.
  2. Also, From the Control Panel, printers, properties, preferences, features change the paper size to LETTER. This step can be done from EXCEl also through the printer menu.
  3. You may need to Turn the printer off and on again.
Hope this will work for you. If this solution is helpful, please give a rating.
Have a Good Day
luciana44
Nov 30, 2009 | HP LaserJet 4 plus Printer
The print size for the paper is defaulting back to A4(97%) and I can't get it to stay on A4 (100%). Is there any way i can make this a new default.
This sounds like you are setting the size in the application rather than the printer system properties.
To set the system printer properties, Click on Start>Control Panel>Printers
Select the Kyocera >Properties
Set the desired paper size, click OK.
The paper size should remain as selected until you decide to change it again.
You will still be able to temporarily change the printer properties for the application job.
Please rate this solution. Thanks.
Nov 19, 2009 | Kyocera FS-5025N Laser Printer
Print legal size paper problem
when you give print command that time chage the paper size from a4 to legal in print proeprties and choose paper size legal.
Sep 08, 2009 | Canon LASER SHOT LBP-3000 Printer
Hi I have a Konica Minolta 2490MF and when I try to print a document/s it will print the first page only then comes up with an error 'incorrect paper size (1LT)' the paper size is correct (A4) and the...
Mr Stephen You have to check paper settings at 3 places first that you are putting correct paper size in correct tray and the paper supporter is touching the paper. Secondly your documents page setup paper size. Finally go to printer properties and under paper selection you will find letter size change it to a4 Thankyou for using free solutions at yafix-ratings from your side would be appriciated.
Jun 22, 2009 | Konica Minolta magicolor 2490MF Laser...
Printer will not print: Canon imageCLASS D320
The paper size selected in the menu system must match the paper size in the rec. (recording) paper tray. If you have 'letter' size paper in the tray and the menu system is set for 'A4' paper you will get this message. Either put A4 size paper in the tray, or change the paper size in the menu system to 'letter'.
Oct 15, 2008 | Canon imageCLASS D320 All-In-One Laser...
Error Message on Dell 5100cn
check the page setting in the printer as well as in the print dialog box in the, if the problem persists then you have to send it for servicing
Apr 29, 2008 | Dell 5100cn Laser Printer
Printer keeps saying change paper size
Go to Control Panel - Printers and on MF3310 right click and choose Default settings. I had to change page size from Letter to A4 and output size from Match page size to A4 as well. Finally, after 4 hours of investigations it worked.
Jan 30, 2007 | Canon MF3110 All-In-One Laser Printer
HP PSC 1210 All-In-One InkJet Printer Logo
29 people viewed this question
Seeker5211
Seeker5211
