Question about Star DCLCD DCL7A 17 inch LCD Monitor
My DCLCD 19" monitor flickers
Dell desktop monitor screen flickers.
The monitor is about to go bad. Replace it. Borrow a monitor from a family member, neighbor or friend just to see if the flickering stops. If it does stop your monitor is bad. If the borrowed monitor flickers, you will need to replace your Video Card in the computer.
May 01, 2012 | Dell Computers & Internet
When i plug it in and turn it on. it takes minutes to warm up. flickers on and off on a black screen.
the flickering is normally due to an EST about to go bad so contact a local tech who repairs monitors and get the EST checked
Dec 08, 2010 | ViewSonic VX900 19" Flat Panel LCD Monitor
Dclcd monitor blinking power light
Try it on another PC first, if it still does not work then you will need to open it up, but read below first so you will know what to look for:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 02, 2010 | Star DCLCD DCL7A 17 inch LCD Monitor
Monitor flickers about 2 minutes after turn on. the flickering starts from the left and it eventually becomes a black screen. the monitor is 8 months new.
Unless I have the model number wrong (F1903), this monitor was relased in 2004. If it is 8 months old then it should be fixed under warranty. This can be bad problem in the bcaklight inverter circuits or bad lamps due to bad soldering works, bad power supply, please look here to see hwat is involved in repairing the monitors: http://s807.photobucket.com/home/budm/allalbums
Apr 01, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
Envision 19" Widescreen Flat-Panel LCD Monitor It just started I have lines that flicker across the screen.How do I stop that it is driving me crazy.
Is there any speaker sets near the monitor or electromagnetic devices near the monitor?
Generally the flicker is caused by some external devices.
Mar 14, 2010 | Envision 19" Widescreen Flat Panel LCD...
Acer 1916w flickering
Its either going to be a problem with puffy capacitors on the main board or the lcd is going bad on it cause the backlight can't stay on.
The cost of fixing the monitor may be more then what a new one is worth but you wouldn't know unless you bring it to a repair shop and have them look at it.
Try another known working monitor to see if you get the same symptoms, if they go away then you know the original monitor is bad. if you get the same symptoms then the video card is bad.
Jun 26, 2009 | Acer AL1916W 19" LCD Monitor
Acer AL1914 flickering background
check the monitor refresh rate setting.right click on the back ground on the main windows screen. Choose proprieties from the menu that opens, then click on the settings tab on the top of property window. Next click 0on the monitor tab and increase the refresh rate at the bottom of monitor window. That should do it.
Jan 24, 2009 | Acer 19" LCD Monitor
HANNS-G MONITOR BLACK SCREEN JUST FLICKERS
when u power the computer press F8 key then enter in enable vga mode.
then if u able to enter then chagne screen resolution to 1024*768
Jan 05, 2009 | Hanns.G Corporation JW-199DPB 19" LCD...
DCLCD 19" flatscreen won't turn on correctly
Same problem here, but after using the plugging/unplugging method it eventually stopped all together. So, I took it to a local monitor repair shop (AM Stereo, Seattle). The problem is a power supply issue where the capasitors go bad. They fixed the monitor by replacing the capacitors for $70. In there experience, all monitors, regardless of brand, tend to use the same cheap capacitors which fail. He replaced them with better quality capacitors which may make this monitor better than it ever was. I'm back in business with a great monitor!
Oct 31, 2007 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
Monitor
Check for faulty MAIN'S CORD or A/C Socket in the UPS if UR having.Try the MONITOR source in some other socket.
May 02, 2007 | Compaq Presario CV915 (White) 19 in.CRT...
Star DCLCD DCL7A  17 inch LCD Monitor Logo
Top Star Computers & Internet Experts
Abdul Mannan
Abdul Mannan
ray gallant
Paul Chapman
Paul Chapman
Are you a Star Computer and Internet Expert? Answer questions, earn points and help others
