Question about Euro-Pro Sewing Machines
Thread breaks each time I attempt to sew. - Euro-Pro Sewing Machines
  • Euro-Pro Master
  • 7,365 Answers
Rethread the machine
try the tension on 3 or 4
use a new needle
some needle & threads don't work togeather
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Posted on Nov 08, 2010
The thread is breaking the whole time, what could possibly be the problem?
Could be several things, ie mis-threading, burr or snag is catching the thread, old/bargain bin thread, needle is not compatible with thread and fabric, tension is incorrect...
The first thing to try (and also the least expensive), install a brand new needle.
Remove the upper thread. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Feb 25, 2017 | Sewing Machines
My thread keeps breaking, Ive checked and changed my needle, re-threaded bobbin and upper but every time I try to sew the upper thread breaks.
Have you tried loosening the upper tension? Remove the upper thread, RAISE the presser foot and rethread from the beginning (make sure it follows the correct thread pathway). Sometimes the upper thread jumps out of a thread guide or wraps around something. Or try a different brand of thread? Avoid old or bargain bin threads--use good quality thread. Could also be the incorrect needle for the thread/fabric, ie thread too large for the needle eye.
NMSU Checklist of Common Machine Troubles
Why Does My Thread Keep Breaking While Sew
Apr 03, 2016 | Sewing Machines
My thread keeps breaking every time I start sewing on my pfaff 4.0 sewing machine. O have changed the thread two times. re threaded the needle six times and ensured the needle was in the correct location....
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Sep 02, 2013 | Pfaff Creative 4.0 Sewing Machnie
How do i fix my machine, it's breaking the top thread all the time
The needle thread breaks
Nov 28, 2012 | Sewing Machines
Model vx710 upper tread keeps breaking adjusted both tentions
If the timing is a bit off this could also be causing the thread to break. lf you've had a good attempt at getting the two tensions right and not having any joy, then it could be timing is just out a little.
I'm assuming that its good quality thread and same top and bottom and that you've checked the thread paths for any places where it could be catching/jamming etc already.
If machine has been at least 2 years since a service then might be time to take it for one.
Apr 27, 2011 | Brother Sewing Machines
Morse 6300, the thread keeps breaking every attempt i make
Change your needle, make sure the needle is new. and change your thread. Use a high quality thread and rethread the machine carefully, following all the guides. Also, check your tensions. I bet it is the needle tho.
May 11, 2009 | Brother LS-2125 Mechanical Sewing Machine
The needle thread on my bernina minimatic keeps breaking.
There is special thread for denim/jeans. It usually comes in shades of brown. It's a little heavier and might help with the breakage. You might also want to try a little less tension. I assume you already have a Schmetz denim needle?
Apr 06, 2009 | Bernina Virtuosa 160
Needle jams and breaks off
Needle jams....Thread is caught in the hook...solution...Remove the upper thread and bobbin case,turn the handwheel backwards and forwards by hand and remove the thread remands.
Needles breaks
1. Needles is damaged..Insert new needle
2. The needle is not correctly inserted....insert flat side towards the back
3. Wrong needle size for the fabric...Choose a needle to suit the thread and fabric.
Mar 24, 2008 | Singer 1116 Mechanical Sewing Machine
Needle breaking-CE 250
I had that same problem and it was due to the thread being too tight. Put the thread net on your thread and it should be ok.
Dec 22, 2007 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
