Question about Kenmore 24.8 cu. ft. TRIO Bottom Freezer Refrigerator
The temperature settings keep changing themselves. i leave them (with the lock on) at 36 and -2. Sometimes when I get up in the morning they might be at 45 and 8 ???? or something strange...
    Sergeant:
    Champion:
  • 277 Answers
Is is not a self regulating unit
Posted on Nov 08, 2010
  • Kimberly Mobley Nov 08, 2010
    I know - why does it keep changing on it's own??? I want it to stay where I set it, as it is NOT self regulating....any suggestions?
2002 chevy malibu doors unlock themselves!
I don't understand the question, but sometimes, newer cars give you time to auto u lock in case you leave a child unattended in the car.
Oct 14, 2014 | Cars & Trucks
What does led reading DEF mean on model G20010
DEF means it is in defrost mode. If it looks like it doesn't need defrosting, or if it looks like it is frozen up, the display can sometimes stick showing def until it gets back to its set temperature.. Check all is clean and working, leave off for a day with door open and see if it is ok after that.
Apr 26, 2014 | Refrigerators
Not cold
Good Morning renee kelley, this is Z. I am happy to assist you!
Good Afternoon Jason, thank you for allowing me to assist you!
I understand your Frigidaire freezer is not cooling and displaying "OFF" on the door. It appears that the temperature control is in the OFF position. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating the freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I hope these troubleshooting tips help you in some small way. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your freezer status has changed successfully.
Mar 20, 2014 | Frigidaire Freezers
Compressor not kicking in on 'cool'; or ;dry'
Have you checked that the controls are not set to fan only? If you have lets go to the next step. All window A/C have thermal switch.. These thermal switch keeps the compressor from overheating. In the event that the compressor is overloading it would trip then click back on as the compressor cools down. Sometimes those switches go bad but the compressor is ok. They are mounted on the compressor themselves and accesable once the A/C unit cover has been opened.
Jul 07, 2010 | Whirlpool ACQ122XK Air Conditioner
Heater blowing cold air
Hi!
It appears we have an Air lock scenario and you will need to perform a system Bleed.
Park the vehicle on level ground, when cold remove coolant filler cap, start engine and leave to idle, turn heater on full and blower to max. When engine reaches operating temperature watch and listen near coolant filler, keep clear as gurgling and hopefully a boil over should occur. Top up with very warm coolant and wait as it may do it again.
Check for heat inside vehicle if warm replace coolant cap but keep an eye on temperature gauge as the ~Air lock may have moved on from heater matrix/core so proceedure needs to be carried out again from COLD.
If No change then look at thermostat but I'm sure your problem lies with the heater Matrix/Core!
Please press the Blue button to appraise my FREE Efforts, Thank You!
Paul 'W' U.K.
Feb 06, 2009 | 1996 Chevrolet Blazer
Vacation button keeps on activated(refrigerator Samsung SRS20NTC)
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Set to regular temp then lock functions.
Freezer temp + fridge temp for 3-8 sec to lock function
Dec 13, 2008 | Samsung SRS20DTD Side by Side Refrigerator
RCA 36 inch ---channels keep changing
Mine did this and I took the back off of it to remove the button panel on top of the tv. It un- snaps from the inside and pulls straight out. My channel down button was messed up but it lookd fine. It has three prongs on one side of it and two on the other. I clipped the two prong side of the switch and put it back together. Works fine now with remote. Be careful as the set picture tube holds high voltage for a long time when unpluged. Unplug overnight and then work on it.
Jul 21, 2008 | RCA F36674ET 36" TV
TV turns on & off by itself. Channels also change by themselves.
Make sure your remote is totally away from the set.
Make sure the buttons on the set are not sticky
If both of those are ok, it's your E-Prom in the set. RCA's are notorious for this, not a major repair, maybe $75-100. The 8 leg e-rom is only about $6.00
Apr 11, 2008 | RCA F36668 36" TV
Kenmore 24.8 cu. ft. TRIO Bottom Freezer Refrigerator Logo
46 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
