Question about Frigidaire GLTF2940WH
I have a Frigidaire GLTF2940FS front load washer that leaks water into the drawer of the stand it sits on. how can i tell where the water is coming from?
  • 126 Answers
It pretty much has to be coming down the front, underneath the door. If your rubber boot is really dirty or has a lot of hair on it this will happen.
Posted on Nov 08, 2010
My Frigidaire affinity washer leaks water into the washer stand. Whenever I open the drawer after washing a couple of loads there's water in the drawer.
That's what I thought was wrong with mine to I had 1.75 in change and a piece of a wash clothe in the screen. I toke all that out and it still leaked. Took it apart further and found a piece of the weight that is made out of cement broke of and rubbed through the drum. That sounds like junk to me!!!
Oct 30, 2012 | Frigidaire ATF6000ES Front Load Washer
What does the error message E20 on the frigidaire front load washer GLTF2940FS mean?
Hello - The error code "E20" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Oct 15, 2012 | Frigidaire GLTF2940ES Front Load Washer
Bosch WFVC6450UC Washer leaks at bottom
How about loose fill hose connections?
How about incomplete shutoff of the internal fill control valve between wash cycles?
Sep 22, 2012 | Bosch WFVC6450UC Front Load Stacked Washer...
FRIGIDAIRE WASHER GLTF2940FS / WASHER HAS POWER BUT WON'T START/ IT DISPLAYS LOC IN THE ESTIMATED TIME WINDOW
means display is locked look for little lock symbol on panel,
press and hold key for 5 seconds
Sep 01, 2010 | Frigidaire GLTF2940F Front Load Washer
My washer leaks when used
Check if the leak is from the tap or hose. Is it leaking out the front?..Could be door seal, from inside could be pump or blocked detergent drawer/hose...Water and electricity don't mix! probably best to call a tech!!!.........Nomess
Apr 18, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
MAJOR leak in new JUST installed WCVH6800 front load washer
If you hear of a solution, let everyone know. Our machine did the same thing. From the research I have seen, GE makes **** machines and I will NEVER buy a GE product again.
Feb 07, 2010 | General Electric WCVH6800J Front Load...
My washer is giving error code e10 and im not sure what to do my washer is a frigidaire front load
I have an error code chart that came with mine and it says a few different things for E10. 1st says water not entering washer. 2nd says water leaks. 3rd soap dispenser drawer is open. In another post there was something about a magnet needed in the drawer too. But I would suggest checking your hoses and making sure you have water and the drawer is completly closed.
Jan 18, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire gltf2940e front loading washer - dispenser drawer magnet replacement
When you are looking at the drawer, the magnet stands upright on the far right side just inside the outer front casing about halfway down. There is a small plastic clip that holds it in place. You don't need to take anything apart to reinsert the magnet, just open the drawer, but it may be easier to see the location if you pull the drawer all the way out of the hole.
Nov 02, 2008 | Frigidaire GLTF2940E Front Load Washer
Leaks water from soap drawer
could be a loose hose to the drum from the dispenser or a tape still in the dispenser not taken off.
please check it.
tnx 4 using fixya,
drcool
Oct 27, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTF2940WH Logo
137 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
