Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
My beater bar makes a noise and has a crack in the motor on the beater bar and is discolored--me thinks I need a new motor for the beater bar
  • 694 Answers
Sounds like you're right. New motors are available at your nearest Aerus Electrolux store. They used to charge the same amount for selling the motor and letting the buyer install it, or for installing it in the shop. Worth checking in to.
http://www.aerushome.com/storelocator/
Posted on Nov 08, 2010
SHARK NV90 VACUUM BEATER BAR DOES NOT ROTATE - WHAT IS MY PROBLEM?
Most beaters are driven by a rubber belt driven off a shaft from the motor. Check this is in place, and wrapped around both the shaft and the beater bar (they can break). If this is OK, try to move the bar by hand- it may be jammed by fibres, hair, or other material that has wrapped around the bar. If this is the case, cut along the fibres and remove.
Oct 15, 2016 | Shark Vacuums
Dyson DC27 beater bar making noise
I'm sorry to hear you're having difficulty with your DC27's brush bar. If you haven't already been in touch with us, I'd encourage you to give our Helpline a call on 1-866-693-9766 (US), or 0800 298 0298 (UK), as we may be able to resolve this issue with some simple troubleshooting over the phone.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Jul 02, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
The motor on my carpet tool (beater brush) stopped running yesterday. The main vacuum still works, but the switch for the carpet tool just clicks and doesn't turn it on.
Knowing the model would help.
Possible problems:
Broken or disconnected wire in hose, connections, power nozzle.
Hose needs replaced. Check all connections for discoloration and cracked supports. Have power nozzle checked at a vacuum shop. Depending on the model, take it to an authorized Aerus Electrolux store for this.
Bad power nozzle motor Needs replaced.
Bad switch. Take the whole machine in for thorough check and repair..
Jan 25, 2011 | Electrolux Vacuums
The motor running the beater bar on ny Electrolux canister vacuum cleaner runs intermittently. It runs about 2 minutes and then cuts off and automatically starts again after a 1 to 2 minute interval. I...
Check all the wiring connections to make sure they're tight.
1/2. Wiring to power nozzle motor or reset switch is loose.
1. Cord from power nozzle to upper wand. If the plastic portion of the wand is cracked near the cord connection, or the connections are blackened, they need replaced.
2. Wiring connection from hose handle to upper wand. Check for cracks and discoloration as in 1 above. Replace if necessary.
3. Hose connection to vacuum. Not likely, but possible.
4. There could very well be a break in the hose wiring.
You may need to take your vacuum, with hose and power nozzle, to an authorized Aerus Electrux service shop. They can try a new hoze to see if that's the problem. If there is a break in the wiring, the hose is probably worn in other areas as well, and should be replaced.
Oct 16, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Dyson vacuum DC17 beater bar won't turn
sounds like the brushroll motor has gone bad. disassemble the head and check the continuity on the brushroll motor
Feb 26, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson 07 animale
Check out this YouTube Video:
http://www.ezvacuum.com/dyson-dc07dc14-clutch-assembly-90025204-genuine-p-1636.html
After reading a ton of forums I thought I needed to replace the clutch assembly. My Dyson was making a horrible noise when in "carpet" mode. Got a new clutch on eBay for a great price. Somewhat hard to replace, but thanks to the YouTube video, I was able to get it in.
HOWEVER this did not resolve the issue. I realized the beater bar was not spinning or was slipping. I thought I cleaned it all out but realized you need to take the beater bar out and pop the end cap out and clean the INSIDE of the beater bar. I additionally sprayed WD40 in there.
It spins great now and in the end I think that's all I had to do was clean out the cat hair build up inside the beater bar. But now I have a new clutch & belts too. Hopefully won't have issues anytime soon.
Dec 22, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
WHEN I TURN MY VACUME ON IT SOUNDS FINE, WHEN UPRIGHT. WHEN I GO TO MOVE IT TO HOOVER IT MAKES A SCREAMING NOISE. CAN U TELL ME WHAT IS WRONG PLEASE AND HOW TO FIX. THANK YOU
When the vaccum is upright, the beater bar is not engaged. When you tilt the handle back, the clutch engages and the beater bar begins to turn.
There are two likely possibilities for the "screaming noise". First, and most likely, is that the beater bar cannot turn because of a build up of debris or the beater bar is broken. In eaither case, the clutch belt is spinning on the non-moving beater bar causing the noise. Remove the beater bar, inspect for hair, carpet fibers or other items wrapped around the bar. Also inspect for cracks in the plasitc at the ends of the bar. Clean or replace the bar as needed.
The second possible cause is the clutch assembly. If you were unable to fix the problem with the first solution, it is time to take the vacuum in for service as replacing the clutch is somewhat difficult.
Here is a YouTube video link that will walk you through the process of removing the beater bar as well as the clutch if you decide to go it on your own: http://www.youtube.com/watch?v=7_CtaFcc5HU
Hope this helps.
Sep 23, 2009 | Dyson Vacuums
2 year old machine...new noise in beater bar area
I have a dyson 17 animal and have a loud noise comming from the beater bar area.Also I don't think the hight adjuster is working properly.
Apr 15, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Vacuum turns on and suction in hose works, beater bar won't turn
If you hear the motor in the head running and the beater bar isn't rotating, you probably need a drive belt. With the power off, make sure you can rotate the beater bar freely by hand, if it isn't bound up.. then locate and remove the baseplate screws to gain access to the beater bar itself, you'll see a drive belt pulley system and chances are, a broken belt. Replace it with a new one by pulling the beater bar assembly out of the housing and plcing the belt onto the motor shaft pulley as well as the beater bar pulley.. nest the beater bar back into the holder and reinstall the cover. Hope that helps !
Aug 14, 2008 | Eureka Vacuums
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
70 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
