Question about Toshiba e-Studio 202L Copier
I need to calibrate the touch screen - Toshiba e-Studio 202L Copier
  • Toshiba Master
  • 707 Answers
Press & hold the "0" and "8" key, on machine to enter 08 mode.
Type "692", calibration screen will pop out, calibrate the 2 points and restart machine.
Posted on Nov 09, 2010
Where is pc settings/ calabrate located in lenovo c260
From page 21 of the user manual, "The monitor is touch-sensitive thanks to its touch-sensitive screen. A touch screen is an input device just like a mouse or a keyboard, and the user's fingers transmit position information via the touch screen to the computer. With this technology, you only need to touch the pictures or words on the computer display lightly with your finger, and the computer will react. Touch Screen Calibration Prior to first use or whenever the touch screen reacts in a different place where you are touching it, start the calibration program. The procedure is as follows: 1. In Control Panel, select "Hardware and Sound". 2. In "Hardware and Sound" window, select "Tablet PC Settings". 3. In "Tablet PC Settings" dialogue, click "Calibrate" button. User Gesture Instructions for the Touch screen The Touch screen supports single touch and rotational movements, enlargement and reduction multi-touch operations, and the user can transmit position information to the computer via touch. The touch screen uses a very low pressure movement recognition method, which only needs the finger to move lightly on the computer display screen or make a simple hand gesture to be detected by the main computer processor. 16 User Guide 31506537 C260 UG V1.0 (Win8.1)(EN)(R).indb 16 2013-12-6 11:54:06
Nov 30, 2014 | Lenovo C260 Touch 19.5 Pent 4GB 500GB
Screen calibration screwed up.. need to know how to reset it?
You can get back into the touch-screen calibration routine if you start up the machine with both of the needle offset buttons pressed at the same time ... once you've calibrated the touch-screen you'll be OK again.
Dec 30, 2012 | Bernina Artista 180
Touch problem
Nokia designed the N97 with a touch-screen calibration program to remedy problems with the touch screen. Opening the touch-screen calibration program requires you to use the touch screen, which can prove difficult. You're forced to judge where to tap the screen because the screen isn't recording the precise location of your taps. To find the touch-screen calibration program, open the main menu, select "Settings" and then "Touch Input." The program provides on-screen instructions to help you finish calibrating the screen.
Oct 23, 2012 | Nokia N97 Cell Phone
What does calibrating a ipad mean
Whoever used the term "calibrating an iPad" may have been referring to touch screen calibration.
Some touch screens need to be adjusted, or "calibrated", or the device may act as if you touched a different spot on the screen than you did. The iPad screen does not need to be calibrated.
If the iPad make a mistake about what spot you touched, the error may be due to:
  • a defect or damage;
  • a screen protector;
  • a cold finger;
  • a hand that is holding the iPad and inadvertently touching the screen;
  • a finger that is inadvertently touching the screen.
Apr 26, 2012 | Apple iPad (16 GB) WiFi Tablet PC
Touch screen working but it's not recognizing finger to chang
You need to calibrate the touch screen.
Try this:
Press Yellow key
On the key pad Press 1-9-9-3.
Press 5 times the red key (the 5th old a little longer)
(If everything is good in the touch screen shows an option "calibrate touch screen")
Try to touch there and will show a little arrow on each corner. With a pen click there to calibrate the touch screen.
Click exit and its done
Mar 08, 2011 | Ricoh Aficio 3025P Black and White Copier
My touch screen quit working
If the touch screen of your phone keeps working, then it means the sensor board of the phone is bad and need to be replaced, if you can access the menu of the phone, then you need to calibrate the screen first.
To calibrate the screen, you need to go to the menu, then you select settings, then you select calibrate screen then you follow the rest of the instruction from there on.
If calibrating the screen does not help you, then it means you have to fix the sensor board of the phone, if your information from the keypad reaches the screen, then it means you simply need to replace the touch sensor board of the phone.
Hope this helped.
Take care and good luck
Jan 10, 2011 | Samsung SGH-A877 Impression Cell Phone
Its saying calibration problem on the screen
When the Reader device is started for the first time or is reset back to factory settings, the screen must be calibrated. The Reader device will display a calibration screen that requires you to touch the stylus to the center of an "X" at several points on the screen. This is to make sure the touch screen properly recognizes input.
The process requires you to touch the "X" in the following locations on the screen:
  • Top left
  • Bottom right
  • Top right
  • Center
If the screen is accidentally touched someplace other than the center of the "X" during calibration, the Reader device will display a message stating Calibration error detected. Please restart calibration process .
If this happens, please start again in the top left corner and touch the stylus to the center of each "X" as it is displayed, being careful not to touch any other part of the screen. After the sequence is completed the Reader device will display Touch Panel calibration completed . Click OK to continue to the next step in the setup process.
Dec 26, 2010 | Sony Reader Touch PRS-600
Touch screen not working
Try to remove the battery and insert it back into your gps device and turn it on. If the screen does not still work, then you need to reset the nuvi, by holding down the power button for about 15 seconds, then the unit will restart, that way the touch screen should respond. If it still does not work, then you need to calibrate the screen to get it to work. To calibrate the screen, follow the sreps below:
  1. Turn off your nuvi,
  2. Press your finger on the upper left corner of the touch screen,
  3. While holding your finger on the touch screen, turn on the nuvi,
  4. Continue to hold your finger on the screen for about 30 seconds until the calibration screen appears (white screen with touch dot),
  5. Then follow the on screen instructions.
It might not work trying it once, so you have to try it over time till it works. Calibration is the last resort of all solutions, so if calibrating it does not do the work, then it means it a an internal problem.
Dec 25, 2010 | Garmin nuvi 650 GPS Receiver
Calibrating posiflex jiva 5800
There should be a calibrate program in your posiflex. If it still doesn't want to calibrate, check whether the touch screen glass is worn out / cracked since you might need touch screen replacement
Aug 09, 2009 | Posiflex Jiva 5800 All-In-One...
China mobile
have a china made handheld double sim touch-screen phone. The device is Winkoy T6688. The touch screen got damaged and after reseting the device, the following notice appears after turning it on:
"Calibration wizard. You have to calibrate the touch-screen. Click anywhwere on the screen with your stylus to start calibration".
Of course you can´t but there´s no other option because it won´t accept any other input until it´s calibrated apparently. Does anyone know how to bypass this calibration wizard on start up?
Sep 10, 2008 | Nokia 6300 Cellular Phone
Toshiba e-Studio 202L Copier Logo
731 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Timothy Van Der...
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
