Hello, I have a Panasonic PT-53X54J. to attemp to turn on the TV, I have to plug it and it will try to come on but, quickly shuts down. Has a 1 red Blink, stops for a few seconds and comes on again. I read this may be an indication of a power supply unit problem. I open the back of the TV and all blue, red, green lights attemp to lit up before it shouts down. I heard that I may attempt to twist the red high voltage wire, that comes out of the black resistor unit, after waiting 30-60 minutes disconnected. Any other ideas. I haven't attempted this. Kind of afraid of the HVT.
  • tennispla411 Nov 08, 2010
    21045, is my zip code. What would be the estimated cost on such a repair? Ballpark figure is fine. (and yes, they were talking about the flyback, black box like thing that has one big red wire coming from the top and then splits to 3 big red wires giving power projectors.
    Thanks much for your help. I know quite a bit about PC's but not very much about TV's. One thing I did know. Is never mess around the back of the TV ask you can get yourself killed. Thanks for the tips!
  • 4,889 Answers
I am so glad that you actually wanted to confirm before you try this. The red wire they are talking about is probably the one coming from th flyback to the CRT. It carries around 20K-25K Volts so thats definitely a very bad idea. This problem is not related to that. This problem is caused by failed protection circuits on the power supply, usually resistors, voltage regulators etc., A component level repair should be performed and I would not advice you to do it yourself more so coz it sounds like you have not worked on electronic circuits before. You are better off seeking professional assistance. If you can get me your zipcode, then I can find you a list of techs in your area.
Posted on Nov 08, 2010
  • eagle338
    eagle338 Nov 08, 2010
    Huh. I knew that!Crazy people I would say. Loosening those cables would cause the flyback to arc and that arc is one of the things in the world that you do not want to be touching or even see(extremely bright and can result in temporary blinding). As for the estimate, it would be around 150$ max, as the replacement components usually do not cost over 20-30$ max(I once had to replace components worth 1.5$, a resistor and a shorted IC). Click on the link below to see the list of techs in your area. Some of them are very close by.
    http://www.fixya.com/Services.aspx?zip=2...
The center of my panasonic plasma tv remote control and volume stop working
They stopped working because they are used the most and the contact material has worn out inside. Try to find a replacement remote. Pressing the edge and not the middle might help for a while.
Nov 11, 2013 | Panasonic Tv Remote Control For Pt-53x54j...
I have a panasonic PT-53x54J that will not turn on,the red light keeps blinking 6 times
On a panasonic if its a "3" blink pattern its usualy a sign that the convergnce hsa failed. When this happens the tV will commonly shut down. You will need to call in a repair shp or get the parts from sites like www.TvRepairKits.com or just google convergence repair kit.
Aug 18, 2011 | Panasonic PT-47WX53 47" Rear Projection...
Can I use the Panasonic PT-53X54J as a computer monitor?
U have a HDMI hub on this tv?Yes,than u can used it as a monitor.No HDMI hub,can't used as a computer monitor.
Sep 30, 2010 | Panasonic PT-53X54 53" Rear Projection...
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
My panasonic rear projection TV turns off
this just happened to us, we tried the reset button, didn't work. we unplugged from surge protector and plugged the tv in the regular wall socket and after a few minutes the green light quit and we were able to turn tv on
Apr 08, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-53X54J Rear Projection TV. Suddenly shut off just before went black with a color line down the middle. When turned back on makes clicking noise and can't power on for about 3 minutes then cuts...
That is the classical sound of a Switchmode power supply, detecting an "Over current" situation and shutting down, for "Safety" reasons, like fire explosion etc. I get these in the shop frequently, (actually they seldom get to the shop, more, we go to them, as they are so BIG) This is a common occurrence. But can have many, many causes, the Power Supply shutting down, is a "Symptom", of the actual "Cause". Unfortunately, as related there are many areas that can cause this to happen. It literally can be in any section, or part of the circuit. really, the only way to effect a fix, is to first get a Service Manual. It is well worth the price it costs to get one. Simply Google the name off your TV, and add the words "service manual" after, Panasonic PT-53X54 service manual The manual gives service algorithms, to work through, to isolate the problem. It is still quite a challenge in any event. Rear projection TV's do have what seems to be a higher failure rate than the "Normal" TV's. Also they seem to be more expensive to repair. If you decide to get a repair ensure you get a firm "Quote" before proceeding. No "Quote" no job. If you choose to do it yourself.. good luck
Mar 12, 2010 | Panasonic PT-53X54 53" Rear Projection...
Hello, We have the Panasonic project TV (PT-50LC14). We purchased a new bulb this past July. We're now experiencing problems with the TV. After turning it on for less than 5 minutes, the TV shuts off. ...
Hello well this kind of problem all the time is because you have a fan problem and you could have dirt inside of your tv and sounds also like a ballast problem i have this issue also and I got connected on the live chat that a web say has that they call discount-merchant they sell parts and lamps for TV they could help you they help me twice.
Regards
Jan 01, 2010 | Panasonic PT-50LC14 50" Rear Projection...
PT-53X54J Power Switch Flashing Red and more...
think it's the projection bulb, easy to replace yourself
Apr 14, 2008 | Panasonic PT-53X54 53" Rear Projection...
Panasonic PT-53x54J
a tech would be fairly expensive a simple convergence repair is usually about 400.00 most repairs can be handeld as long as a good tech gives the proper techniques and warnings of what to do and what not to do.It does involve soldering and unsoldering
Apr 08, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Televison & Video Logo
90 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
