Question about BenQ T904 19" LCD Monitor
Hi! I have Benq monitor FP92W a Q9W5. Two months after insurance period ended, I can not turn on monitor. I clicked on the turn on button but green diode which tells me that monitor is on, turned off after 1 second and monitor wont start at all. Like it is unplugged from current. Monitor don't give any signs of life. How to find out what is wrong? Are there any software or something to test it?
SOURCE: Q7T4 monitor
I have the same trouble,with the Benq Q7t4 power, but can you tell me how I can get it apart, I have taken all the screws out but can't seem to dismantle it.
many thks colin
Posted on Jun 30, 2008
  • 5 Answers
SOURCE: BenQ FP767 17" Problem: Monitor wont turn on
Check four 5707, two 9204, and one bel 3A slow blow fuse. Also re-solder all cap and transformer.It's quiet common on benq and Dell(benq OEM) 17 LCD. For detail google "benq 5707", sure you can found. Good luck
Posted on Jul 19, 2008
var-pun
  • 331 Answers
SOURCE: Monitor goes blank less than a second after turning on.
the moniter may be having  some technical errors   maybe the IC's has got corrupt
you need to call the seller of the moniter
Posted on Sep 06, 2008
freetek
  • 5568 Answers
SOURCE: BenQ FP91G+ 19" LCD Monitor black screen
Possibly either the backlight lamp or its associated power supply has failed. Power buttons (mostly LEDs) have constant availability of low voltage (for some other circuits too) otherwise they wouldn't 'wake up' on command from a computer as some do.
The blackout could also be due to a failed main power supply so the incoming video is no longer being processed.
Posted on Nov 01, 2008
tbreeze47
  • 3083 Answers
SOURCE: Benq FP92W monitor. The screen has turned white,
This isn't an easy solution, my friend. Go to this website and read what so many others are saying about the same problem. When you ger to this webpage, go to the link for the white screen problem, it's the same one you're having. http://en.kioskea.net/forum/affich-51640-laptop-screen-goes-white
I wish I could give you a simple solution, but there isn't one, sorry. These days it's usually cheaper to replace than fix, unless you get lucky.
Posted on Mar 19, 2010
Power supply range
RTM
get the operators manual, free online (google is your friend?)
and read it.
its all there.
do you mean what is , the A/C line voltage ranges?
most say so, on the back, did you look there>?
Sep 30, 2013 | BenQ FP92W LCD Monitor
Benq lcd fp0537s on for just 2 second
There are one or two capacitors in the power supply that open," leaving a slight puff at the top" in some cases.
Mar 16, 2012 | BenQ FP92W LCD Monitor
When I turn desktop on & monitor on, sceen display for about 10sec then monitor go's off. Have put another monitor on desktop and it works fine. Something wrong with LCD monitor
This tends to be a power issue and monitor is hopefully under warranty and will need to be sent back. Otherwise it is pretty much done.
Feb 22, 2011 | BenQ FP92W LCD Monitor
Power not on, power button blinks green power light, doesn't power up. Benq FP92W
It sounds like you have a power supply problem and the safety shutdown has kicked in, the system will need to be checked by a computer tech with an estimate in mind.
Dec 31, 2010 | BenQ FP92W LCD Monitor
Benq FP92W monitor. The screen has turned white, I've turned it on and off several times but keeps showing a fully white screen. Help?
Mar 19, 2010 | BenQ FP92W LCD Monitor
I have a benq fp71g model q7t4 computer monitor when i hit the power button the green indicator light comes on but goes right off i can hear a clicking sound when i hit the button what can i do
use another monitor with your pc to make sure your graphic card is working and
connect that benq monitor (to double check it is ok) another pc
find out if the clicking comes from the monitor or the pc tower,
if yes from the tower than your video card fails.
exchange it with another and replug benq monitor, boot up.that should solve the prob
Jul 28, 2009 | Computers & Internet
Benq computer monitor shuts down after standby in energy saving..
There are 6 (reduced quality) capacitors in the BenQ Q9W5 which cause the screen over time to 'fail to sync' when turning on or resuming from standby.
They are;
4x 470uF 35v, and
2x 1000uF 16v.
I recommend the following replacements if you are in Australia (the ones I purchased from Jaycar only lasted 12 months);
(470uF) http://www.altronics.com.au/index.asp?area=item&id=R4865
(1000uF) http://www.altronics.com.au/index.asp?area=item&id=R5182
Mar 24, 2009 | BenQ Computers & Internet
Benq 24" wont comes back after sleep mode
Try to install the OS once again.
If it turn up the same again then it may be the logical board problem.
Apr 12, 2008 | BenQ FP92W LCD Monitor
Screen working and after 2 sec screen black
On your power board you will have a faulty surface mount fet with 8 legs that controls the backlights.
There are 4 of these, but if any of them fail the protection circuit turns them all off.
Best best is to get it to a local technician for repair. It is not an easy task unless you have the right equipment.
Hope that helps. =)
Dec 14, 2007 | BenQ FP92W LCD Monitor
Reset back to factory defaults
To unlock the OSD
controls when the OSD is
preset to be locked, press
and hold the 'MENU'
button for 15 seconds to
enter the 'OSD Lock'
option and make
changes.
Nigel@netfishers
Oct 16, 2007 | BenQ FP92W LCD Monitor
BenQ T904 19" LCD Monitor Logo
229 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
