Question about White Sewing Sewing Machines
White serger lower looper needed or upper looper
  • White Sewing Master
  • 7,365 Answers
Check with sewingpartsonline.com
if you don't see the parts just email them they will answer
Posted on Nov 08, 2010
I have a white speedy lock serger model 7340. I completely pulled all threads out and now trying to re-thread new thread. I have tried around 15 times. It will not loop. Threads don't interlock at all
Be sure that you are threading each thread in the correct order. The manual should have those instructions.
ALWAYS RAISE the presser foot when threading the machine!!!! For most machines, the upper looper is threaded first, the lower looper second (the lower looper thread finishes by draping OVER the top of the upper looper and then pulled toward the back of the machine), then thread the needles. Give each thread an extra little tug when threading the tension disk to make sure it is seated completely.
Even if you are unable to locate a tutorial for your particular machine, most models from the same era will thread the same.
Don't be surprised if it doesn't work the first, second, or even the third try. It took me most of a day to get mine threaded correctly the first time!!! Patience!
How to Thread the White Superlock 534 Serger Serger Machine Series Ep 2
How to thread White Superlock serger
Sewing Machine Instructions White Speedylock Differential 1800
You can search YouTube for other videos.
Jan 06, 2017 | Sewing Machines
The tread from the lower looper is not being picked up by the upper looper how o i fix this?
Best advice would be to consult your owner's manual. The most common serger problems are caused by incorrect threading or not threading the threads in the proper order. With most sergers, the upper looper should be threaded first. The lower looper is threaded second and the lower looper thread tail should drape OVER the upper looper. Then thread the needles.
Be sure when threading that each thread is pulled snugly into the tension disks.
Nov 15, 2015 | Janome MyLock 644D
Why won't my sl370 work?
Hello Mary.
By the question, it looks like the lower looper is making loops? If so, check that you are using the correct needles for your serger and that the needle or needles is/are inserted correctly:
- needles must be all the way up into the needle shaft
- needles must face with the flat side to the back and the groove to the front
- use at least needle size 12/80, not smaller
Check these few items, if the loops are still not forming:
- re-thread the serger from the start, keeping in mind to thread in the proper sequence (upper looper, lower looper, needles)
- make sure that the lower looper thread lays on top of the upper looper thread and is passed to the back of the serger and then under the presser foot when threading
- make sure that the thread are securely engaged IN the tension assembly
- make sure that the serger is set for 3-thread or 4-thread overlock (i.e. that the upper looper converter is not engaged)
- check all tension setting
- stitch length should be around 2.5 - 3.5
Let me know how it goes.
Happy serging!
May 02, 2015 | Sewing Machines
My serger is not looping at all. I changed the needles and nothing is working.
Start with the threading sequence. Upper looper, lower looper, left needle, right needle. Your upper & lower loopers must be threaded before your needles or it won't make the stitch. If it still doesn't work, it's out of time and will need to be taken in to a shop.
Mar 05, 2015 | Singer White Speedylock 1634
Upper looper hits lower looper
The upper/lower looper need realignment, requires a qualified technician to do this.
Oct 21, 2013 | Brother 1034D Serger Sewing Machine
I have a Huskylock 936 Serger and used it last week, no problem. I changed the threads for a new product and one thread came out and had to rethread. I know you have to thread the upper looper first then...
Recommend you remove all the threads and rethread from the beginning. ALWAYS RAISE THE PRESSER FOOT when threading and thread the upper looper first, the lower looper second. Sergers sometimes are temperamental about threading. When in doubt, start over from the beginning.
Jun 14, 2017 | Husqvarna Huskylock Computerized 936
JUKI MO 134 SERGER
How to Thread Juki MO-134 Serger from watching lady at Lyles. Turn upper blade up. Push in first then turn up.It makes threading easier. Blue Thread upper looper first. Pull thread through tension knob. Don'tjust lay it there. (She thought that is what I must have done) Orange Thread lower looper next. Pull thread through tension knob as inthreading upper looper. Adjust lower looper so it is right nextto upper looper so that their points are almost together and directly belowsewing needles. Lower looper will be in front of upper looper (I believe). With tread from upper looper pulledback, slightly lift lower looper above upper looper and thread. I think this isright. Pull thread back with other thread. Tension is the key. Remember that. Yellow: Thread left needle first.Remember tension. Pull thread through curled wire on left side of needle arm. Green: Thread right needle. Rememberabout tension. Pull thread through curled wire on right side of needle arm. b> Note: Before sewing turn the wheel tomake sure the stitches are going together correctly.
Apr 16, 2010 | Juki MO-644D Mechanical Sewing Machine
White Superlock Serger 1934D
Either adjust your knife to cut wider or tighten both looper threads.
sewman7
Aug 09, 2008 | White Sewing Superlock 1934D Mechanical...
Threading my whites superlock 2500 serger
You can get sewing machine manuals online at sewingmanuals.com. I didn't see the superlock 2500 but there were other superlocks. They may thread the same way.
Jul 30, 2008 | White Sewing Speedylock 1600 Mechanical...
Threading a serger
Always thread the lower looper first. Then the upper looper. Finish by threading the needles.
By the way, the lower looper is the one which is always below the needle plate and the upper one is the one which travels above the needle plate.
sewman7
Jul 01, 2008 | Simplicity Serge Pro SW432 Mechanical...
Sewing Machines Logo
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
