Question about LG LDF6810ST Stainless Steel Built-in Dishwasher
Middle spray arm is not turning - LG LDF6810ST Stainless Steel Built-in Dishwasher
    President:
  • 2,468 Answers
Check the arm assembly bearing for free play,then the spray arm for food residue blockage,then if these are o.k.,then replace the water conduit that runs up the back interior wall of the washer,the basket has what is called a water horn and is rolled into and against the water conduit to get water to this arm to turn it,after time this horn loses fit and lets water get past it so you lose water pressure and it no longer gets the watert pressure needed to turn it
Posted on Nov 08, 2010
2009 year Model 2182; middle spray arm came loose; when reattached, does not turn properly or spray water; makes knocking noise with door closed.
The parts that hold the spray arm have worn out...to get it working right you will need to get a new arm and the parts that it attaches too and you will be fine...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Jan 03, 2011 | Miele Inspira G2140 Dishwasher
The top washer is not spinning
Look at the top spray arm and see if it moves freely. Inspect the middle part of the spray arm. Sometimes a tall dishes can prevent the arm from moving. Put the spray arm at 12 o'clock position and have a cup right side up in the dishwasher. Run a cycle. During the cycle the cup should be filled to the top with in 20sec and the spray arm should have moved from its position. If not then change out the spray arm and Delivery tube.
Thanks, Please rate your experience
Dec 11, 2010 | KitchenAid Dishwashers
Du1145xtpq top spray, and upper spray arm don't
sounds like the chopper is plugged or broken. remove the lower spray arm by holding tab with a set of plyers and turn spray arm counter clockwise. then where the middle spray arm attaches at the back of tub remove screw. turn the housing on pump to the right side of the machine( its easier to pull top rack out a bit so that whole housing can move) it will turn a little bit to be released from top of pump. then take out the torx screws that hold the housing and filter on. in the sump there will be one or two more smaller torx screws remove those and remove coverings to the chopper. check to see if the mesh is plugged with food and other things. clean. also check to see if blade turn with the motor impeller. if not then the chopper needs to be replaced. good luck
Dec 03, 2009 | Whirlpool Dishwashers
Spray Arms won't rotate
good day,
hope this link below will solve your problem.
kitchen appliances
Jul 16, 2009 | KitchenAid Architect? II U SERIES KUDS03ST...
The diswasher arm does not rotate or spray water
Check the small holes on the spray arm. They are most likely plugged. (candy wrappers, tooth picks, popcorn or watermelon seeds, you name it.) Sometimes you can clear the holes out, other times it is just as easy (and not very expensive) to replace the spray arm(s). List your model number if you need part numbers or instructions on removing spray arm.
May 14, 2009 | GE 24 in. GSD2000Z Built-in Dishwasher
Middle spray arm does not rotate
Please check: Does the arm turn freely?  Are the jets clean and spray in the right direction? If not you may need to replace the arm.
May 12, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
GE GLD5800L Middle Spray Arm is Not Spinning
The middle arm may be missing an O-ring at the back of the dishwasher.
Mar 23, 2009 | GE GLD5800L Dishwasher
Water coming out of bottom during run cycle
Your lower spray arm is broken, allowing the water the hit the door where it shouldn't thus causing the water to blow out of the door gasket. To remove you turn the center plastic screw in the middle of the spray arm clockwise while holding the spray arm stationary. You can obtain the spray arm either at you local appliance dealer or at repair clinic dot com.
Feb 22, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
The middle spray arm has come off
If the arm does not appear to have broken parts, then it probably came unscrewed. The screw and washers may be in the bottom of the machine or instead of screw and washer it may be a plastic locking device. (depending on what model) Those screws or plastic locking device almost always screw in backwards. So, to but it back on, turn to the left as if you were loosening - but you are actually tightening.  Hope this helps ya.
Oct 11, 2008 | Frigidaire 24 in. GLD2162RDC Stainless...
How do I open the sprary arm
the plastic screw is not holding it down. First disconnect the white tube in the back of the bottom spray arm.Now turn the stub part clockwise. and the spray arm should pop off...
Jul 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
LG LDF6810ST Stainless Steel Built-in Dishwasher Logo
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
