Question about HP Compaq d530 SFF PC Desktop
I need to know how to open my stuck DVD plate in my desktop... please help
    Scholar:
  • 118 Answers
Hi, You can see a pinhole kindly try to pull it by using a pin or something
Please vote if you think this might help others:) Thank you
Posted on Nov 08, 2010
    Sergeant:
  • 233 Answers
All cd and dvd drives has small hole on front pannel, (it might be hidden some how according to the manifacturer) but you shoul find it , try to insert at least 8 cm PIN inside that hole to push the dvd drive's door out
Dvd drawer stuck in player
Most CD\DVD devices have a manual "eject" pin hole near the front of the door that a paper clip would fit into.
Be sure the device is unplugged before attempting....
Jun 09, 2011 | Panasonic Home Theater System System
Aver DVD Veriton 5800 dvd door will not open. do not see a pinhole. tried opening from computer start did not work either
sir the pin hole is the best solution but since u r unable to find it then the only solution remains to unscrew the DVD and check the door opening belt is not broken\stuck... just move it a little bit and the hatch may open... but before going through it please try to strike ur DVD with your hands a little bit while pressing the eject button repeatedly... this might help in moving the stuck belt inside... rate this solution if you watch awesome movies on your newly repaired DVD
regards....
May 06, 2011 | Acer Veriton 5800 PC Desktop
I need to know how to open my stuck magnavox dvd model # mdv422/17
hello
there is a pinhole in the front of the DVD faceplate, use a paperclip -- insert and push in , with little force, -- bay door will open
hope this helps
Nov 09, 2010 | HP Compaq d530 SFF PC Desktop
Dvd tray on Dell Inspiron 530 hard drive not opening. The dvd in the tray is not loose because the program runs so it's not the dvd preventing the opening process. The "door" tries to open and when I...
from what it sounds like.... its a gear problem. see, inside your dvd drive, there are a set of gears, and a little "rubber band" that opens and closes the dvd drive. either A). a gear has stripped itself(or broken) or b.) that "rubber band" has broke, and has gotten itself stuck(probably in the gears). Good luck, and i hope that it wasn't an important disk.
Feb 23, 2010 | Dell Inspiron 530 Desktop Computer
Installing a DVD Writer in open slot/replace the current drive
this plate is a cabinet safety plate just as a slot of our PCIE ...just twist that plate from one side so it will brake at two end tips and then install your dvd rw...
Aug 19, 2009 | Dell Inspiron 530 Desktop Computer...
Plate that dvd sits on while inserted into dvd wrter itself is stuck, how do I get it to work again? JZ
Thayt may take some work.
You need to remove the Burner and open it and then free yo the disk.
It sounds like you use it allot and it may be that the bearings are bad and it may not work.
replacement is called for.
Feb 21, 2009 | Computers & Internet
Door will not open
I had a similar problem, I went back in and opened it up, took the top plate that covers the lens, opened the tray, put the plate back on, then closed the tray and it works again. With the tray closed, I think I put the top plate on the bottom piece and it was stuck on.
Oct 19, 2008 | Cyberhome DVD Recorder - DVR1600
D.v.d.drive
Take a paper clip. In every cd/dvd rom there is a very small hole on the front plate. You would probably never notice it. Stick the paper clip into the hole and the tray will open. Maybe you have a stuck cd in there. Hopefully it will work after that on it's own again.
Is the light on it working?
You didn't say if you have a pc tower or a lap top as further trouble shooting will require knowing this.
Aug 18, 2008 | Computers & Internet
DISC STUCK AND ERROR 02 MESSAGE
hi, i have a kenwood kvt_725(or did have before some scallywag robbed it) i had a simular problem when ejecting discs i found that if you turn power off and removed face plate and turned ignition off it eventually ejected the disc and worked, or a simular routine with the face plate then ignition etc etc. i know it seems a lame solution sorry but hope it helps.....
Mar 20, 2008 | Pioneer AVH-P6500DVD Car DVD Player
DVD stuck
You can pull down the front cover over the DVD tray and you will see a white plastic sprocket wheel on the left bottom. Use a flat screwdriver to push that wheel to the left and the tray will come out. No need to open up the case at all using this method. You can get the DVD out and then I agree with the other posting - go buy a new DVD player! Very disappointed in this Sony product!
Dec 04, 2007 | Sony SLV-D350P DVD Player/VCR
HP Compaq d530 SFF PC Desktop Logo
80 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
