Question about Bryant Heating & Cooling
Where can I find an parts illustrations for a Bryant 90+ furnace? Model Number 398AAW036080D Product # 398AAW036080AEBA Need to know the correct name and or part number for the Black metal Condensate pan that bolts to the side of one of the burners, corodes and leaks water on the floor. I'm sure I do not have the only furnace that has or had the problem. This pan is around 4" tall and around 12'" long.
mastersaintx
  • 928 Answers
SOURCE: the driver for my modem(Diamond SupraMax 56K External USB)
You can go to the either link below.
http://www.driversdown.com/drivers/Diamond-Supra-Max-USB-SUP2920_73728.shtml
http://www.dmmdownload.com/driver.php
Posted on Jan 05, 2009
electrodynam
  • 35 Answers
SOURCE: bryant furnance clicking, won't fire
try checking the pressure sensing switch,it has a tube that should run somewhere close to the inducer fan.sometimes this hose fills with liquids,and makes the units act funny.I don't know if you have a condensing unit or what.the furnace wont try to light if it cant tell the inducer motor is running.any induced draft unit will work this way.you can also do a temp. bypass of the pressure switch to make sure the contacts on it are closing just be sure your inducer fan is running,and you cant leave it like that its just a test.that is a safety feature you really need.
Posted on Mar 19, 2009
  • 189 Answers
SOURCE: Furnace doesn't reach desired temperature
Yes....... it can freeze if drained outside........ It is always best to discharge the condensate to an inside drain.
The other persons problem could be a undersized furnace for the home. Or Yes it coukld be a faulty installation. Always make sure a permit is purchesed from your towns building inspector. This way you can be reassured that the it is done properly and sized properly.
Posted on Apr 03, 2009
rahul26485
  • 611 Answers
SOURCE: driver for SupraMax 56k external usb for windows vista
this modem is not support the vista you have to go for the win xp or win 2000 i just give the link to download the driver for win xp or win 2000
ok
http://www.hzjdr.com/drivers/diamond/diamond-supra-max-usb-sup2920-windows-2000xp-download-driver-modem.html"
Posted on May 11, 2009
  • 17 Answers
SOURCE: Furnace leaks water on floor when air conditioner is running.
Okay, let do this;
get a wet/dry vaccum set the suction into the drainage and let it **** it.
it should solve your problem.
nguyen@ite.net
Posted on Jun 09, 2009
Bryant plus 80 furnace no fan/ operation , yellow constant flashing light code , power to furnace was rerouted during remodel and since then furnace stopped working. Any suggestions ?
You need to have/ know the "fault code" chart for that specific furnace. Count the number of flashes and refer to chart. Look on the inside of the furnace blower door or other panel. Also look up on internet and print it off. If the furnace was allowed to run during the remodel it voids the warranty automatically. Read the installation manual.
Try resetting the electronic board by turning the power off then back on.
Mar 29, 2017 | Bryant Heating & Cooling
Model 393 Bryant furnace fan or motor makes noise when first starting. Then it's quiet.
https://www.repairclinic.com/PartDetail/Bryant-Furnace-Dual-Run-Capacitor/P2914553RS/2386586?ss=a36b380&mr=0
That part is probably going bad. The motor uses it to get moving and when it fails then the motor wont start, makes buzzing or humming noise due to phase loss.
Jan 28, 2017 | Bryant Heating & Cooling
Need to find a replacement part
Here you go Angela
1149097 Draft Inducer Assembly - AllParts Heating
www.allpartsheating.com/1149097.html
  1. Cached
  2. Similar
Draft Inducer. 1149097 draft inducer for Heil, Tempstar, Arcoaire, Whirlpool & Comfortmaker brand model furnaces. This part replaces old part number 1008416.
Arcoaire Furnace Motor Parts: Fast Shipping RepairClinic.com
www.repairclinic.com/Shop-For-Parts/a36b389c53/Arcoaire-Furnace-Motor-Parts
  1. Cached
  2. Similar
Furnace draft inducer assembly. The draft inducer motor draws air into the burner and exhausts it out the flue. If the draft inducer motor is defective, the furnace ...
Arcoaire Furnace Parts: Fast Shipping RepairClinic.com
https://www.repairclinic.com/Shop-For-Parts/a36b389/Arcoaire-Furnace-Parts
  1. Cached
Direct Factory Replacement Inducer Blower Motor Used in 90 ...
www.americanhvacparts.com > ... > Oem Direct Replacement Models > Arco Aire
  1. Cached
  2. Similar
Direct Factory Replacement Inducer Blower Motor Used in 90% Furnaces. ... Comfortmaker, Intercity Products Snyder-General, Heil, Tempstar, Arcoaire Draft Inducer Blower Motor. ... Used in ICP Equipment Models: ... GUH125A016CIN
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor ...
https://www.amazon.com/1149097-Arcoaire-Furnace-Inducer.../dp/B00FFBQRGA
  1. Cached
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor - Fasco Replacement: Replacement Household Furnace Motors: Amazon.com: Industrial ... Draft inducer motor for arcoaire model guh125a016cin Google Search
Nov 27, 2016 | Heating & Cooling
My bryant furnace fan will not turn on. Everything is sequencing, the induction fan starts and the flame lights, but the fan will not turn on. The capacitor reads 4.86 uf. Any suggestions?
Your fan delay relay is not functioning. On most furnace fan controls, there is a fan delay relay that delay the fan from turning on until it senses the temperature increase, typically around 130 degrees. once the relay senses the temperature increase it closes a contact inside the sensor and turns the blower on. It is the same device that keeps the fan running once the furnace turns off. Just take the Model number and serial number to your local dealer and get a fan delay relay and replace it.
Dec 07, 2014 | Bryant Heating & Cooling
Bryant Plus 90 furnace
possible your supply duct leak or break
Feb 11, 2014 | Heating & Cooling
Furnace Keeps Cutting Off after a couple of cycles
Is this a Bryant Legacy?
Can you please send me the model number from the nameplate?
There are parts on Amazon but I need to know the specific model to trouble shoot it.
Nov 14, 2013 | Heating & Cooling
Control board
Hello, check to see if the board is receiving 120 volts at the L1 and neutral terminals, if you are then the board will need to be replaced, if you are not getting power then trace the wirimg back to where the voltage stops, for example could be a bad door switch, fuse, circuit breaker. If it is the board then just write down where all the wiring goes or sketch it out on a piece of paper and then remove the board and take it to a Hvac supply store, that way they can match it up for you and get the exact board you need.
May 08, 2012 | Heating & Cooling
Bryant furnace plus 90 led code is blinking once then 3 times fast. What does it mean?
these codes are on the inside panel of the front cover of the furnace. lift off and look inside.there should be a code explain chart on the panel by the light. this panel will need to be replace correctly for the furnace to work as there is a door switch.
Jan 31, 2011 | Heating & Cooling
Bryant plus 80 heat exchager is cracked, i'm looking for a replacement heat exchanger
Hate to tell you but heat exchangers are hard to match up. Unless it is relatively new then in most cases they have a warranty of 10 years. So you will have to replace furnace. You might be able to find a used furnace or go to web site and enter model number of your Bryant to get replacement.
Oct 23, 2010 | Heating & Cooling
Bryant furnance clicking, won't fire
Mar 11, 2009 | Heating & Cooling
Heating & Cooling Logo
75 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Bill Long
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
