Question about Pass & Seymour #660IGU 15A Ivory SP Toggle Switch
I have the 691pass&seymour toggle switch/outlet, the way the electric was wired over 40+years ago does not look right? but I would like to install this new switch. on the old switch on the right side they have a black wire at the top and a orange wire at the bottom connected. and nothing grounded, in the wall in the back they have 3 black wires in a wire nut with one of the wires going to the old switch,( thats the one at the top.) then they have 2white wires with a wire nut together and 2blue wires with a wire nut together. pushed in the back. my new switch has 2 brass screws on the right for hot and 1brass screw on the top left and 1 silver screw on bottom left and a ground nut at very bottom left. the orange wire travels some place into the conduit? so what should I do?? thank you.
Thank you for the clear description of your P&S device.
You need to test your wires.
We are looking for the Hot, Neutral and Load wires.
Your old switch has two wires.
One of these wires is the Hot (I suspect 100% that the wire that comes from the other wires that are twisted together is the Hot)
The other is Load
Separate the old switch wires and turn on power.
Use ordinary tester.
Test each wire to metal box and see if the box is grounded.
Tester will light up on Hot wire.
You can also test each of the old switch wires to the other wires in the box.
1) Hot: Once you determine the Hot wire, this wire will connect to the P&S device:
Hot connects to the brass screws on right side, just as you said ... and these screws are on opposite side from silver screw.
2) Load: The wire to Load connects to brass screw on top left, which is on same side of device as silver screw. This screw sits opposite the P&S switch.
The last wire is the Neutral.
Test your Hot wire to all other wires in the box.
When the tester lights up, that is the Neutral
3) Neutral connects to silver screw which will complete the circuit to the P&S receptacle.
http://waterheatertimer.org/How-to-select-right-wire-nut.html
Posted on Nov 09, 2010
I'm want to install a toggle switch/outlet but have 2 white wires and 1 black. It's a Pass & Seymour 691-WCC6 switch. Can I install this switch?
More information is needed.
Unknown what wiring device was there before, and which wires were connected to which screw terminals.
Wire color is not as important as knowing what wire is for.
If both white wires were connected together before, then they need to be put back same way.
Separate wires. Turn on power. Test each wire to bare ground. Tester lights up on Hot wire. The Hot wire is usually black.
In back of box are white wires twisted together and covered with wire nuts. These are the neutrals.
Test black hot wire to neutrals and tester will light up. If box does not have neutrals, then device cannot be installed to code.
Open following link for illustration of wiring:
http://waterheatertimer.org/How-to-wire-combination-switch-outlet.html
Aug 01, 2011 | Pass & Seymour #660IGU 15A Ivory SP Toggle...
I am replacing an existing switch/single outlet, the outlet was always live.the switch controlled a light. the existing sw was very old and only has connections on the back top.. The left had 2 white wires...
White wires under the silver screw...
The black wire under the black screw...
and the red wire under the brass screw...
If it does not work right then switch the red and black wires...
heatman101
Apr 20, 2011 | Pass & Seymour / Legrand 1595-2SWT...
I have the 691tr-icc6 outlet/toggle. I would like the switch to control the outlet below it. So I can turn on and off the outlet as needed. , Where do I put the black and white wires that come to the...
You have switch plug combo with dark screws, brass screw, and silver screw.
Dark screws are for black Hot wire coming from breaker box.
Brass screw is wire going to Load that you want to turn on-off.
Silver screw is for white Neutral wire coming from breaker box.
To set up so switch controls outlet, you need 2 dark screws on one side of device that are connected by break-away fin.
Remove fin so dark screws are no longer connected.
One dark screw goes to switch, one dark screw to outlet.
Hot black wire connects to dark screw for switch.
Connect jumper wire from brass Load screw to the dark screw for outlet.
Connect Neutral wire to silver screw.
To test for Hot and Neutral:
Separate wires.
Turn power ON.
Test each wire to bare ground wire, tester lights up on Hot.
Hot is identified.
Test Hot wire to all other wires except bare ground, tester lights up on Neutral.
Mar 28, 2011 | Pass & Seymour #660IGU 15A Ivory SP Toggle...
I have a dispard switch wall plate mountung strap with a dispard toggle switch in the middle and with two recepticle outlets, on top and bottom and the stack. Looking for a wiring diagram, and how is the...
Assuming that you are planning to use the push in connectors then if you have four connections they are normally in two groups of two. Each group is connected to a single pole of the switch so you place one wire in either hole of each group. The switch will toggle simple on/off capability
Jan 11, 2011 | Pass & Seymour Acd1cc Despard Single Pole...
What if the light that is being connected has been added, thus the reason for the outlet being converted from 2 plugs to now 1 with a toggle?
I don't exactly understand your question, but to control that light using a switch you have to have two sets of cable one coming into your switch box and one going out of it. Tie your two whites together and the two black wires go on your switch, whereas on a receptacle black and white wires go on the terminals.
Jun 20, 2010 | Pass & Seymour #660IGU 15A Ivory SP Toggle...
Need to find out how to hook up a toggle switch/outlet
You can't, not without running an additional wire. The black and white pair of wires that you have is most likely routed from the ceiling fixture. The black wire would be the hot wire coming to the switch and the white is the switched hot wire returning to the fixture. You don't have a neutral available at this location, so you can't make the outlet work, just the switch. ----- Sorry for the bad news. Thanks for using fixya. Al Kupchella
Apr 30, 2010 | Pass & Seymour #681ICC6 15A Ivory...
How do I install a Pass & Seymour Nightlight/ Outlet? I used to have one regular outlet with 2 receptacles and two sets of hot & neutral wires. When I attempted to install the NIghtlight/ Outlet,...
The wires that you taped up are most likely the wires that feed that outlet and the outlet that isn't working anymore in the bathroom. The proper way to fix your problem would be to do one of the following:
Turn off all electrical power to that circuit. If you are unsure, turn the whole panel off. The inconvenience of resetting your household clocks isn't worth your life.
1) If the screws on your new outlet have spaces for two wires, reattach the disconnected wires under the same screws as the ones feeding the new outlet.
2) Cut yourself a 8" piece of black, white and green or bare copper wire. Disconnect the wires feeding the new outlet. Twist all three wires together, color to color and twist a wirenut on each connection. You should have the three black wires twisted together, the white wires twisted together and the green or bare wires twisted together. Now take the 8" wires and reconnect them to the outlet. Black going to the bronze screw, white going to the silver screw, and green or bare going to the green screw.
Oct 18, 2009 | Pass & Seymour #1595NTLICC4 15A Ivory GFCI...
How do i install a combination toggle & outlet switch. Is there a piece I have to remove in the switch? I removed the old switch. One black on left top above nickel post. One black on nickel post. ...
If I understand you question (if not please clarify) you have a switch and outlet combo and you have a box with a black and white coming in one side and a black and white going out the other side. Here's the deal the switch side only deals with the black (hot) lines but the outlet needs a common (white) line so there should be two brass posts the black coming in goes to the bottom brass post and the black going out to the light goes to the top. You should now have two silver posts and these take the white lines they are common to each other (electrically speaking that means they are two ends of the same wire to put it simply) In the event you only have one silver post tie both whites to that one. if this was a switch box the two whites would be tied together with a wire nut and shoved in the back.
good luck I hope this helps.
Mar 25, 2009 | Pass & Seymour #660IGU 15A Ivory SP Toggle...
Pass & Seymour #660IGU 15A Ivory SP Toggle Switch Logo
148 people viewed this question
Top Pass & Seymour Electrical Supplies Experts
ken skalski
Ottoniel
Mike
Are you a Pass & Seymour Electrical Supply Expert? Answer questions, earn points and help others
