Question about Teac CD-RW880 CD Player / Recorder
When I try to record, I get a red siganal that says "over". Cannot record!!
    Sergeant:
    Champion:
  • 277 Answers
It might be copyrite risticted
Posted on Nov 08, 2010
How to connect Sky digibox & DVD recorder to Samsung UE46ES6300 TV
Buy 2 hdmi leads and use one to connect sky TV decoder to the hdmi 1 socket on the back of the TV and if your DVd recorder has an hdmi socket attach it to hdmi 2 or leave it on the scart socket
as you don't name your dvd recorder the connections available are unknown
hdmi is the best followed by component which requires a 3 cable lead 3 video (video is red green blue plugs ) audio is red and white which is a 2 wire lead which all are needed to get video and audio to your TV
scart is the lowest quality along with composite video
Jul 04, 2017 | Televison & Video
Tip
Philips CDR870
I think there are several other possible solutions for the Philips CDR870 which will make it record more reliably, although using the "proper" Music Disc and cleaning the laser lens with an appropriate lens cleaning CD, seem to be the best ideas. Also, try wiping the blank or partially blank CD using a lintless microfiber cloth from the center outward to remove smudges and fingerprints. Several "failed" discs miraculously recorded after wiping.
If you're willing to "go under the hood", (you;ll need a #10 Torx screwdiver to remove the cover screws), you might try gently vacuuming the inside of the unit, brushing components gently with a soft camel hair brush to dislodge any dust that has accumulated; then gently sucking it into the vacuum cleaner. Make sure you've disconnected power to the CDR870 first! Trying to reach the laser lens itself involves surgical like dis-assembly of the sub-chasis and technical skills way beyond those of the average techie. I strongly DO NOT advise it!
Another possible solution is to let the unit "warm up" for about a half hour prior to recording, this may "cook" some electronic parts, and maybe change an internal condition to reduce the "OPCFAIL" problem.
You might also try cycling through "Input Source" by repeatedly toggling the Input Button (19) from DIG COAXIAL - DIG OPTICAL - ANALOG. Sometimes this allows the electronics to "wake up". It also may help to be playing an actual input signal into the unit while trying this.
I, too, have had frustrations with the unit using several brands of consumer and professional grade CD's. Occasionally, I have been successful in getting the unit to record music onto CD-ROM Data Discs when it's not supposed to. I have recorded onto Maxell, Sony, TDK and Discmakers (professional) blanks with varying results. FYI Radio Shack now stocks Verbatim brand discs for Music Recording (about $10 for 25 pack). Make sure CD Recordable Discs say "Music" or "Digital Audio" on the outside wrappings. I am a professional recording engineer, and now plan to see if the manufacturer, Philips Consumer Electronics in KY, can help.
Good Luck with this problem, I'll keep watching this site for other solutions.
on Mar 14, 2014 | Philips CDR870 CD Recorder
Tip
How to record a program you are watching on your cable satellite receiver.
Hello,<br /><br />Most of the time we watch TV programs with our cable satellite receiver/decoder. And sometimes we would love to record these programs so that we can watch them again. You can learn how to record your TV program while you watching a TV program. <br /><br />All you will be needing is a DVD recorder or VCR (Video cassette Recorder). It all depends on the one you prefer.<br /><br />There are two methods of doing this connection. 1. is RF connection and the other is RCA. But I will start with the RF connection method;<br /><br />This is how is works. Get a RF cord, check the back of your TV, you would see RF in, connect the RF into TV in, then connect the other part to RF Out at the back of the Cassette or DVD Recorder.<br /><br />Turn the Cassette or DVD Recorder and the TV on. Go to Channel 1 or any channel on the TV, search the TV stations automatically or manually in order to get a display of the Cassette or DVD Recorder on the TV. To easily get the Cassette or DVD Recorder's station, play a movie on the Cassette or DVD Recorder while you search for the station. Once you see the display of the movie on your TV, you would easily know that that's the Cassette or DVD Recorder station. <br /><br />Once you have gotten a display from the Cassette or DVD Recorder, save the channel on the TV.<br /><br />Then get another RF cord, connect it to "RF out" at the back of the Satellite/cable decoder/receiver and the other part to "RF in" at the back of the Cassette or DVD Recorder.<br /><br />Now with the Satellite/cable decoder/receiver turned on and the Cassette or DVD Recorder also turned on, press the Cassette or DVD Recorder's channel, you should find search. Scan for channel/stations on the Cassette or DVD Recorder just like you did on the TV and you will find a display of the Satellite/cable decoder/receiver showing on the TV via the Cassette or DVD Recorder. Note that on some Cassette or DVD Recorder, you will have to select "Source" to RF before you can get a display of the channel.<br /><br />Now since the Satellite/cable decoder/receiver program is now showing via the Satellite/cable decoder/receiver, insert a black disc or cassette into the Recoder and press record. The Satellite/cable decoder/receiver programs showing on the TV via the player will be recorded and that would be all.<br /><br />For some recorders that has internal hard drive, you can just press record without inserting a blank disc......<br /><br />USING RCA CONNECTION METHOD.<br /><br />You could also achieve this by using a RCA (yellow, red and white cord).<br /><br />The connection procedure is the same with the RF explained above.<br /><br />Connect the Recorder to the TV. That is, from "Video and audio Out" of the recorder to "video and audio in" of the TV accordingly. Press AV or source on the TV to confirm that there is a display from the recorder on the TV.<br /><br />Now connect the RCA cord to "OUT" from the Satellite/cable decoder/receiver to "IN" at the back of the Recorder.<br /><br />Then, press source on the recorder to "INPUT" (RCA) and the Satellite/cable decoder/receiver's program will automatically display on the TV. <br /><br />While the Program is being displayed on the TV via the recoder, insert a blank disc and press record on the player and it will automatically start recording. You will see the record or record symbol while the recoding is in progress.<br /><br />I hope you understand the above. Please follow steps closely and you won't have any problems.<br /><br />Good luck.
on Mar 09, 2011 | Televison & Video
Sony dvd recorder repair
try cleaning the disc and reload. i have that problem too. If it's a dvd recorder your disc might have a chip in it which thinks you are trying to copy it . try it on another dvd player without a recorder cability
Jan 11, 2012 | Televison & Video
Trying to record but when I push the "record"
Get the manual...
http://tascam.com/product/cd-rw750/downloads/
Record READY switches the unit into a Monitor mode so you can set your levels for when you finally initiate recording.
Jul 28, 2011 | Tascam CD-RW750 CD Recorder
I have a RCA VR5320R digital voice recorder. My voice recordings are stored on the recorder, under folder "A," but when I attach the recorder to my computer, eventhough the device shows up under...
Your best bet is to play the recordings through the headphone connector to a pc audio line-in connector and capture the audio using something like Audacity. Then output them using audacity to mp3 to play on your mp3 player.
These units are notorious for their failing USB feature.
Mar 09, 2011 | RCA VR5220 Digital Voice Recorder
I am trying to copy a VHS to DVD from a VHS player. I have a Sony VRD-MC6 multi-function DVD Recorder. I am using the A/V cable and have verified that they are correctly placed. The Sony player will...
Is it possible the VHS you're trying to copy is copy-protected? Apparently, the MC6 displays "waiting for signal" when you're attempting to copy a copy-protected (commercial) video. I had success converting my own homemade VHS tapes. I just bought my MC6, and thought I'd pass along some tips I got from others: You know you're recording when a red ring around the large Record button lights up and it actually says "recording" on screen, and adjust HQ to SP to get 2-plus hours of video on the DVD.
Jan 24, 2011 | Sony VRDMC10 DVD Recorder
How to write a code of a combobox
Try this code:
Combo-BOX - Abstraction With function you can retrieve the combo-box
structure with its data
<?php
function GetCombo_Where($db, $nombre, $tabla, $campo_lista, $campo_graba,
$campo_seleccionado,$valor_seleccionado,$where)
$query="SELECT * FROM $tabla ";
$query.=($where)?"WHERE ".$where:"";
$db -> query ($query);
$cant_registros = $db -> num_rows ( );
$string = "<select name=".$nombre.">";
if ($seleccionado=="")
$string .="<option></option>";
for ($i=1;$i<=$cant_registros;$i++)
$db -> next_record ( );
$value = $db -> Record[$campo_graba];
if ($valor_seleccionado == $db -> Record[$campo_seleccionado])
$string .= "<option selected value = ".$value." >";
else
$string .= "<option value = ".$value." >";
$string .= $db -> Record[$campo_lista];
$string .= "</option>";
$string .= "</select>";
return $string;
hope this helps.
Thanks
Shafi
May 08, 2009 | Computers & Internet
Don't know how to use MWR10D6
{quote]i AM LOOKING FOR A FREE DOWNLOAD FOR MAGNAVOX DVD RECORDER MWR10D6 -- OR -- A OWNERS MANUAL FOR THE SAME[/quote]
http://homeappliance.manualsonline.com/mdownloads/4e6992c3-f428-e9f4-c50d-9c48ee7a9c30.pdf
Feb 06, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Teac CD-RW880 CD Player / Recorder Logo
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
