Question about HP Pavilion dv6000z Notebook
Need know power supply - HP Pavilion dv6000z Notebook
  • lesbeach478 Nov 08, 2010
    need know input power supply
Need a power supply
I use the adjustable power supplies you can get at Radio Shack.
Nov 05, 2012 | Computers & Internet
Dell DPS-1200EB A REV :01 I need to know which prong provides 12v power at 100amps. The power supply is from a poweredge 1855 i think. and i want to use it to power my big car amplifier. so i need to...
As an audiophile and former hardware engineer specialized in switching power supplies, this would be the last thing I would do in my life.
Switching power supplies are noisy and when used in a power amp they will deliver horrible sound quality.
Mar 22, 2011 | Dell (DPS-1200EB) (F5323) 1200-Watt Power...
I have the CAD ST100 microphone i need to know the power to supply this and pin outs.
The ST 100 microphone is a phantom powered unit. So, it receives its power by the same terminals used for its connection, not needing a separated power supply.
In general, most mixing consoles offer the option to feed the balanced microphones with 48 volt via a switch that can turn on or off its internal phantom power supply.
If you are going to use the ST100 microphone with a common amplifier or mixer, you will need to buy a separated phantom power supply. Searching the Internet for "phantom power supplies", you will find many available models and brands.
To know a little bit more about these power supplies, please check the following link:
http://en.wikipedia.org/wiki/Phantom_power
Mar 09, 2011 | CAD Microphones ST100 Professional...
I need to know exactly what voltage of power
Dear,
Power Supply 100–240VAC, 50–60Hz
Power Consumption 232W max.
Its mean its a switching supply that can support as low as 100 and more as 240VAC
If there is a problem with supply and you want to attach a fix one then Check the MAINS at your area. If it is 110VAC then get it and if its 220VAC then use the supply for this kind of support
good luck..........
Jan 30, 2010 | Televison & Video
Where can I find the spec of the ptgd-vx sony Vaio
Not sure really what you are asking.
As a general rule, I use a 350-400 watt power supply in my systems.
This is adequate power for most modern machines (gaming machines would be higher). The motherboard doesn't care what size power supply you put into the machine. It gets the same voltage from any of them. The power supply must have the proper power plugs to fit the motherboard, however. All modern power supplies will have what you need.
Check out your graphics card, too. It may require power from the power supply.
If this helps, be sure to rate the answer, please.
Mar 14, 2009 | Sony Computers & Internet
NEED POWER SUPPLY FOR ELITEGHROUP L7VMM2 MOTHERBOARD
There is no specific power suppl that you need. The only differce is the wattage 300, 350 , 500 etc. Your motherboard will work with all types not to worry. The only reason you get a higher wattage power supply is if you plug in a lot of stuff. say you have 3 HDD and 2 CDROMS then you would need the 500 Watt power supply.
Jan 05, 2009 | E-Machines (ATX-300GT) (ATX30012) 300-Watt...
HP Pavilion dv6000z Notebook Logo
24 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
