Question about Cameras
Frame number full
The same thing happened to my camera too and I tried your way, but it didn't help! what should I do?
  • jeeper446 Nov 08, 2008
    frame no.full
When i turn on the camera I get a frame no. full, I tried formating the memory card to no avail. I can't take a picture with this error
Posted on Nov 08, 2008
  • 198 Answers
Your question is not full... please give extra information... what way u tried on your camera...please be specific
Posted on Jun 16, 2008
What does it mean when the camra says frame full
Hi, in most cameras by defult the camera names the pictures it takes in numeric sequence and after a while the range of names reaches an end and the camera would give similar message... if you go to the setup menu look for something like frame number or picture count and see if it is set to continious, see if you can switch it to reset or renew and see what happens... hope that helps :)
Jan 29, 2011 | Fuji FinePix J10 Digital Camera
My FinePix S1800 Fujifilm Digital SLR camera says Frame No. Full''
Go to set up then Frame and change to RENEW. It is probably on continuous. My camera did the same thing and this solved it.
Apparently even thought the card is empty if it is on continuous it will start the picture numbering where you left off last time.
Mar 03, 2010 | Fuji Photography
Frame full
I had the same problem with a fujifilm camera, the good news is that it's easy to fix. On the shooting menu (press menu when the camera is in shooting mode) there will usually be a set-up option, within that you should see "Frame No." or something similar- the two options for this are either "continuous" or "renew". If you are experiencing the Frame no. full error it means that you are currently set to continuous; TO SOLVE THIS PROBLEM SWITCH THIS SETTING TO RENEW.
Hope this helps!
Apr 05, 2009 | Fuji FinePix Z5fd Digital Camera
Fuji finepix a900 Frame number full error
In case you haven't sorted this out yet.
To fix this go into Menu ---> Setup. From there there's a Frame Number setting. It is normally set to: Continuous. The other option is: Renew which evidently simply resets the picture count. After selecting Renew the error message disappears and the camera works perfectly again.
Great little camera!
Mar 17, 2009 | Fuji FinePix J10 Digital Camera
Fuji frame no full
I had the same problem. Here's what I think is going on: the camera has a finite set of numbers that it can assign to pictures. If it is set to "continuous," then every picture that you take gets assigned a new number (even after you delete them off the card). To fix this, you need to set it to "renew" the picture numbers. Here's how to do this: Menu --> Setup --> Frame No. --> Renew.
Hope that helps!
Dec 14, 2008 | Fuji FinePix V10 Digital Camera
"Frame NO. Full"
Try going in to the "setup" menu and change the frame numbering from "continuous" to "renew", if it is not already done. Sounds like you are on the continuous setting which keeps adding numbers, even though you've erased many. Going to renew starts the numbering over so it keeps reusing previous numbers.
Jul 06, 2008 | Fuji FinePix Z100fd Digital Camera
Fuji finepix s7000
Per the owner's manual:
  1. Insert a formatted media into the camera.
  2. Set "RENEW" as the FRAME NO. setting in the SET-UP menu.
  3. Start taking pictures. (the frame numbers start from "100-0001".)
  4. Set "CONT." as the FRAME NO. setting in the SET-UP menu.
Then you're done. We just did this on ours and now we're ready to go. God Bless.
Jun 05, 2008 | Fuji FinePix S7000 Digital Camera
Vivitar vivicam 5100--frame #
You mentioned that the camera has had a lot of abuse. I assume that means you did not take a lot of care with the camera.
Remember that a digital camera is very delicate. It will not stand under abuse very long.
Treat your digital camera like you are dealing with eggs, and it will last. Of course things do happen, it is mechanical, and things do burn out, and wear.
If you would use the wrist strap to hold the camera, the chance of dropping a camera is lessened. Putting it in a padded case will indeed help to preserve the delicate parts.
If you want to toss the camera in a box, and treat it with very little care, then maybe you should use a cheap camera.
May 24, 2008 | Vivitar ViviCam 5100 Digital Camera
Frame no full
try emptying the memory card & phone memory then give try ... if same problem persists then may the software of the camera may be corrupted .... you give for installing the software in the show room where you purchased or ur model named show room...
they may charge some 300 to 500...
Feb 07, 2008 | Fuji FinePix Z100fd Digital Camera
After one frame battery icon flashes ( battery is full charged)
The problem is with the electric contacts between the battery and the camera. You can try cleaning them with a clean pencil eraser. Make sure you don't leave any eraser debris in the battery compartment. It is best to do this while holding the camera so that the battery compartment door is "down" so that any eraser debris will fall out of the door onto the table rather than fall into the compartment.
Oct 13, 2007 | Canon EOS-1D Mark II Digital Camera
Cameras Logo
489 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
