Question about Xerox Phaser 3500/DN Laser Printer
My Phaser 3500 has served well for years, but now image is degrading especially down one side, new toner and fuser had no effect, what else could it be?
There is a laser that can be covered in toner that is located under the top cover. If you remove the toner cartridge and feel under the top cover, you should feel a credit card width slot that extends over the length of the toner bay. If you fold some paper or use a cloth, you can fit this into the slot. This might not appear much debris or dirt however this dramatically improves the quality of the print and makes the image much darker and clearer. Hope this help!
Posted on Feb 09, 2011
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Sergeant:
  • 185 Answers
The drum on the toner cartridge may need to be replaced
Posted on Nov 08, 2010
My phaser 6180 color printer, toner not adhering to paper
hi.it could be your print cartridge.end of life.and very costly
Nov 19, 2013 | Xerox Phaser 6125 Laser Printer
Tip
Xerox Phaser 6110 Banding Cure
As usual, my Phaser 6110N (light use, home office network duty, printed less than 2000 pages in the 4 years or so I've had it) developed a banding issue. Rather than invest in a new toner unit, I decided to take it apart and have a look at it. What I discovered is the toner feed mechanism was clogging up and not distributing toner to the imaging drum.
This is a messy job, I did it in the bathtub (dry of course!), and it's simply a case of removing the side covers from the imaging unit (I'd recommend putting the drum in a thick black plastic bag to prevent overexposure) taking care not to lose any parts, and sliding the toner feeders out of the unit. You can then remove the top cover and it will allow you to clean out the mechanism with a small dry paintbrush.
Remove just enough to de-clog the mechanism, and especially the feed conveyor at the back - this takes toner from the cartridge and feeds to the roller screws that feed the imaging drum.
If you've only got banding problems with one colour, only de-clog that particular colour. It's messy and no point wasting expensive toner! Black and red where problems for me, in both cases the conveyor mechanism was chock full of toner and there was very little in the feeder roller screws.
Re-assemble the imaging unit and run a couple of test patterns through the printer. You'll probably find that the first few pages are especially faint - when you first power up the printer from new, it fills the feed mechanisms from the toner cartridge, I haven't found a way to make it do this again (maybe someone can hack together a maintainence firmware update?). The more you emptied from the feeder, the longer it'll take to even it up. Once it's got the page mostly covered, you're back in business.
After I'd done all this, my banding problem went away! Of course, the bath was covered in toner dust and it took a while to get rid of it all!
on Jul 07, 2011 | Xerox Phaser 6110 Laser Printer
I have a problem with the fusor xerox phaser 6125, the display say error 010-397 please help me
That is in fact a problem with the printers fuser, which melts the toner to the paper. You should replace the fuser (part# 675K65654). To replace it open the front door, and at the top right you should see a gray clip you push down and then slide the fuser out starting with the right. When installing the new fuser slide the left side in first and then the right. Iteminc.com has this part in stock and ships same day. Hope this helps, good luck. Thanks for using FixYa!
Aug 08, 2011 | Laser Phaser 6125 Colour XEROX Phaser...
I have a Phaser 6200 Printer and when I print the left side of my copy is very faded. Can you help me?
This could be an issue with several different components. It could be the toner, fuser, or imaging drum. I recommend first replacing the toner as this is probably the cheapest component. After that try replacing the fuser. Fuser kits for this model can be bought off Xerox directly, same as the imaging drum, which is the last thing to think about replacing. It is most likely a problem with the fuser. Parts found here.
May 09, 2011 | Xerox Phaser 6200DP Laser Printer
Phaser 7300DT, all of a sudden my yellow only prints at the very bottom solid and then really faded throughout the rest of the sheet. The imaging unit is at 54% life remaining and toner is says more than...
Remove the yellow toner cartridge and shake from side to side while keeping the cartridge level. Sounds like the remianing toner in your yellow toner cartridge is not evenly distributed.
Jul 28, 2010 | Office Equipment & Supplies
The black print jobs have a shadow about 3 inches down the page
I had replaced the fuser - no improvement. I removed the fuser, imaging unit & transfer roller. CAREFULLY using a vacuum cleaner I cleaned all units and the internals of the printer, rotating the roller on the imaging unit to clean all parts. (Warning Place Imaging unit on paper as toner escapes) After a few test prints the page cleared and duplicate ghosting cleared.
Apr 07, 2010 | Xerox Phaser 6360 Laser Printer
Phaser 7300 - one color fading on diagnostics page
Are you using third party toner? That is one thing that causes that problem. Use only xerox toner.
The other thing is that your image unit could have come defected, if it was brand new. Try changing the image unit and that should fix that problem. Good luck. 016-1993-00 image unit & toner 016-1977-00
Oct 02, 2009 | Xerox Phaser 7300DN Laser Printer
3500 n printer
You can get the Fixing Film Sleeve changed you dont have to change the whole fuser assembly
ban_fuserfilmsleeves.jpg HP LaserJet 3500 Fuser Sleeve Manufacturer: Hewlett Packard
HP LaserJet 3500 Fuser Sleeve - (Fixing Film Sleeve) $59.95Contact : kathy@printersupplies.com
cb_transparent_l.gifus.gifspace.gifspace.gifarrow.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gif800-551-1943cb_transparent_r.gif Mon - Fri 8:30 - 5:00 CST
Sep 11, 2008 | HP Color LaserJet 3500 Printer
Xerox Phaser 6250
How Brave is Jan?
Doubt it be the fuser(100 000life), "just magenta dots".... fuser would be "all smudged" or "black marks" , "the print rubs off" , "paper is creasing or jamming"
Can prove it by stopping a print (open door) when paper is1/2 way threw machine, you need to stop it before it goes threw the hot bit, so you can tell if the hot bit (fuser) puts the marks on the paper.
Transfer roller one would expect to effect whole print Smudged/Faint,uneven density
It will be the imaging unit ( 30 000 pagelife Ouch$ ) or possible leaking toner (if aftermarket)
Remove imaging unit and inspect film you should find image of lines, dots are usually chips or sticky stuff on drum surface, carefull no oily human fingers on surface please.
When stopping machine mid print and perfecting your timing, pull out the imaging unit and look at replica of your print notice if marked and where.
Hope this helps
Nov 19, 2007 | Xerox Phaser 6250 Laser Printer
Xerox Phaser 3500/DN Laser Printer Logo
151 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
