Question about Zyxel P660HW-D1 Router
How to confiureg my router using internet cable only no DSL connection being used
Coldcut
  • 1554 Answers
SOURCE: Wired connection is fine but cannot get internet access - virgin media
Connect the routers Wan connection to the modem
Posted on Jan 26, 2008
tech curly
  • 298 Answers
SOURCE: No DSL or Internet light
Does your mac book has a phone port? You can try that to setup a dial up connection an see if it will work.
Posted on May 20, 2008
crapiemael
  • 241 Answers
SOURCE: no internet connection. I bought this embarq 660
You can't just connect up a new router to some ISP's (internet service provider) and expect it to work. My ISP requires the MAC address of the router before it can access the internet. Call your ISP and tell them what your doing. The MAC address is the physical hardware address of your router (there is no other one the same in the world). The MAC address is on a sticker on the router and consist of 12 numbers and letters.
Posted on Nov 18, 2009
SOURCE: I have a Zyxel P660HW-T1
For that you need to change wireless channel type in router. You can also configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on wireless->wireless channel type to 3 or 6 or 11 then save settings and restart router. . Let me know if you need further assistance. Thanks for using FixYa.
Posted on Jun 22, 2011
Testimonial: "Thanks, that seems to have sorted it, fingers crossed!"
junedahmed
SOURCE: Connects but no internet connection being allowed through.
my ps3 connects to my ZEXel router only when i reset my ps3 settings and started my ps3 settings from scratch, however the connection cuts on after 5 minutes of being connected to the ps3 and thats connected via cable. please help, unable to play my ps3. :(
Posted on Jul 02, 2012
Wireless antenna or wireless router
Did your ISP Boingo supply you with a DSL or cable modem with a built-in wireless router? If only a DSL or cable modem is supplied and you wish to connect to the Internet by wireless then you need to connect a wireless router to this DSL or cable modem.
You can connect to the Internet using a LAN cable from your laptop to the DSL or cable modem.
If your laptop as a built-in wireless card you can to the Internet via the wireless router.
If you laptop does not have a built-in wireless card then you can install a PCMCIA wireless card into the card slot of your laptop to the Internet via a wireless connection.
Nov 01, 2012 | Toshiba Computers & Internet
No interent connection
Your Linksys wireless router needs to be connected to a DSL or cable modem which needs to configured with the settings that your Internet Service Provider gave you.
To test your Internet connection connect a LAN cable fron your conputer to the DSL/cable modem. If you cannot connect to the Internet using this methos, you need to contact your ISP and the can check the connection to your DSL/cable modem.
Apr 12, 2012 | Linksys Computers & Internet
Won't connect to internest.
first there should be 2 cables connected the device.
1) power adapter
2) ethernet cable from either a dsl modem or a cable modem connected to the wan connector
with most cable modem service its usually dhcp meaning you are always connected to the internet
with some there is ppoe connection where a user name and password is used to make a connection to be on the internet with the dsl modem
there are some dsl companies that are dhcp just like the cable modem companies.
with the ethernet cable connected the wan port on your router there should be some kind of activity light on the router but check with the type connection from your dsl or cable internet provider. also you will need a second ethernet cable to connect your computer to setup and configure the wireless settings and wep protection.
need more info?
Aug 24, 2011 | NetGear WNR2000 Wireless Router
Not able to connect with internet using my router
Had this work before?
If yes, and you're using Cable modem then just Power cycle the Linksys router by unplugging / plugging the power cord.
If not, then you have to configure it with the correct settings for Cable and DSL ISP connection.
Check you physical connections; Modem (cable or dsl) - to Linksys (WAN or Internet port) - then plug (wired) your PC to check internet connection.
Good Luck!
Angel
Jul 09, 2010 | Linksys Wireless-G Broadband Router
Router config
Yes you can use this router to a DSL or Cable Internet Service, so it will be fine if you switch from cable to DSL......
Nov 13, 2009 | Linksys : WRT54GX4 Wireless-G w/SRX400...
Can I use my router just as a Wireless router with a DSL .
i doubt it will work. most times the cable companies give you a modem/router all in one box. the problem is there in no inbound connection to recieve an internet signal other than the cable cord connection. with the dsl modem you will need a seperate router. they cost around $40-50 on avg
Feb 05, 2009 | Arris SURFboard SBG900 Wireless Router...
Connecting DSL/Router to DIR-628 internet router.
it is possible but the routers have to be on separate channels
Jan 14, 2009 | 2wire HomePortal® 1800HW Router...
After successful instn of my linksys wireless router i cannot access to wireless online connection
Whenever you connect a different device to the cable/DSL modem the modem itself must be reset. Dont even waste a phone call to linksys. Its useless.
If you are using DSL depending on your ISP you may have to enter your account info into the router's PPoE section
Cable users should have the router set to "Obtain IP aadress automatically"
Use the reset button on the back of the router and start from scratch.
Unplug the cable/DSL modem power
Hook up your router WAN/Internet to the Cable/DSL modem Ethernet/LAN jack
Power on the Cable/DSL Modem first, wait about a minute, then power on the router.
Sep 25, 2008 | Linksys Wireless-G WRT54G Router
CAN A 2WIRE DSL ROUTER WORK WITH A CABLE INTERNET CONEECTION
The 2wire dsl modem/router cannot be use with a another cable modem , since this 2wire device is also a modem/router and its made for the DSL conenction that's why it wont work with Cox cable, the best thing that you can do is to ask Cox to give a wireless modem/router like this 2wire so you can still use the wireless connection of your computer..
Hope that helps..........
Sep 06, 2008 | 2wire (1000-400108-001) Router
Ic help
Scenario 2 to 4: Scenario 2) The modem does not have an Ethernet port. The modem is a dial-up modem for traditional dial-up service. To use the Router, you need a cable/DSL modem and high-speed Internet connection.
Scenario 3) You cannot use the DSL service to connect manually to the Internet.
After you have installed the Router, it will automatically connect to your Internet Service Provider (ISP), so you no longer need to connect manually.
Scenario 4) The DSL telephone line does not fit into the Router’s Internet port.
The Router does not replace your modem. You still need your DSL modem in order to use the Router. Connect the telephone line to the DSL modem, insert the setup CD into your computer, and then follow the on-screen instructions
Apr 19, 2008 | Linksys Wireless-G WRT54G Router
Zyxel P660HW-D1 Router Logo
175 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
