Question about Casio FX-115ES Scientific Calculator
How do you find degree minute seconds on calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
To convert a decimal degree value to degree-minute-second, press the o'" key just above the ENG key.
Posted on Nov 08, 2010
  • 8068 Answers
SOURCE: degrees seconds and minutes
Sorry, text was posted as clarification request. Here it is
You have a key, the label of which is the degree sign, the apostrophe and the double quotation mark. It is located between the change sign key (-) and the [HYP] key.
To enter an angle with degrees, minutes and seconds you use the key to separate between numbers
Ex: 18 deg 0' 45" you press 18 [Deg ' "] 0 [Deg ' "]45 [Deg ' "] [=] As you type the calculator displays 18 deg 0 deg 45 deg but the result will show correctly. You have to press the key after the seconds figure, otherwise you get a syntax error.
While the foregoing result is still in answer memory, if you press the [Deg ' "] key the result will be displayed in decimal degrees.
The key is used to enter the DMS values and also to toggle between DMS and D.D.
Posted on Jan 20, 2010
  • 8068 Answers
SOURCE: How do you put degrees, minutes and seconds
To access the DMS symbols
  1. Turn calculator ON
  2. If you see no icon menus, press the [MENU] key.
  3. Use the arrows to put focus on RUN icon or RUN/MAT for the newer versions, and press [EXE]
  4. Press the [OPTN] key to display tabs in the lower part of the screen.
  5. Use the F6 key to cycle through all the tabs.
  6. Locate the one marked [ANGL] and press the key below it (may be F5).moz-screenshot.png
Here are two screen captures to show you the contents of screen
Posted on Jul 31, 2010
  • 3 Answers
SOURCE: sir i want to know
Since one degree is defined as one three hundred sixtieth (1/360) of a circle .Where as 1minute is (1/60) part of a degree and 1second is (1/60) part of minute .They have following relation : 1 degree = 0.0167 minute = 0.000278 sec . You can convert them easily using your calculator .
Posted on Aug 22, 2010
  • 102366 Answers
SOURCE: how do i convert a
Use the key above the ENG key to enter a value in DMS form, ending each portion with the key. To convert it to decimal, press SD once (or twice if you get a fraction the first time).
Example: sine of 12 degrees 15 minutes:
sin 12 *** 15 *** =
where *** is the DMS key.
Posted on Sep 27, 2010
  • 8068 Answers
SOURCE: I need to be able
Posted on Jan 09, 2011
How do I input Degrees-Minutes-Seconds to convert to Degrees? Vice-Versa.
On any calculator, let's convert degrees-minutes-second to degrees and then we will do the reverse.
Let's start with the number of seconds in a minute - 60, so we must take the seconds and divide by 60 to get the number of minutes. Next, add the number of minutes. The number of minutes in a degree is 60, so we take this total and divide by 60. Now we add the number of degrees to get out final answer.
Example: 35 degrees 50 minutes 32 seconds
(32/60 + 50)/60 + 35 = 35.842222 degrees
Just out of interest, let's start with 35.842222 degrees and convert it to degrees-minutes-seconds. We know it is 35 degrees, the whole number. Now we have to determine the minutes and seconds. Start by subtracting 35 to get the decimal 0.842222. Now multiply by 60 to get the number of minutes. I get 50.5332. Subtract 50 from this and multiply again by 60. I get 31.9992, which rounds to 32 seconds.
Good luck.
Paul
Jul 06, 2015 | Texas Instruments TI-36 X Solar Calculator
How can i convert decimal in degrees, minutes and second
I don't think I have that calculator, but let's work through it with any calculator.
Let's say our heading is 45.3275 degrees. So we know it is 45 degrees, so subtract 45 from the number and multiply by 60, since there are 60 minutes in a degree. I get 19.65. So now we have 45 degrees and 19 minutes. Subtract the 19 minutes to calculate the number of seconds by multiplying the result by 60. I get 39 seconds. Overall, we have 45 degrees, 19 minutes, and 39 seconds.
Good luck.
Paul
Apr 22, 2015 | Casio FX-65 Calculator
Enter degree minutes seconds
Enter the degrees, a decimal point, then two digits for the minutes followed by two digits for the seconds (then followed by any fractional seconds). You can then convert to decimal degrees with the HMS-> function.
For example, to enter 1 degree 36 minutes 24 seconds, press 1 . 3 6 2 4 ALPHA ALPHA "H" "M" "S" right-shift "0" ENTER
Jun 30, 2013 | HP 50g Graphic Calculator
How can i convert degrees,minutes and seconds to decimal degrees in a casio fx-82MS
Use the DMS key marked degree, apostrophe, double quotation mark.
Lets us call it [DMS]
To enter an angle in degree minutes seconds or hour, minutes, seconds, type in the number of degrees, press the [DMS] key, enter the number of seconds, press the [DMS] key, enter the number of seconds then the [DMS] key. Press = the calculator displays the value in DMS units. If you press the DMS key again the number displayed is converted to decimal degrees.
Example:enter 12 degrees, 15 minutes, and 25 seconds
12 [DMS]15[DMS]25[DMS] =
Calculator displays 12 deg 15'25"
Press the DMS key again and you see 12.2569444
Feb 19, 2013 | Casio FX-82MS Scientific Calculator
Dd to dms conversion
Press the DMS button to convert between decimal degrees and degrees-minutes-seconds.
The DMS button is marked with the degree, minute, and second symbols. It's located above the [ENG] key, which is located above the [8] key.
For full details, start with the "Degree, Minute, Second (Sexagesimal) Calculations" section beginning on page E-22 of the manual. If you need a manual, you may download a copy here.
Jan 19, 2012 | Casio FX-115ES Scientific Calculator
Can I convert Decimal Degrees to Degrees, Minutes, Seconds on my casio fx-991 ES?
Yes. Pressing the DMS key (two keys above the 8 key) when a result is displayed toggles the result between decimal degrees and degrees-minutes-seconds.
For example, to convert 3.5 degrees, press 3 . 5 = and you'll see 3.5. Now press DMS and you'll see 3 degrees 30 minutes 0 seconds.
Jul 31, 2011 | Casio FX-115ES Scientific Calculator
I know how to convert between decimal degress and degrees, minutes, seconds, but how do you enter degrees, minutes, and seconds directly?
Enter it as DD.MMSS and then press 2nd [DMS-DD] to convert it to decimal for further calculations.
For example, to enter 21 degrees 34 minutes 45 seconds, enter 21.3445 then press 2nd [DMS-DD].
May 12, 2011 | Texas Instruments TI-30XA Calculator
Sir i want to know calculations degree, minutes and seconds
Jul 28, 2010 | Casio FX-115ES Scientific Calculator
Converting decimals to degrees on a casio fx-83es calcualtor
if you mean degrees like the degree/minute/second thing: lets say you have 24.12 there is a button that has a dot, and 3 commas (it's located next to the negative button) that will convert that number to degrees. input your decimal, press the equal sign, and then press that degree button and it will convert 24.12 to degrees, minutes, and seconds. the solution is 24 degrees, 7 minutes, and 12 seconds.
Jan 11, 2009 | Casio FX-115ES Scientific Calculator
Degrees, minutes, seconds converted to decimal degrees
No DMS button
1degree 22.25 minutes
2nd Math F3 1 F1 22 f3 15 f3 enter
Sep 05, 2008 | Texas Instruments TI-85 Calculator
Casio FX-115ES Scientific Calculator Logo
182 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
