Question about Frigidaire GLGR331A Gas Dryer
Dryer won't turn on, it makes a dull humming noise when you try to turn it on...how do we fix it??
  • Frigidaire Master
  • 8,220 Answers
Motor replacement most likely. I have the manual and more here
Posted on Jan 13, 2012
  • 142 Answers
SOURCE: The dryer just makes a
When you say it won't turn all the way on, does that mean the drum isn't rotating?
If yes, the belt from the motor that goes around the drum might have broken and you can hear the hum of the motor spinning but no longer rotating the drum.
The other thing I can think of is that the motor itself has failed, possibly seized, and you can hear the motor trying to spin but it cannot. With the dryer unplugged and empty of clothes, try to rotate the drum. If it rotates extreamly easily, then the belt has broken. If you cannot rotate it at all by hand, then chances are the motor is seized. It should rotate with moderate effort.
Posted on Mar 08, 2008
ginko
  • 19396 Answers
SOURCE: Frigidaire Dryer
If Dryer does not tumble , check the following:
" It won't tumble If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it."Source Repaiclinic
Posted on Sep 08, 2008
  • 163 Answers
SOURCE: dryer makes a humming or buzzing noise and the
motor is going bad.
Posted on Mar 08, 2009
  • 1122 Answers
SOURCE: My kenmore dryer 90 serise won't start...makes humming sound....
your dryer motor is shot,it is to weak to kick on,sorry-mike
Posted on Jun 03, 2009
hunter19_46m
  • 7482 Answers
SOURCE: my dryer just makes a humming noise when i turn it
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Posted on Nov 10, 2009
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Whirlpool dryer won't spin
Most dyers after you pull the top up, the front should just lift a little and it should come loose, sounds like you may have the belt intact, but the motor is not conected to the belt.
Jan 12, 2013 | Whirlpool Dryers
Shutting off won't start when hot
The windings in the motor are bad and the motor will need to be replaced. Here is the motor to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 17, 2012 | LG Home Applaince LG DLE0442W 7.3 Cu. Ft....
Indesit G74V dryer won't spin
Some dryers have a belt tension idler and switch combination that works to keep the belt under tension and shuts down the dryer if the belt breaks or falls off.
Apr 28, 2017 | Dryers
What is humming noise from front end of mondeo at low speed
Power steering pump noise is likely the cause.
Apr 30, 2012 | Cars & Trucks
Frigidaire dryer not working drum won't spin,
Hi How old is it , ? and dose it soun like the motor is running but not turnning the drum ? this would be a bad belt , you will need to do some more investagating for me to help you
Dec 06, 2011 | Frigidaire Dryers
My kenmore dryer makes a humming noise when u turn it on n the drum will not spin
If you are hearing a humming noise and no spinning . You have a burnt motor..Do not attempt to switch it on till you fix it to prevent further damage
Mar 07, 2011 | Dryers
I get a loud humming noise . The dryer works good but makes a loud humming noise when it's working .
The motor is going bad and this will make that loud humming when it is running...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 25, 2010 | Maytag Dryers
Dryer makes humming noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
bb
May 15, 2010 | LG DLE2512W Electric Dryer
Frigidaire GLGR331A Gas Dryer Logo
51 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
