Question about AcerView 76E Monitor
MOnitor Problem Monitor is 15''. But without connection to the CPU it gets on . But when I connect the monitor to the CPU through VGA the monitor switch off and the indicator light blinks and the monitor screen turns black
    President:
  • Acer Master
  • 1,314 Answers
Assuming the cpu is on, then the likely culprit is your video card or your onboard video. Either replace the exsisting video card or add a video card to your system.
Posted on Jun 16, 2008
Does the Dell 1503FP 15" LCD Monitor have VGA
Cable Connections On Back of Dell 1503FP 15" LCD Monitor and Computer connect.gif D-sub(Blue colour) is the VGA cable , hence Dell 1503FP 15" LCD Monitor have VGA capability.
Feb 18, 2011 | Dell 1503FP 15" LCD Monitor
The power led is flashing and the monitor will not turn on
Hi
usually for these kind of issues., here are some common steps that helps at times.
1. Check the VGA Cable that connects the Monitor to the Tower (CPU).
2. Reseat the Cable once.
3. Remove the VGA Cable & turn on the Monitor Alone. See if you get any display saying "No Signal" or anything similar. If there is some display, then it means that the problem is with the Tower (CPU) & not with the monitor.
Hope this small sugession helps.
Cheers!!! Have a nice day!!!
Sep 14, 2010 | BenQ FP567s 15" LCD Monitor
AOC color monitor 15in. 5En model. during power on all led lights functioned and no display was observed
u try to reorient ur vga connection it might be a loose connection between ur monitor and ur cpu otherwise ur vga cable is defective...
Nov 02, 2009 | AOC 5 En 15" CRT Monitor
AOC color monitor model 5En...during power on all led lights blinks then stops blinking without display action. all led lights on no more action observed.
actually if u repair an aoc monitor alone without getting connected to cpu once u switch on the monitor all led's will lit on ( green light ) it will remain on situation until u connect the vga connector to cpu that's the time led's will lit off and only the power led will remain in green condition.some aoc 5en once u power on power led is in green condition and if not connected to cpu it will be in orange condition.hope u get some idea but i am not sure if it will work with ur monitor. but as long as LEDs lit on i think no problem with ur monitor.
My lg500g 15" monitors green led is blinking contnuously and no display on computer startup
check you video graphics adaptor inside the cpU. or you may try to use another CPU connect your monitor if it is ok their is a problem with your VGA or inside your CPU.
Sep 24, 2009 | LG 500LC Monitor
Monitor looks as if there is no CPU
If the power supply is coming to CPU before activation of CPU then it must be receiving current from UPS. Don't try unplugging, You may get shock. Thank you, Sir.
Sep 17, 2009 | Computers & Internet
No display
First open cpu cover then refix RAM memory.
Then power up then press F8 key then enter in enable vga mode go to control panel ->dispaly ->settings change screen resolution to 1024*768 .
If you still not get display check monitor to cpu vga port connection reconnect into it.
Aslo pull out cmos cell for 15 minutes so all bios settings are defaults then check .
you can find cmos cell on motherbord chip set in cpu.
Thanks for using fixya.
Please rate this solution if it helps.
Jul 24, 2009 | Acer 22" X223w LCD Monitor
Monitor fault
vertical controll is damaged
Aug 16, 2008 | SAMTRON 55V 15" CRT Monitor
Blinking green light with no display
Have you tried connecting this monitor to another computer?
Have you tried resetting the BIOS? That should reset any problem the video driver for the monitor maybe facing.
Oct 17, 2007 | Gateway FPD1530 15" Flat Panel LCD Monitor
AcerView 76E Monitor Logo
46 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
