Question about Infinity KAPPA 100.1DVC Car Speaker
I want to build a box for my kappa subs and i need to know what specs would make them sound great. they are goin in my 97 chevy ext cab truck. the box is going to be my back seat also
  • 23 Answers
Http://manuals.harman.com/INF/CAR/Boxes%20and%20Parameters/1001dvc.pdf
Not knowing your musical preference, take a look at this spec sheet and pick the sound you'd most like. The bandpass design usually gives the most SPL, but a larger box is probably deeper while still having good volume. Some audio purists say a sealed box sounds the best, subjectively, but the SPL isn't as great.
Posted on Nov 09, 2010
Im trying to build a custom box for a sub. I have one 10in ss autotek 4ohm dual-core and i would like to cut out the right measurements to build a ported box. Can anybody give me the right measurements...
Down load a program call bass box pro and it's realy easy to use it will ask you what type of box you want then speaker specs after that put in the specs or the size of space you have to put it and it will automatically figure it for you and tell you program is all over the Internet
/uploads/images/im-trying-build-custom-box-sub-one-10in-34868166-4-1.png
Jan 13, 2015 | Autotek Car Audio & Video
2004 chevy 1500 ext cab hard to turn right at low speeds
2004 chevy tahoe 4x4 had the same problem wont turn right at idle - like no power steering , has hydoboost brake steering system , did test and found steering box bad , removed box and remove the top cover on box 4 bolts at hydralic cover and removed and found spool valve has 4 seals 1 outer was blown i replaced box with reman from advance auto about $200.00 and flushed system , drove great problem solved .
Aug 26, 2010 | 1999 Chevrolet Silverado 1500
What is the recommened air space for kicker comp vr sealed do you know the specs for building a sealed box
Really it all depends on how you want them to sound, and to be set up. There really is not specific air space, but there are general air spaces that work, and some times the manufacture will list some specs for different set ups. It also depends on the size of the sub, which you did not specify.
Kicker recommends as follows.
0.4 cubs per sub for a compact box, and 1.8 for an SQ box. SQ stand for sound quality.
So if you want a small box, do .4 per sub. If you want a better sounding box do 1.8.
Rule of thumb and something to think about.
The more air space in the sub, the less power you can run, the less air space, the more power you can run.
For example you can run 200 watts RMS per sub at .4 cubes, but only 140 watts RMS with 1.8.
As well, the smaller box will be louder, But not sound as good.
Dec 24, 2009 | Kicker CompVR 05CVR84 Car Subwoofer
15" Lanzar 400 watt sub
you would have to build a ported or sealed box with a sloped back
Sep 19, 2009 | Lanzar OPTI1222D Car Subwoofer
Need subwoofers
IF U HAVE A REG CAB U CAN BUY A TRUCK BOX MOSTLY FITTING 2 10INCH SUBS, AND A AMP UNDER YOUR SEATS, OR IF U HAVE A LARGER CAB THEY MAKE CUSTOM FIT BOXES BUT THEY WILL COST U MORE, OR U CAN GET A BOX FOR 1 12INCH SUB FOR A TRUCK AND U CAN PUT IT ANYWHERE U WANT.
Jun 16, 2009 | Car Audio & Video
Need specs to build box for my truck
I do design sub enclosures for a living and I give free specs on basic setups, so you are in luck. As a starting point I'll start by saying that fitting them under the seat may not work that well. Each sub will need about .75 cu.ft. sealed and probably double or triple that for a good ported box. I can get more specific If you e-mail me (dynami28@charter.net) the specs on those subs. Specifically I will need the Theile Small parameters ( these numbers-VAS, QES, QMS, FS, etc,) and then I can give you a better idea of where they will fit. If they do go under the seat they will probably not produce really low bass because smaller boxes generally produce higher bass tones. This decision should be based on what you listen too and what you expect them to sound like. They most likely will be more thump than boom and some people like that, so figure that out as well and let me know. Also my father has the same truck and there is a lot of room under the back seat. You can also gain some extra space by using fiberglass to conform the enclosure to the contour of the truck.
-Dynami
Apr 02, 2009 | Rockford Fosgate Car Audio & Video
Need to build a ported sub box for my alpine swr-1222d subs x 2
Try going to Alpine web site, I think they have box building program as well that you just input your sub models into and it gives you blueprints for various types of enclosures. I know Rockford has one and a comparative attachment to compare equipt specs. Or if you call Alpine headquarters you may be able to get info that way, I once sweet talked a rep @ a demo vehicle I met doing some car shows that turned me on to a senior rep @ Korbon Trading the owners of Rockford Fosgate and they gave me specs for a 5 stage band pass box for some competition subs that was more intricate and detailed than anyone before that could find me, Won me first place in spl. Matching your box specs to your subs is crucial and the best specs are often kept a secret for demo competition vehicles! So ask around with some competition guys or other top experts if your real serious about your boooom.
Mar 13, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
HOW TO INSTALL
I would say look for a custom box off ebay or build one behind rear seat. Im not shure if you can fit a small truck box behind there but you may be able to. It would sound pretty good behind rear seat. Hope this helps
Jan 13, 2009 | Pyle 12" 600 Watt Amplified Subwoofer Tube...
Car stereo im trying to build
I guess the question you need to ask yourself then is how much money are you willing to spend? If you are looking for a sound quality system then it WILL cost a lot more than a DB all out BASS system. The system that you have picked out isn't a bad one but as with all systems this in only half the story. You will need to have it installed well to get the best from the speakers that you have chosen too. If you want to have the stealth look in the cabin then it's pretty simple, but you will not get the best sound quality or should I say imaging as the OEM locations usually are no good for this.
I would suggest that even though you keep things looking stealthy in the cabin apply sound deadening to the doors as Asian cars are generally quite tinny unlike German cars. This will make a big difference in terms of overall sound quality & help keep out the road noise so you can hear every little detail of your personalised system.
Dec 25, 2007 | Car Audio & Video
Infinity KAPPA 100.1DVC Car Speaker Logo
136 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
