Question about Refrigerators
I'm getting a regular beeping from the unit -- and the front panel light reads"LE". I can't get the beeping to stop; nor adjust the reading.???
  • steve_tho648 Nov 08, 2010
    Thanks for the help. It is a Kenmore compact refrigerator. Model #: 93382
    President:
  • Refrigerators Master
  • 2,923 Answers
Can you tell me the brand and model number of your appliance? The info that you will provide might help me to find more information that might lead in fixing the problem.
Thank you!
Posted on Nov 09, 2010
  • 3,083 Answers
It would help to have the model and make of the unit, but if you google the make, model, and keeps beeping, you might come up with some blogs that have some answers and things to try.
Here is a site that has some error codes and might help you:
On the following google search, LE codes only came up for washers, but this question was printed in the Refrigerator section, and those mishaps can occur.
If you're problem is with a washer, go to this search page and bring up the articles to see if they can help you solve this:
http://www.google.com/#sclient=psy&hl=en&q=refrigerator+LE+error+code&aq=f&aqi=&aql=&oq=&gs_rfai=&pbx=1&fp=eeb05746d54f919c
Good luck to you, and hope this helps.
Posted on Nov 08, 2010
Got fridge freezer but no instructions. Alarm keeps going off. Front panel contriols
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Apr 10, 2015 | Refrigerators
Slip indicator light and beep locking of the front wheel
sounds like it looses wheel sensor signal from the front left wheel, thinking its slipping. either a defective wheel sensor or loose connection somewhere on/in the wires between wheel sensor and control unit
Mar 21, 2014 | 2005 Toyota Sienna LE
Lg front loading washer flasing LE and stops midcycle
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
OVER SUDDSING
Jun 16, 2012 | LG WM-2277HW Front Load Washer
Got "LE" mark on LED
Hi
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped.
This error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 03, 2011 | Washing Machines
It stops mid cycle and at the digital display it flashes " LE " . What is wrong????
Motor lock can be caused by several things from a loose connector, to a bad motor, or even the hall effect sensor failing or dislodging from it's mount. Any one or more of these components could have caused this error.
Apr 11, 2011 | LG WM1812C Front Load Washer
My panel said "Sudz" then the washer stopped and
Are you using HE detergent? If some units sense suds, it'll shut down with a sudz error. Unplug the unit and let it sit for a few minutes.
Dec 04, 2010 | Kenmore HE2 Plus Front Load Washer
2001 Corolla LE Brakes are not strong
Could be many things to look at. 2001 Corolla, assume disc pads in front, and regular drum style brakes in rear. Generally, most of your braking will come from the front disc brakes, and no adjustment is provided in these. Rear drum brakes can be adjusted two ways. Manually, they are adjusted by accessing the adjustment "cog" or threaded rod via a slot in the back of the plate that the drum fits up against. This should be done when the brakes shoes are first installed. As an alternative, the brakes will automatically adjust when you apply the brakes while backing up. I'd suggest that you find a big old empty parking lot, without a lot of light poles to hit, and place car in reverse, get going about 5 MPH, then hit the brakes firmly to stop. Repeat this a dozen times and see what results you get.
I am, of course, assuming that the brake fluid level is good and you see no leaks from either the front calipers or the rear brake cylinders.
Oct 07, 2009 | Toyota Corolla Cars & Trucks
RESOLLUTION ISSUES OR GRAPHICS CARD UPGRADE?
Can you please put forth the problem in minimal words?
May 07, 2009 | HP Pavilion a6650f Desktop PC
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
