Question about SanDisk Sansa e250 MP3 Player
No display my player fell down and now i cant see any display on the screen only the blue ring lights up also it is not detected by my pc. plz help.
  • 8,596 Answers
Probably hardware damage, but you can try the following "soft" fixes:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jun 18, 2008
My netbook fell down n when I tried to start it a blue screen with setup utility comes n I tried changing options n restarting n the same screen keeps coming... Plz help..
The problem is the any hardware part is not it its proper position
Avinash it can be hard disk or even the ram
Please first try to open and see all this component are in the proper state and secondly it can also be hard disk failure you have to specify me that if the computer goes in blue screen does the hard disk light is still blinking and if you can go the bios option then its more better
when you power the device then click on the f2 or f1 it will show your bios option then scroll down and you will see hard disk please specify me that its showing anything on the harddisk i mean the vendor name or model no
please reply back
Nov 18, 2012 | Computers & Internet
My Sansa e250 has hanged and only wheel light gets light is I restart the player....Plz help !!
Battery and Black screen Blue ring: Remove the back and check and see if the battery isn't fully connected
push softly but firmly on the Rubber rectangle above the battery (This is the Chip-set For the screen, and memory "Black screen Blue ring" ) and put the back on.
Jul 25, 2010 | SanDisk Sansa e250 MP3 Player
My sansamp3 has no light on the screen.so the screen is dark how can i fix it because i cant see what am doing
push softly but firmly on the Rubber rectangle above the battery (This is the Chipset For the screen, memory Black screen Blue ring ) and put the back on.
Jul 16, 2010 | SanDisk Sansa e250 MP3 Player
Nothing but the blue ring lights up
ok..idk if this will work but it might...first turn off the sansa...then turn the hold switch on (it should turn red). hold down the record button on the side of the player..then while still holding that hold the power button down...but keep holding them untill a screen shows up saying something about recovory mode..itll say to plug in the usb..u could do that..idk it that will work..it it doesnt instead of plugging in tthe usb in the computer..wait about 15 seconds after the recovory mode screen shows up and then hold down the power button for about 15-20 sec...then itll go all black (including the blue light) press the power button again like u would to turn it on...and everything should be back to normal..hope this helps...:)
May 04, 2009 | SanDisk Sansa e250 MP3 Player
What does "Refreshing Database" mean?
You will need to upgrade or reinstall the firmware on your MP3 player. You may download the firmware on http://www.sandisk.com/Retail/Default.aspx?CatID=1376. For the manual installation of the firmware upgrade, you may go to this site: http://www.sandisk.com/Retail/Default.aspx?CatID=1449
Oct 12, 2008 | SanDisk Sansa e260 MP3 Player
Zen sleek Mp3 (20 gb) SCREEN PROBLEM!! HELP
There is no repair service for a cracked screen - the whole player has to be replaced -sorry
Jul 04, 2008 | Creative Labs ZEN SLEEK MP3 Player
SanDisk Sansa e250 MP3 Player display gone blank
I believe this is answered already. Turn the hold button on. Red light will be on. Hold the rewind button while you insert it into the computer. Please search online this has been answered. I am recalling from what I read a few minutes ago.
Feb 04, 2008 | SanDisk Sansa e250 MP3 Player
Mp4 player not working
prevously my pc was detecting ma MP4 player... but now it is getting hung ...and not even detected ma pc....plz do a needful help...all helps appreciated.....cbaljit@gmail.com
Nov 04, 2007 | Sony CDX-MP40 CD Player
Help..!!!
sandisk have a upgrade to fix connection problem download, install it ,plug it and upgrade it via internet. works for me.
Mar 14, 2007 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
29 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
