Question about Ricoh Aficio 450 Copier
Sc 322 how to solve this error - Ricoh Aficio 450 Copier
  • 165 Answers
U cant it needs a service
Posted on Nov 10, 2010
5 Suggested Answers
Bubbabear64
  • 2794 Answers
SOURCE: sc 322, sc 326 codes
Never heard of this happening to five machines before.  Check the connections in the laser unit.
Posted on Oct 27, 2008
  • 990 Answers
SOURCE: sc 322
Hello sir; Try to reset if not work you need to replace laser unit, the reset procedure as follow; press "clear mode " then 107 then press " clear/ stop " until screen change ,then touch "copier sp " ,then turn power off and back on .
Posted on Aug 26, 2009
  • 192 Answers
SOURCE: i HAVE AN ERROR SC 322 WHEN i GO TO PRINT RICOH 1035
Error Code SC322:
1st laser synchronization error
The 1st laser synchronization signal cannot be detected by the main scan synchronization detector board even if the laser diodes are activated.
Possible Causes:
+ Poor I/F harness connection between the laser synchronization detector board and the LD unit.
+ Laser synchronization detector board out of position and angle of reflection not correct
+ Laser synchronization detector board defective LD unit defective
Not sure what your expertise is on this, but unless you know how to service the machine yourself, this one is going to require a service call...
There have been instances where toner drops onto the LD Unit and creates problems like this. About a month ago I replaced the Laser Synch. Detector Board in a 1045 for this exact problem and error code.
I'd start by cleaning up any toner on the LD unit, and re-seating all the electrical connectors on the laser unit. If that doesn't clear things up, it's probably one of two things, the LD Unit or the Synch. Board. I'd lean more towards the Synch. Board myself, but you never know...
Posted on Nov 19, 2009
  • 109 Answers
SOURCE: please solve this problem Ricoh 7650 Code SC 902,
SC322: Laser Synchronization Error
Definition [B’]
The laser synchronization signal cannot be detected from the synchronization
detector even if the laser diodes are activated.
Possible Causes
• Poor connection between the laser synchronization detector and the LDB
• Laser synchronization detector out of position
• Laser synchronization detector defective
• LDB defective
• SICU defective
• Front door safety switches defective
SC302: Charge corona output error 1
SC902: counter error
Posted on Apr 03, 2010
How i can solve the ricoh 350 error sc-322
hii dear 322 means synchro1 not detected signal that go to sp mode yellow cancel and put 107 and hold on red cancel 3 seconds yo will see copy sp in asquar then put 2109and# and 2108and# and close machine and open if it's not work out try to clean mirrors in laser unit ok
Jan 25, 2011 | Ricoh Aficio 1035 Copier
Ricoh aficio 2035 sc 322 (unidad de lazer en buenas condiciones) ?que mas puede ser ¿
sc 322 is a laser unit problem. find a ricoh technician and clean the laser unit or replace it. this laser problem is hard to solve usually.
Sep 28, 2010 | Ricoh Aficio 450 Copier
SC 322
sc 322 how to solve this error
Jun 16, 2010 | Ricoh Aficio 450 Copier
It has an error code 322.I took out the drum unit but upon returning it gave me the error code
sc-322 is a code of laser synchronization error.just open the laser unit and clean all the mirrors and lenses carefully with a soft cotton cloth or j cloth.and also clean the polygun motor.this
Dec 07, 2009 | Ricoh Aficio 1013 Copier
Sc 322, sc 326 codes
Oct 25, 2008 | Ricoh Aficio 1035 Copier
Afficio 450 sc 322
1st laser synchronization error.  This should be looked at by a Ricoh technician to see what needs to be replaced.
Sep 11, 2008 | Office Equipment & Supplies
Aficio 450
SC 322 is a laser diode problem. It will require service.
Mar 27, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 Copier Logo
106 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
aaron douglas
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
