Question about Bosch Axxis WTL 5410 Electric Dryer
No heat after 2 mins - Bosch Axxis WTL 5410 Electric Dryer
If it is a condensation dryer try wiping the inside of the dryer in a damp rag with water & vinegar. this will clean any deposits of the sensors.
Posted on Dec 05, 2010
Put in new Honeywell t-stat. Put new sequencers in. Heat runs for five min shuts off for 2 -5 min then back on continuously. Inside temp stays the same as set point???
What is the model number of the new thermostat? What could be happening is that the cycle rate needs to be changed or if it has a heat anticipator it may need to be adjusted.
Jan 30, 2017 | Honeywell Heating & Cooling
98 Malibu 3.1 v6 can drive it for about 30 mins than it stalls and dies been through 5 fuel pumps 2 motors and still has the problem let it sit for 30 mins it will start again. Also found out if heater is...
5 fuel pumps and 2 motors? id say that whoever is diagnosing your car needs to be fired. toggle switches, over heating, stalling after 30 mins, new motors....you need to get this to a shop. no way someone can diag this cars serious problems and over internet.
Jul 27, 2014 | Cars & Trucks
WHY IS MY EZ 10 GIVING A LOW HEAT CODE
Message is displayed and sterilization does not start if the autoclave has not reached sterilization temp. after heating for 50 mins. while in wrapped or unwrapped programs (80 mins in the Glassware program).
1) Clogged air jet, clean air jet.
2) no pwer to the heating elements.
3) Low line voltage delaying heat up. Not enough power to supply unit.
May 06, 2014 | Tuttnauer EZ10 Automatic...
Heat Pump Cycling too frequently?
It should run until it reaches the temp. setting on the thermostat.
Do you have a make and model number so I can assist you?
Jan 11, 2014 | Mitsubishi MSH09TW Air Conditioner
Nokia lumia 800 heating
motherboard problem try fix at service center
Sep 04, 2012 | Nokia Lumia 800
Oven is taking to long to heat
look for the temperature sensor inside the oven cavity in the upper left or top center of the upper oven cavity,its will be a silver or copper colored rod about 1/4" by 2" to 6" long this rod senses the oven temp and cycles the heat to the oven
Jun 03, 2012 | Kenmore 30464 / 30465 / 30469 Gas Single...
Clean button is flashing
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 02, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
When the thermostat can not be set
TURN THERMOSTAT SWITCH TO AUTO AND THEN TURN THE
OTHER SWITCH TO HEAT OR COOL. IF IT DOESN'T CUT ON AND OFF PROPERLY NOW, REPLACE THE THERMOSTAT OR MAKE SURE ALL WIRES ARE CONNECTED TO THE PROPER TERMINALS , AND IF THEY ARE THEN REPLACE THE THERMOSTAT AS SUGGESTED. REMEMBER...PUSH SETTING
TO HEAT AND WAIT 2 TO 3 MIN. TO SEE IF THE HEAT WORKS. NOW DO THE SAME FOR THE COOL AND WAIT 2 TO 3 MIN.
Apr 07, 2010 | Heating & Cooling
Very little heat worked great 2 days ago
make sure you have the right thermostat in it usuall 160 degrees or so
Jan 03, 2010 | 1994 Jeep Grand Cherokee
Bosch Axxis WTL 5410 Electric Dryer Logo
75 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
