Question about Acer Aspire One Netbook 8.9" Notebook
How do I set my Acer Aspire one back to factory settings
  • 105 Answers
At the boot menu you must choose backup mode option instead booting into windows XP directly.
That way you'll boot into a backup mode and you can reinstall windows.
Posted on Nov 08, 2010
1alexh
  • 484 Answers
SOURCE: restore a acer aspire 4330 back to factory settings
Follow these instructions carefully:
To start the recovery process:
1. Restart the system.
2. While the Acer logo is showing, press <Alt> + <F10> at the same time to
enter the recovery process.
3. Refer to the onscreen instructions to perform system recovery.
I copied the above from an Acer manual, and it works on my own system, which is not the same model as yours. But you must understand that this will basically restore your computer to the condition in which it was when you bought it, unpacked it from the box, and followed the instructions to set up a new computer.
This will give you your system back as if it were brandy new, but in most cases, anything you created, like DOCs, or XLS files, again … ANYthing you created since buying this computer, will also probably not be there any more.
You will have a pristine, clean as new, computer system.
Be careful, be absolutely sure this is what you want to do, and go ahead and do it.
-a.
Posted on Dec 15, 2009
zohail
  • 1223 Answers
SOURCE: restore factory settings
there are 2 ways for doing this
1) Fast and easy without backup disk just do this
Acer: When you turn on the laptop and see the Acer logo screen, hold the ALT key and press the F10 key (you need to do this before the Acer logo disappears).
2) If the method above doesnt work u can do it thru backup disk u have got when u purchased ur laptop u shud have made it thru Erecovery software.
Pls rate me FIXYA for help !
Posted on Apr 13, 2009
  • 30 Answers
SOURCE: Reset Acer Aspire One to factory settings--clean hard drive
You will have to order the erecovery cds from Acer to put it back to factory settings. They can about $40.00 to $50.00 dollars and they arrive about a week after you order them. Once you get them, you boot from cdrom and follow the instructions on the screen.
Go to Acer.com to order them.
Posted on Dec 28, 2008
  • 3 Answers
SOURCE: acer aspire 6920 back to factory settings
on the first screen that says something like "F2 to enter BIOS" and "F12 to change boot order", hit F10 (maybe Alt+F10 or Ctrl+F10, not sure) and it should pull up the recovery console.. just read carefully, the only option there might be reformatting C:
Posted on Jun 22, 2009
  • 52 Answers
SOURCE: restore back to factory settings
From Acer direct
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Posted on Jul 12, 2009
Restore to factory settings
The Acer Aspire One is a netbook, not a laptop.
A netbook is a smaller, scaled-down version of a laptop. It does not have the memory capacity or graphics of a regular laptop.
It also lacks a CD drive, which means you cannot restore the Acer Aspire One with restore discs. Instead, the netbook has a built-in factory restore feature.
You can reset the Acer Aspire One to factory settings just using your keyboard.
Only restore your netbook to factory settings if you cannot fix the problem any other way.
Save any files or folders on your Acer Aspire One with flash drives.
Drag and drop files onto the icon of your flash drive.
Go to "Start" > "Restart" to reboot your netbook.
Hold down "Alt" and "F10" when you see the Acer logo on the screen.
The recovery menu will load.
Hit "Enter" and then "Next" to see your recovery options.
Choose "Factory Restore" to set your netbook back to factory settings.
Follow the instructions on the screen.
Choose your time zone and language when the customization menu appears.
Reboot the netbook when you are prompted.
Restore your saved files from the flash drive.
Jun 13, 2013 | Acer Aspire One Netbook 8.9" Notebook
Aspire one needs rebooting no disk
The Acer Aspire One is a netbook, not a laptop. A netbook is a smaller, scaled-down version of a laptop. It does not have the memory capacity or graphics of a regular laptop. It also lacks a CD drive, which means you cannot restore the Acer Aspire One with restore discs. Instead, the netbook has a built-in factory restore feature. You can reset the Acer Aspire One to factory settings just using your keyboard. Only restore your netbook to factory settings if you cannot fix the problem any other way.
Save any files or folders on your Acer Aspire One with flash drives. Drag and drop files onto the icon of your flash drive. Go to "Start" > "Restart" to reboot your netbook. Hold down "Alt" and "F10" when you see the Acer logo on the screen. The recovery menu will load. Hit "Enter" and then "Next" to see your recovery options. Choose "Factory Restore" to set your netbook back to factory settings. Follow the instructions on the screen. Choose your time zone and language when the customization menu appears. Reboot the netbook when you are prompted. Restore your saved files from the flash drive.
Feb 14, 2013 | Acer Aspire One PC Notebook
I dont know how to restore my acer with linux back to factory settings
Jan 20, 2013 | Acer Aspire One Netbook 8.9" Notebook
I DONT KNOW HOW TO RESTORE MY ACER BACK TO FACTORY SETTINGS
Jan 20, 2013 | Acer Aspire One PC Notebook
How to reset myacer to manufact setting
  1. Consider what data you still need from your Acer Aspire One's hard drive. Save the files to an external USB device.
  2. Restart the Acer Aspire One's operating system. Wait for the Acer logo to appear on the LCD screen.
  3. Press the "Alt" and "F10" keys at the same time to bring up the recovery menu. Press "Enter."
  4. Click "Next." Follow the prompts that appear on the screen to restore the operating system back to factory settings.
  5. Use the drop-down boxes to select the time zone and language information for your Acer Aspire One. Restart the netbook when you are prompted to finish restoring the computer.
  6. Connect the external USB device to your Acer Aspire One and transfer the data you saved earlier back to the netbook.
Nov 12, 2010 | Acer Aspire One Netbook 8.9" Notebook
Need to restore acer to factory settings
contact acer you can get there number from the website and they will let you purchase a restore disc for 15bucks
Aug 20, 2008 | Acer Aspire™ T180 PC Desktop
Acer Aspire One Netbook 8.9" Notebook Logo
234 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
