User Manual required for kohlangaz karizma gas fire
2 Suggested Answers
  • 4736 Answers
SOURCE: Please could you help with
The following is a downloadable link to your Owner's Manual in pdf format..
http://the-manuals.com/kohlangaz-kt18-manual/
I hope this helps you and tanks for choosing FixYa.
Posted on Jul 24, 2011
2010 Hero Honda Karizma ZMR will not turn over
Hi, Arun before testing any electrical component in the Starting Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead-acid batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Engine Run Switch is "FAULTY" or corroded.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
5. Bank angle sensor needs a reset or is faulty.
6. FOB battery low or dead.
7. Faulty ignition switch.
8. Faulty starter button.
9. Faulty kickstand, clutch, neutral safety switch.
10. Security alarm needs a reset.
11. Starter relay, solenoid, starter motor or circuit wiring faulty.
12. Starter armature or field coils have failed.
13. Main fuse or circuit breaker may be blown or faulty.
14. Faulty ignition relay.
15. The electric starter is working but starter clutch has failed.
16. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Karizma ZMR weird starting problem Team BHP
HeroMotoCorp Forum View topic starting problem in Karizma ZMR
Hero Honda Karizma ZMR 2010 service manual DOWNLOAD FREE FULLMANUALS COM
Hero Karizma ZMR free parts fiche
Owner Manual Scans of Indian Motorcycles Team BHP
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 04, 2018 | 2010 Hero Honda Karizma ZMR
2007 Hero Honda Karizma R overheating
Hi, Vijay and the usual suspects are:
1. Engine oil level and SAE weight are too low or not circulating.
2. Insufficient or blocked airflow over the engine.
3. Heavy combustion chamber carbon deposits.
4. Ignition timing retarded due to a faulty MAP, CKP, or CMP sensor.
5. Carburetor jetted too lean.
6. Leaking intake or exhaust valve.
7. Clutch slipping, brakes dragging, heavy load, towing a trailer.
8. Idling too long without moving.
9. Constant hot weather temperatures, mountain, or desert riding conditions consider adding an oil cooler and or cylinder head cooler.
Engine overheating and stressed out engine even at 60km hr Hero Honda Karizma Ownership Experience Team BHP
Karizma ZMR OVERHEATING issue RESOLVED twin oil cooler and exhaust thermal...
https://rushgleason.files.wordpress.com/2016/02/53235.pdf
https://safexbikes.com/products/motorcycle-parts/Hero%20Honda/vehicle/KARIZMA
Karizma manual
Feb 20, 2018 | 2007 Hero Honda Karizma
What's the fuel pressure on a Karizma ZMR
Hi, Shihab for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.xbhp.com/talkies/help-me/33271-karizma-zmr-fuel-pump-issue.html
Karizma ZMR fuel pump full breakdown and repair at home without special...
How to fix Repair faulty fuel pump on your motorbike motorcycle
Hero Karizma ZMR 2013 service manual DOWNLOAD FREE FULLMANUALS COM
Hero Karizma ZMR
Jan 29, 2017 | 2010 Hero Honda Karizma ZMR
How to remove zmr fairing
Hi, Vignesh_m_cb for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
How to remove zmr fairing Google Search
Hero Honda Karizma Zmr service book shortage
http://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda
Feb 01, 2014 | 2010 Hero Honda Karizma ZMR
How do I purchase a chrome decorative frame for a kohlangaz model kt L16 fire
Go to a shop that stocks them. But don't go to a computer shop as you will be wasting your time. It is a Gas fire.
Feb 18, 2013 | Computers & Internet
Karizma r carburetor problem
i have a karizma r bike the carburetor which the water is mixing with petrol while in the rainy season why other bikes dont have this type of problems how to resolve this reply
Jul 30, 2012 | 2010 Hero Honda Karizma
I have a Brilliant 16TCDL gas fire without a user manual, I wanted to get the fire serviced but it cannot be done without a user manual. I have contacted Brilliant but they don't keep manuals for
You have this posted in the Car and Truck product category. If you want the right expert to read this please post it in the correct category. Thanks
Feb 14, 2012 | Cars & Trucks
Please could you help with a manual for a fire place: Make: KOHLANGAZ MODEL:KT 18
Jul 24, 2011 | Heating & Cooling
Heating & Cooling Logo
804 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
