yes it is normal . most of these have a flexable metal tube that vents them , you can use a dryer vent tube but it will get hot and even melt a little
these units do not have a long service life so don't waste your money on factory replacement parts , just use the way you are till it's used up.
You can usually remove the old vents using a small flat bladed screwdriver and inserting it in the space between the dash and the vent (where the vent pivots) and gently prying up until the vent comes out. Replacing the vent is easier, just very carefully snap it back in the pivot holes. If the space seems a little tight, use the screwdriver to gently pry the dash out alittle till the vent goes into place.
Seems like the dampers are partically closed,look under steering column and see your duck work for the vent system.Follow it back to the blower box.Unhook if there, turn on ac, if you get full air, nice and cold on low and high you have blockage in your vent duct work,check the vent line that diverts air to the diffrent selected vents. Also check for vent disconnection around sterring column,and defrost vent area.
You cannot use a cheater, studdor or mechanical vent or an AAV on any Saniflo product. As they are considered one way vents, they only allow air to flow one way. Saniflo pumps must have an 1 1/2" vent pipe vented to the open air, air must flow in and out of the vent pipe at all times, otherwise the pump will short cycle and the solids will not leave the toilet. You will have to flush it several times to get rid of the waste and eventually the motor will go bad. Make sure is vented properly.
Your dryer vent may be crushed or blocked. To resolve this issue:
,Check to see if the vent run from the dryer to the wall is crushed.
Confirmthat the vent run from the dryer to the wall is free of lint and debris.
Confirmthat the exterior vent exhaust hood is free of lint and debris.
Confirm that your vent system falls within the recommended run length and number of elbows for the type of vent you are using. Refer to the "Plan Vent
System" section of the Use and Care Guide for details.
Select a Timed Dry heated cycle, and restart the dryer.
If the message persists, have your entire home venting run cleaned.
If you intend to use this in a residential garage, you will have to use standard galvanized round pipe coming off the unit, 24 gauge will suffice, use a minimum of 6”-8” from the unit. From there you will have to make the transition to the B-Vent. Always double check with you local codes in your area.
You are always better off using steel on these kinds of conversions and do not worry about how hot it gets,..Aluminum will get hot too. Steel is more rigid and less likely to dimple in while installing or hooking up the external vent system... Hope this helps..
