Question about Elna Quilter's Dream 6003Q
When I turn on my Quilter's Dream I am not getting any read out and cannot select a stitch. The machine turns on but there is no selection in the box that allows for stitch selection. Can you help me?
  • Elna Master
  • 7,365 Answers
Sound like the display has gone out & need to be replaced
Posted on Nov 08, 2010
I need an instruction book for serial number 641041095 please
The model number may be in the name, ie Janome Dream Quilter. Also, look for a plate, badge, or even a number stamped into the case.
Search the internet for:
Manufacturer + Model + the word "Manual"
Nov 11, 2015 | Janome Sewing Machines
Pattern selection dial
take the machine back & get another one
Aug 30, 2012 | Brother LS-2125 Mechanical Sewing Machine
I have the Mega Quilter and Quilters Cruise Control. My stitches are very inconsistent.
I agree to have the regulator check, & even having the whole machine checked wouldn't hurt.
May 15, 2012 | Sewing Machines
My elna quilters dream machine has 84o test mode on display and I can't select other stitches
you might think about having the machine check to see if there is something wrong with the motherboard
Nov 26, 2011 | Elna Quilter's Dream 6003Q
Do I use a twin needle with my narrow pintucking foot on my Elna quilter's Dream 2 sewing machine?
if you want to sew pin tucks, then yes, you could use that foot providing the hole is large enough for the two needles to pass through. Twin needles come in 4mm gap and 2.2mm gap so just check that it will fit. When using a twin needle, there is a lot of heat created so it is always important so sew slowly, going too fast will cause the needles to break.
Also, you should check on the twin needle type, modern machines now using a twin which is slightly offset, the block colour is usually a dark brown/red colour. Your machine may have come with a twin needle in the needle selection so take a good look at it and see if it is an offset one, then make sure you buy replacements of the same type.
THe pin tucking foot allows you to keep rows of pintucks lined up, it will have grooves in the base that you can run the previously stitched pintuck through to keep even distances. Best on lightweight fabrics like cottons, lawns, batiste etc. You'd probably go for the narrow 2.2mm twin needle to get a nice fine tuck. I like to press each seam after stitching too to give a sharp tuck.
Oct 20, 2011 | Elna Quilter's Dream 6003Q
My Elna SU will only do straight stitching it will not zig zag
I have the same model, have you turned the first knob on left, the stitch selector, to the stitch you want? Then turn the middle knob, the stitch width to "4". Use the colour guide marks shown in the little picture on left of the knobs so you are dialing up the right settings. So for the zig zag, elastic blind hem, scallop, overcasting and multi-stretch stiches, 1-6 on the diagram you'll be setting the left knob to 1, 2, 3, 4, 5 and 6 respectively and the stitch width and length knobs to "green", you can vary the length and width to suit what you want.
Then for the cams, you need to set everything zero, turn stitch selector to 7, the cam setting. then turn the width to orange again (3-4) and the stitch lenth selector to the orange setting, right around the knob. This engages the "Elnagraph" the device under the flap on top of the machine to read the discs. Basically the green stitches the needle is swinging from side to side while the feed dogs move the fabric forward, making your zig zags, blind hems etc.
But when you engage the Elna graph, the machine matches stiches by moving the fabric "forward and backwards at certain times, while the needle does its thing from side to side. This is what makes elastic or stretchy type stitches because you are putting "stretch" into the seam by sewing forwards and backwards.
Please note: always turn your stitch width and length back to Zero BEFORE you make any changes to the left knob and select a new stitch as this saves on wear and tear to the moving parts in these wonderful machines.
I do hope this assists you and I haven't just told you stuff you already knew!
Feb 02, 2011 | Elna Quilter's Dream 6003Q
Brother mechanical sewing machine XL-5060 - Can't select stiches
I have been provided with the solution by Brother.
If I turn the Stitch Length dial to "SS" I can select stitches from 10 onwards.
Wish they could have put that in the manual!.
Jan 18, 2009 | Sewing Machines
Can't select stitches 11-21
To select stitches 11-21 you position the stitch length dial on the "SS" setting , and the pattern selecting dial on the desired stitch number.
Mar 08, 2008 | Brother XL-5700 Mechanical Sewing Machine
Sewing Machines Logo
82 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Oloyede Monsuru
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
