Question about Lincoln Mig Welder Trigger Switch Magnum 100 L S19725
Wanna know how to install a trigger on my weldpak magnum 100l welder
I have a lincoln power mig 255 and every time i weld little holes appear in the welds. what could this be?
Hi:
This could be a problem of gthe gas you are using. Make sure to use mix 75/25 argon/CO2 for mild steel welding, argon 100% for aluminum and trimix helium/argon/CO2 for stainless steel.
Also check your heat (voltage) 16-22 is enough for weld of most steels less than 1/2 inch.
Aug 06, 2011 | Lincoln Magnum 100L 10' 025035
My magnum 100l is flowing gas even when the power is off. How do I get it apart to look inside?
Hi:
Your gun is not the problem, your problem is the solenoid valve on your machine (welder) that solenoid valve must got dirt or debri from the hose and the closing needle it's stuck . Just replace it, it will be cheaper than replacing your gun.
Have a great day.
Jun 21, 2011 | Lincoln Mig Welder Trigger Switch Magnum...
216 mig no feed no fire maybe selonoid problem please help seloniod does not click
It could be just the simple problem of the trigger not working. Disconnect the trigger wires from the machine at the plug at the front of the machine. See if you can manually trigger the machine by placing a piece of bent over mig wire onto the contacts. If the machine does trigger from this then your fault is in the torch somewhere. It could be the trigger (which commonly does fault from a dusty environment) which is easily replaced by going into any welding store with the torch model number (magnum 250L), or it could possibly be that a trigger wire has broken from the torch being damaged
May 29, 2011 | Lincoln Electric Lincoln Power MIG 216...
I have a ProMig 175. Suddenly the wire feed motor does not work. The solenoid clicks. I have manually turned the wheel trying to reposition the contacts in the motor. No help.
Verify the polarity is correct for Flux or Mig configuration (should be on label under lid) - and ensure there are no loose connections on that polarity wire.
Loosen the tensioner + make sure the wire feed motor turns freely by hand.
My WeldPak 100 and SP-135T were tough to turn, but it did turn freely.
If it does spin freely, then inspect the contacts for the voltage selector. Make sure to unplug the power cord and keep clear of the big capacitor. My SP-135T contacts corroded while in storage.
Apr 12, 2011 | Lincoln Electric LINK2400-+2 CV-305 MIG...
THE WIRE DRIVE SYSTEM HAS STOPPED. HOW DI I TROUBLESHOOT IT. WHERE DO I START.
Hi:
1) Disconnect gun's power plug connection and with the use of a clip bridge the connector on the machine; if the drive motor moves, then you have a faulty gun switch, Replace it. if not go to step 2.
2) Connect back the plug to the machine. Take the welding wire off the drive wheels and leave the tensor loose, press the switch if it moves; then you have a kinked gun liner, replace. If not then you have a damage PC1 machines needs to be send to a maintenance shop.
3) Last check the breaker on the back of the machine and press it. This is your last recourse. If still nothing happened then probably an overload caused the damaged to the PC1.
That's all.
Feb 27, 2011 | Lincoln Magnum 100L 10' 025035
Wire will not feed ,I was welding with my weldpak 100 and it just stopped feeding the wire so I shut it down to look at the next day when I tried it the next day the wire fed like it was suppose to until...
Your weldpack 100 has a duty cycle of only 20 t0 30%, meaning that your machine will weld for 2 to 3 minutes and then you need to let it cool down for the 8-7 minutes, then start again.
If the problem continues let me know.
Jan 03, 2011 | Welding Tools
LINCOLN 100 SEEMS TO BE 'SHORTING 'OUT AT FEED WHEELS AND BURNING OUT THE FEED WIRE?
check your ground wire everywhere its grounding out somewhere change the liner in your gun
Dec 10, 2010 | Lincoln Magnum 100L 10' 025035
I cant seem to get consistant penetration even though i am a competant welder and have set the unit up to manafacturers spec's as well as a few degree's either way. The material is clean, well earthed, i...
try a different outlet it seems you are loosing electrical power supply and it surges in and out causing this problem.also try cleaning the inside of the wire cable every time you chance the roll of wire i use brake clean spray it inside until it pours out the other end you will be surprised what you see come out.any comments are appreciated
Nov 21, 2010 | Lincoln Mig Welder Trigger Switch Magnum...
Need the gun for a lincoln 3200 welder
Gonna be expensive About $125-$200. Sometimes its cheaper to get a new unit. They sell for about $300 on Ebay. I believe this will work on your unit Its $85 on ebay.
http://cgi.ebay.com/Lincoln-Magnum-100L-MIG-Gun-Replacement-10-150A_W0QQitemZ330349527430QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item4cea5dc186&_trksid=p3286.c0.m14
Jul 29, 2009 | Welding Tools
Lincoln Mig Welder Trigger Switch Magnum 100 L S19725 Logo
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
