Question about CSi Speco PBM-30 2-Channel Amplifier
Music works only when phone is on hold and intercom system will not work at cashregisters but will work through telephone.
    Top Expert:
  • 9,472 Answers
Here is a link to the instruction manual for your amplifier. Check to make sure that the wire connections are correct for the music on hold and the mic.
I hope this helps you.
Regards, Richard
Posted on Dec 03, 2010
How do i switch from intercom to telephone?
If you unplug your phone and plug it back in, perhaps that will work for you. Ours always flashes when we do that but if you have a cell phone, just call your landline and it should return to normal. Hope that works.
Nov 19, 2011 | Lands Phones
How to use the intercom system
  • Check your telephone to see if it has an intercom feature. Many wireless phones that come with multiple units allow you to temporarily turn one unit into an intercom to contact other units attached to the same wireless phone system. Depending on the model, you can contact all the other phones at once, or a single specific phone, by pushing the intercom button and entering the other mode. To put the phone back into regular mode, all you have to do is switch off the intercom option.
  • Contact your telephone provider. Some telephone service providers allow landline phones to call themselves, which enables the phone to function as an improvised intercom. You would simply pick up the phone, dial and then close the connection. Once the phone is answered elsewhere in the house, you will have established a line to another phone and you can speak normally on it. This has largely been eliminated due to lack of need as technology advances, but it may still be an option with some providers.
  • Purchase and install an intercom system that will work through an existing phone line. Many of these products, some of which are produced by Panasonic, operate as a halfway point between a traditional intercom system and a phone line. The exterior intercom links directly to the phone line, and you can pick up the phone and talk through the intercom unit outside once the system is properly set up
  • Dec 18, 2010 | Uniden Cordless Phone
    I have a Panasonic KX-T7565 Digital Super Hybrid System and it is constantly playing music through the speaker...it won't stop and seems to be working fine
    Not sure of the model number, but Panasonic phones normally not connected to a TDA/TDE/NCP and TAW system have a toggle to turn background music ON/OFF. On the idle phone, press "1".
    If that works, then I guessed right again :-) If not, try dialing *7510 on the intercom which will work on the systems mentioned above.
    Carl
    Aug 26, 2010 | Panasonic KX-T7565 Corded Telephone
    I can't make a call or receive calls, I tried unplugging it several times and all the lights starts blinking!! When I try to dial a button, it gives me a busy signal.
    You are probably trying to dial out on an intercom button. This will give you a busy every time. You may have to dial 9 to get out.
    To test your phone, 1st find out what your intercom number is (press feature*0 and then press the intercom button) Your display will show you the intercom number of your telephone. Then try to make an in house intercom call to another working telephone. If that works have them call you back.
    The next step is to find out if you have any lines programmed to your phone. (press "feature*0) and then each button on your phone. The display will show you what is programmed on that button. If you have any that say "001 Line001" or such those are the outside lines to dial out on. Hope this helps.
    Bill C. www.dyna-tech.us We provide remote programming and tech support for Norstar CICS MICS and Call pilot 100/150.
    Mar 11, 2010 | NorStar M7310 Corded Phone
    How can i have music in hold time ?
    There are several ways to have music-on-hold for your telephone line(s). 1st you need to have a source of music such as a radio that has an output connection to feed the radio signal to the tele system, or a recorded music player that also has this output connection, or you can subscribe to Muzak (www.muzak.com) a company located in South Carolina that provides this type of service. 2nd, you need a telephone that has the input connection to allow this music source to be connected to the tele system, or you can buy a music-on-hold adapter that will feed your music source into the tele system regardless of the type of phone you have (as long as the phone has "on hold button", or if you choose Muzak, they will provide this aparatus adapter to you. Check the manual that comes with your phone to see if it has this music input feature; I'm not 100% sure of your model without further research, but I feel that the phone most likely does not have this feature. An adapter unit can be found at Radio Shack, or some AT&T telephone stores or on the internet. Good luck, Macgivor.
    Oct 04, 2009 | Panasonic KX-TS3282 Two-line Corded Phone
    Hands free not working
    To get handsfree working on any T7316 telephone you have to go into system programming to make sure full handsfree as been set to either Auto or Standard depending on software level of system you will get a choice but on latest version of software only option is for Auto, to check on telephone if handsfree as been programmed leave handset on phone press feature * 0 you will see key enquiry press a key in display, press the bottom intercom key on r/h/s of phone if it says extn number handsfree as not been programmed if it says handsfree mute you should be able to press handsfree key on phone to make or answer a call.
    Aug 07, 2009 | NorStar T7316E Telephone
    I have a NEC ETW 16DC-2 phone that does not ring with calls
    The telephone instrument you have can be used on the NEC Electra Professional Level I, and the Level II systems (and under some conditions the NEAX 2000 series). Codes for features are somewhat different based on the system. It is possible that your phone is in "Do-Not-Disturb" if other phones on your system actually ring when they are called via the intercom (on the Level I and Level II systems, initial intercom ring is a system wide setting). The cancel DND code is: Level I system: with telephone idle, press <FNC>, dial 60, press <FNC>. Level II system: with telephone idle, press <FNC>, dial 69, press <FNC>.
    It is also possible that your ring volume is very low. To adjust, press <SPKR>, dial 601, then adjust volume using the up/down keys at the bottom of the phone (press <SPKR> when finished. If your system is programmed to access an outside line when you press <SPKR>, you will need to press the <INTERCOM> button first.)
    If your system is set for voice intercom, people calling your phone can make it ring by dialing a "1" after your intercom number.
    If you do all this and your phone still won't ring on incoming calls, let me know and we'll have to go into system programming to correct it.
    Jan 06, 2009 | NEC Electra Professional ETW-16DC-2
    Lucent partner system intergrated with AAS gate control and intercom
    Sounds like the storm also took out the port in the phone system. try plugging in a standard telephone to the port and see if it works. if it doesn't them move the gate phone to a new port and try it.
    Oct 13, 2008 | Lucent PARTNER18 Corded Phone
    KX-T7730
    have you tried calling from another phone not connected to your main box? hold music will not work at intercom call.
    Jul 28, 2008 | Panasonic KX-T7730 Corded Phone
    2-9450c telephone will not setup
    Each telephone must be connected to line 1 and line 2 for
    proper operation. The remaining lines 3 and 4 may — or may not —
    be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set. Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
    Sep 26, 2007 | GE 2-9450C Corded Phone
    CSi Speco PBM-30 2-Channel Amplifier Logo
    Top CSi Speco Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a CSi Speco Audio Player and Recorder Expert? Answer questions, earn points and help others
