Question about Dishwashers
Dishwasher Imperial KDI-18 will go through full cycle but water does not drain and starts another full cycle all over again, still without draining.
  • Dishwashers Master
  • 3,247 Answers
Have you checked for blockages in the filter area at the base and the drain hose where it enters the kitchen drain.
Not sure what you mean by starts another full cycle all over again. Do you hear the drain motor turning on? Do you hear the water moving around through the wash arms?
Please post a comment giving your observations.
Posted on Nov 08, 2010
Dishwasher not draining
It has a drain line that goes to a fitting on the garbage disposal or the sink drain if no disposal. It is held on with a hose clamp and can clog easily
Apr 06, 2014 | Frigidaire 18" Built-In Dishwasher
Kitchenaid dishwasher imperial 21
Take the kick panel off under the door and see if the technical spec sheet is there. That lists all the diagnostics that you can run
Nov 20, 2013 | Dishwashers
When I tried to turn off the dishwasher, it accidentally started the cycle again. I pushed the off button to stop it, but the bottom is full of water. How do I drain the stop and stop the cycle?
It would help if you provide the make and full model number of the dishwasher.
Normally you would press the drain/ cancel button if you have one.
if not it should most likely drain when you start the next cycle.
Nov 24, 2010 | Dishwashers
38 year old kitchenaid KDI-16 imperial dishwasher
yep you can just get springs from lowes or home dept or your local hardware store; they're often in with the hardware (i.e., screws) and not plumbing. remember that the springs need to stretch out a bit, too; so you may end up buying springs that look shorter than they should, but they eventually habituate.
Jul 07, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Diplomat Dishwasher ADP8352 Will not complete wash Cycle
My Diplomat ADP8352 when running a cycle it will run for ages, doesn't seem to get hot. If i switch off the m/c then switch it on again it dumps the water left in the m/c?
any ideas?
Jan 04, 2009 | Hotpoint 18 in. DC28 Slim-Line Built-in...
Bosch Dishwasher Not Draining
Im really not all that familiar with the bosch unit, but a few things i would ck. when you cancel a cycle (it should drain the water) is it humming??? does it sound as if it even trickling into the sink discharge?? do you have a disposer under your sink that this unit drains into, if so remove the clamp and look for possible obstructions right there.Honestly passed this ill have to defer to someone else sorry and good luck
Mar 10, 2008 | Bosch SHU9915UC Dishwasher
18 in dishwasher drains water during cycles
find out how the dishwasher is set up to drain. Pour water into dishwasher 4 or 5 gallons, see if water disappears. if so, your drain is ran wrong
Jan 05, 2008 | Kenmore 15121 Built-in Dishwasher
Bosch Dishwasher wont drain
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Nov 17, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
DISHWASHER IS LEAKING A LOT OF WATER
I had the same problem with my machine - ie lots of water coming out front about two thirds of the way through the cycle - engineer (local and very reliable) knew as soon as he came in that I had started bying Powerball 5 dishwasher tablets - they produce too much foam (try opening the door during the cycle and see the amount of foam) and it therefore comes out of the overflow parts on the door. I tried Magnum 5 and got the same problem. Now I stick to either Asda's own basic (not the 5) or I buy the Magnum ones and cut them in half. Has never leaked since!
Jun 11, 2006 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
73 people viewed this question
Top Dishwashers Experts
