Question about Keurig Elite B40 Coffee Maker
When i brew a cup of coffee with my Keurig coffee maker there is a lot of coffee grounds that do not filter. Its like drinking dirt. How do I fix my issue?
  • Keurig Master
  • 43,501 Answers
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Mar 21, 2011
Is there a way to stop coffee from spraying?
There is a little part that sells on ebay for $2 that slides into the Keurig brewer lid and stops coffee from spraying from reusable K-cups. It works great and is guaranteed or money back. Here is the link:
http://www.ebay.com/itm/EASY-FIX-STOP-COFFEE-LEAKS-FROM-REUSEABLE-K-CUP-EKOBREW-SOLOFILL-CAFE-KEURIG-/271239290594?ssPageName=STRK:MESE:IT
Nov 14, 2011 | Keurig B70 Coffee Maker
The coffee grounds are dry after the cup is brewed. It does not taste like fresh brewed coffee.
There's a needle that punches a hole on the bottom of the K-cup. That needle is clogged. Poke it with a paper clip or a thin wire to unclog it.
Aug 23, 2011 | Keurig 5048 My K-Cup Reuseable Coffee...
All the water is not going through when I make a cup of coffee. It only makes about l/4 of a cup
Problem:
Keurig B30 would only brew a partial cup and stop. Had to run 3 times to complete brewing.
Solution:
With the coffee maker unplugged and an empty cup in place, I filled the reservoir with filtered water and with a short length of flexible plastic tubing I blew in to the small hole in the bottom of the reservoir. I did this 4 or 5 times sucking some water in to the tube to force it through the system. When I had finished there were a lot of grounds in the cup and the next time I used the coffee maker it worked perfectly.
Apr 17, 2011 | Keurig B30 Mini Coffee Maker
Partial cup of coffee brewed
Call keurig customer service 1800 cup brew
Mar 25, 2010 | Keurig B60 Coffee Maker
After cleaning/descaling my coffee maker still
If you put water in the basket, does it empty rather quickly? If it does, have you tried putting in a paper filter to help with the spillage?
Nov 24, 2009 | Keurig Coffee Makers & Espresso Machines
Our Keurig only dispenses a partial cup of coffee. We descaled as recommended and did the paperclip cleaning of the need,es and no improvement. When we press brew, it draws an appropriate amount of water...
Keurig coffee maker dispenses only part of a cup (about 5 ounces) after brewng one cup. Running a second clear cup (w/o K-cup) shows coffee grounds in cup of clear water. the maker will then brew a full cup of coffee. It appears that the top pin is too long and goes into the coffee after it punches through the top of the K-cup. Some of the gorunds appear to get stuck in the top pin.
Nov 10, 2009 | Keurig Platinum B70 Coffee Maker
My Keurig is leaving a lot of coffee grounds in the cup
I found that the kcups were under pressure. When I insert the kcup, I press down on the cup to puncture the bottom of the cup then close it. Works fine now.
May 16, 2009 | Keurig Special Edition B60 Coffee Maker
Keurig Elite B40 Coffee Maker Logo
575 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Steve Allison
Steve Allison
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
