Question about Xerox Office Equipment & Supplies
I made a mistake and fingered my drum cartridge. is there anything i can do to stop the marking it's doing to my copies. the copier model #xc1045
    New Friend:
  • 51 Answers
Clean it with silvo or alkohal or toner itself
Posted on Dec 12, 2010
Black marks on copies
This printer also has a drum unit. If the marks are appearing at regular intervals down the page (2-3 inches apart) it is almost certainly the drum unit at fault. The drum unit can easily and cheaply replaced.
Nov 01, 2012 | Brother HL-2070N Laser Printer
I have a Xerox Copier XC1045. Our copies are coming out with dark spot on the paper., I change the drum, but still have same problem, even big area has black spot
You may have a worn out heat roller in the fuser.
It is also likely you have a bad toner cartridge . If the spots are gritty then replace the toner cartridge and vacuum out the machine,
Aug 11, 2010 | Xerox 5665 Copier
The copies are coming out smeared and with lines. I wiped the (drum?) off?
What did you wipe the drum off with???? That is why you have this problem. You may want to try recleaning the opc with a dry soft rag, also you may want to clean the drum blade... If that dose not solve your problem, you may need to replace the opc & blade... Have you tried to stop the copy before it gets to the fuser unit.. If so, are the marks there???
Jun 02, 2009 | Minolta EP1083 CS/PRO Copier
Copier too dark
Did you clean the lens and the mirror under the lens cover? If so, There is a VR behind the front cover of most small Xerox machines. One VR makes the image darker/lighter and one VR changes the lead edge registration.
Dec 11, 2008 | Office Equipment & Supplies
Locked up AL-1642CS with blinking Drum Light
Older Sharp AL copiers will go on working with the drum light blinking, but yours will not. Newer models do stop working when the drum reaches its limit. Now keep in mind that just as almost every copier in the market, these units count the copies they make in order to determine toner & drum life. So it is possible to reset the drum counter if you inspect the unit and see no markings or visible wear & tear. Also keep in mind that the toner & drum units have been the same for all AL units through time, so there are plenty of good replacements in the market (not recycled, but re-manufactured or brand-new compatibles).
As for your unit, if the drum is Sharp original or a good quality replacement, you should have to do nothing after installation, for the internal chip in the drum will tell the copier to reset the counter and begin working automatically. However if that is not the case, or should you want to reset the counter on your existing drum, this is the correct sequence to do so.
  1. Identify the buttons used for adjusting exposure (darker or lighter copies), amount of copies, clear copies and start copying.
  2. Now press the following sequence of buttons: [CLR], [EXPOSURE], [CLR], [EXPOSURE]
  3. Your unit should turn off the numbers in the panel.
  4. Now press 24 as if asking for 24 copies and press [START].
  5. Press 07 as if asking for 7 copies and press [START].
  6. Your unit should restart by itself and start working normally.
Be blessed.
Nov 07, 2008 | Sharp AL-1641CS Laser Digital Copier
Replacing Drum Catridge
Hello, Here are the steps involved in replacing the drum assembly as copied from a users manual:
DRUM CARTRIDGE REPLACEMENT
The useful life of the drum cartridge is approximately 18,000 copies. When the internal counter reaches approximately 17,000 copies, the drum replacement required indicator will light up indicating that replacement of the drum cartridge will be needed soon. When the indicator begins to blink, the unit will stop operating until the cartridge is replaced. Replace the drum cartridge at this time.
1 Remove the TD cartridge (Toner Cartridge). Hold the drum cartridge handle and
gently pull the cartridge out. Dispose of the old drum cartridge in accordance with local regulations.
3 Remove the new drum cartridge from the protective bag and remove the protective cover from the cartridge. Then gently install the new drum cartridge.
When closing the covers, be sure to close the front cover securely and then close the side cover. If the covers are closed in the wrong order, the covers may be damaged. Do not remove the protective cover on the drum portion (black paper) of
a new drum cartridge before use. The cover protects the drum against external light.
Do not touch the surface of the drum (green portion) of the cartridge. Doing so may cause smudges on the copies.
4 Gently install the TD cartridge. Close the front cover and then the side cover by pressing the round projections near the side cover open button. The drum
replacement required indicator will go out and the start indicator will light up.
Aug 15, 2008 | Sharp AL-1217 Copier
What is a corotron wire
It sounds like the wire that charges the drum has broken or has a bad connection. If the drum does not get charged it will not attract toner and therefore blank copies. As i do not know the make an model of your machine I cannot give you further information.
Hope this helps.
Aug 14, 2008 | Sharp AL 1631 Copier
Xerox 5305 copier excess toner
sounds like faulty drum cleaning blade,which is usually contained in the replacement drum module.I would be inclined to take the drum unit back where you got it (unless you replaced it with a second-hand one) 99% certain the problem is contained in that module
Feb 27, 2008 | Xerox 5305 Copier
60 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
