Question about Air Tools & Compressors
I have a Dewalt 2 gallon air compressor model D55141. It is very old, but the other day I was using it and it powered off and it won't power back on. What caused this problem and can it be fixed easily.
    Sergeant:
    Champion:
  • 277 Answers
Check thet its on at the db board
Posted on Nov 08, 2010
My dewalt 2 gal air compressor model D55141, when on hisses inside the pump housing. Sounds like a leek. Some pressure builds.
More than likely is leek. Must get to it to look at connections and air line to find out If slow probably would hear it. But loud you will find it. Tighten connections if it's there, other wise replace line
Jan 05, 2018 | Dewalt Air Tools & Compressors
Where can I find a wiring diagram and a repair manual for a Dewalt air compressor D55141 2 gal ?
Go to "ereplacementparts.com" for exploded parts and pics. You will probably have to go to DeWalt for a wiring diagram but seeing the simple nature of this compressor any good electrician should be able to work it out.
Nov 03, 2014 | Air Tools & Compressors
Compressor relief valve opens 150lbs on my d55141
That is the compressor's holding capacity 150psi. Therefore, the cut-out pressure has been reached. The safety valve opens to relieve the excessive psi. Compressor should come on at 120 psi.
May 15, 2012 | Dewalt d55151 factory reconditioned emglo...
Why does my compressor just buzz when I turn it on?
that (more than likely) is the starter, but it also may have hit a bad commutator bar... turn off power, turn flywheel 1/8 (or so) of a turn, turn on power.
if it starts, purchase new motor because the commutator/brushes are dirty or shorted.
if it doesn't, replace the starter relay.
May 04, 2012 | Dewalt D55141 Heavy-Duty 2 Gallon Trim...
D55141 Electric 2 gallon Dewalt Emglo compressor won't shut off. It builds pressure past the max rating 150 psi and blows the intended safety feature, pressure relief valve as it should, but then...
Hi
your pressure switch is bad. so it isnt cutting off the compressor. the part number is N003306SV and can be obtained from Dewalt on Servicenet.
Detail
Good luck and hope this helps
Oct 26, 2011 | Dewalt D55141 Heavy Duty 2 Gal, 150 Psi...
Hi I have a Dewalt d55141 emglo contiues to run
Open the shut off switch box and adjust the cut out pressure.
Nov 17, 2009 | Dewalt & 2HP Hand Carry Heavy Duty...
Dewalt D55141 air compressor air leak
hi mate this problem may be more than 1 1st it could be the piston rings gone and the air is leaking into the crank and has blown the crank seal but you can tell that if oil is coming out the rear off the pump unit also it could be the breather blocked which allows air in and out the breather is the oil filler cap. good luck
Jun 22, 2009 | Dewalt & 2HP Hand Carry Heavy Duty...
Air Tools & Compressors Logo
108 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
